Rumdum Samba Member
Posted: Mon Jan 26, 2015 8:09 am Post subject: Body grommet for headlight wire |
When replacing the the nose skin 10 years ago on my 75 Westy, I apparently cut the wire near the headlight connection. I'm certain I attempted to label and keep the connector and the grommet for the wire entering the headlight bowl but I cannot find either. I have searched here for info and Bus Depot for replacement parts. Any suggestions for both the grommet and the proper plug/connector for the headlight? I have access to local junkyards but would prefer new parts if available.
Thanks for your time. _________________ 1975 Westfalia Campmobile
CB Performance Dual IDF Weber 40
- jetted and optimized by Aircooled.net |
VWDruid Samba Member
Joined: June 14, 2008 Posts: 1192 Location: Boca de Ratones FL
Rumdum Samba Member
Posted: Mon Jan 26, 2015 8:25 am Post subject: |
That would certainly be a good option for the grommet. Also considered the windshield washer shaft grommet. Lowe's would be a simple solution. Thanks!
Then there's the headlight connector/plug... _________________ 1975 Westfalia Campmobile
BUSBOSS Samba Member
Joined: January 21, 2009 Posts: 2161 Location: Northern California
Posted: Mon Jan 26, 2015 8:39 am Post subject: |
You will probably have to find a scrapyard donor for that. Not much of a market for reproducing that part. _________________ All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
1970 Karmann Ghia Convertible (sold - but not forgotten) |
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Mon Jan 26, 2015 9:02 am Post subject: |
I have a couple of used vanagon headlight connectors. Don't know if they are the same shape.
Post a closeup photo and I'll check what I have.
Aloha
tp |
PITApan Samba Member
Joined: November 09, 2014 Posts: 1058 Location: Northern Colorado
Posted: Mon Jan 26, 2015 9:25 am Post subject: |
Rumdum wrote: |
Then there's the headlight connector/plug... |
If you are running H4 bulbs, all use the same connector. Get anywhere.
If you are using really big H4 bulbs, like 100/130, you would want a high temp phenolic connector. Not so easy to find. I would ask at David Stern lighting. The connector for the bmw /5 series motorcycle is very nice but you would have to go to an online boneyard for those.
I run 10Ga wire to the bulbs and use no connector. Just SAE Female spades and call it good. |
Rumdum Samba Member
Posted: Mon Jan 26, 2015 9:28 am Post subject: |
Tom Powell wrote: |
Aloha
tp |
Thanks for the assistance but I dont have an example to go by... All I know is that I need it to fit headlights for a 75 bus. _________________ 1975 Westfalia Campmobile
busdaddy Samba Member
Posted: Mon Jan 26, 2015 9:32 am Post subject: |
Any FLAPS will have a universal sealed beam headlight pigtail and likely a grommet of the correct diameter as well. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Rumdum Samba Member
Posted: Mon Jan 26, 2015 9:46 am Post subject: |
busdaddy wrote: |
Any FLAPS will have a universal sealed beam headlight pigtail and likely a grommet of the correct diameter as well. |
Thanks for the suggestion. I'll give them a try today. _________________ 1975 Westfalia Campmobile
Hoody Samba Member
Posted: Mon Jan 26, 2015 9:48 am Post subject: |
ECS tuning will have the correct grommet. You can get the part number from German Supply's website. |
Posted: Mon Jan 26, 2015 9:52 am Post subject: |
Rumdum wrote: |
Tom Powell wrote: |
Aloha
tp |
Thanks for the assistance but I dont have an example to go by... All I know is that I need it to fit headlights for a 75 bus. |
I took a look at what I had from a vanagon and the connector in your photo. Not at all the same.
I'm of no use.
Aloha
tp |
Rumdum Samba Member
Posted: Mon Jan 26, 2015 4:02 pm Post subject: |
busdaddy wrote: |
Picked up two pigtails at my flaps. No grommet yet.
Thanks! _________________ 1975 Westfalia Campmobile
Sage79 Samba Member
Joined: September 13, 2008 Posts: 433 Location: Holland MI
Posted: Tue Jan 27, 2015 6:00 am Post subject: |
If your hardware store doesn't have them, Radio Shack carries assorted grommets, you may have to buy an assortment to get the one you need but then you'll have others that come in handy. _________________ Dirk
'79 Westy 2.0FI
'73 Sportsmobile 1.7dual Solex 003Auto - now my daughter's
'77 delux 2.0FI 090Auto - now my son's |
Tcash Samba Member
Rumdum Samba Member
Posted: Tue Jan 27, 2015 10:31 am Post subject: |
Sage79 wrote: |
If your hardware store doesn't have them, Radio Shack carries assorted grommets, you may have to buy an assortment to get the one you need but then you'll have others that come in handy. |
Thanks guys!!!! _________________ 1975 Westfalia Campmobile
Rumdum Samba Member
Posted: Wed Jan 28, 2015 12:35 pm Post subject: |
back to the connector/pigtail I bought.... Since I cut the original wires to my headlight I don't know which wire is which? My replacement pigtail has all three same colored wires. I have searched for a solution with no results. Any input or pic would be greatly appreciated. _________________ 1975 Westfalia Campmobile
Posted: Wed Jan 28, 2015 12:44 pm Post subject: |
Rumdum wrote: |
back to the connector/pigtail I bought.... Since I cut the original wires to my headlight I don't know which wire is which? My replacement pigtail has all three same colored wires. I have searched for a solution with no results. Any input or pic would be greatly appreciated. |
You should have brown, yellow and white. Brown is ground. CHeck you bulb with a meter. The tab that is common to both of the others is the ground.
I forget which is hi or low, yellow or white. Someone will check in on that. But you can just try it by twisting wires temporarily and hitting the switch. No harm if you reverse hi and lo. If reversed, switch them and you are done. If not reversed you are done. Build. |
Posted: Wed Jan 28, 2015 12:46 pm Post subject: |
Слава Україні! |
Rumdum Samba Member
Posted: Wed Jan 28, 2015 1:16 pm Post subject: |
Bless you, Busdaddy! I can now scratch this task from my list today! _________________ 1975 Westfalia Campmobile
Tcash Samba Member
Posted: Wed Jan 28, 2015 5:31 pm Post subject: |
It looks upside down?
