GTV Samba Member
Posted: Mon Feb 02, 2015 10:30 am Post subject: |
65Bugsmasher wrote: |
GTV wrote: |
They are riveted in, drill out the rivets. |
Thanks! I am assuming that WW or someone sells the replacement rivets when the time comes? |
Regular 3/16" rivets from the hardware store. _________________ EMPI Power Rules! |
65Bugsmasher Samba Member
Posted: Wed Feb 11, 2015 6:32 pm Post subject: |
Got a chance to finish taking apart the seat fabric/ upholstery today after work and discovered the rear seat frames were in good shape despite the rat nests...
Also got a chance to clean up the original paint and put on the extra door to replace the bashed one. I think it turned out pretty well. Thoughts?
*Also, in the process of replacing the cargo door, I had to drill out the lower door screws, which caused the plate that the screws go into (in between the door frame to break. Does anyone reproduced this part as it will need new? Also, how do I get the old one out? I tried searching, but did not find much. Thanks! |
velvetgreen Samba Member
Posted: Sun Feb 22, 2015 1:36 pm Post subject: |
Finally a warmer say here in PA. Was able to remove the front mat only to see swiss cheese on the front floor. Another thing that caught my eye was the shift rod bolts. They both appear to stripped pretty bad. Any good way to remove these?
Also, what is up with my heater knob? It doesn't look remotely close to any of the ones I have seen that came standard..
wedv907 Samba Member
Posted: Sun Feb 22, 2015 2:41 pm Post subject: |
that floor will look less intimidating once you get all the old pieces out.weld some nuts on the top of old shifter bolts and the heat from welding and new place to put socket on will take them right out.the buses i have done i found there was no other repair more rewarding than throwing a new front floor down.try not to get overwhelmed on the big picture and just start focusing on certain areas,before long you will be driving it.htr knob looks custom ,but i like it as i have an old glass door knob as my shifter. good luck jeff |
Schwing Samba Member
Joined: May 10, 2009 Posts: 2506 Location: Centreville, MD
Posted: Mon Feb 23, 2015 8:16 am Post subject: |
Go to the hardware store and pick up a bottle of yellow map gas and an adaptor that screws right onto the tank. The advice to weld on nuts I completely agree with, however there is always another way. If you heat the living hell out of those nuts with this torch you can use vice grips to very easily remove stripped bolts. In between heating spray some PB Blaster and it will get absorbed into the threads. You can do it! _________________ Shadetree Westy
http://www.thesamba.com/vw/forum/viewtopic.php?t=657279&highlight=
Single Cab - BBXXVII Long Distance Winner
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
vwmike81 Samba Member
Posted: Mon Feb 23, 2015 8:31 am Post subject: |
Nice bus you have there, jealous, as I am looking for a walk thru similar here in New England. |
Posted: Mon Mar 02, 2015 5:28 pm Post subject: |
Another update to the bus. As I am going through seeing what exactly needs new metal and replaced, I am perplexed as to my findings. Looking at other pictures and diagrams, I have noticed that I am missing the long heater tube from the front of the bus to the rear. Where can I find it?
Also, when looking at the engine tin, I noticed that this is two separate pieces as seen in the picture below. On my beetle it is only one solid piece of engine tin. Am I correct in thinking that the bus engines have one piece tin also?
Thanks! |
Tyler 5447 Samba Member
Posted: Mon Mar 02, 2015 8:55 pm Post subject: |
Thanks! |
On the tin, one side of the motor has one piece tin and the thermostat side is two piece.
I haven't ever seen a repop heater tube. Either hunt down a used one or make your own. |
Posted: Mon Mar 09, 2015 5:28 pm Post subject: |
I started to finally look at the engine to get a better idea of what I am working with. I think it is what appears to be the stock engine, but have a few questions below. Any insight is greatly appreciated. Thanks!
1) The engine is stamped D0000781- The bus itself is a 1965, however after looking at a few resources, opinions vary whether or not the D stamp is original or rebuilt. Any insight? Also, what size is the engine based off of the picture and the information. I am fairly certain it is a 1200cc, but would like to know for sure before getting into it..
2) Looking at the distributor and those images of other buses, including the Bentley, it is missing the vacuum cylinder and looks completely different. Any ideas about the distributor? Has it been switched to electronic ignition or what?
3) Upon removing some of the grease and grim to the block, there is a WC stamped in the block, as seen in the pic below. Anyone have something similar to this? My beetle does not have this stamped into it
spanky324 Samba Member
Joined: September 28, 2006 Posts: 1070 Location: Greeley Pa
Posted: Tue Mar 10, 2015 2:23 pm Post subject: |
"Looks to be an aftermarket "009"distributor-not original |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Tue Mar 10, 2015 2:27 pm Post subject: |
D says 1200cc 40 horse, looks like one, too. grab a 1600 exhaust and hold it up to it, if it is too wide, you have a 40horse still _________________ regards
Uli
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Posted: Tue Mar 10, 2015 2:39 pm Post subject: |
mandraks wrote: |
D says 1200cc 40 horse, looks like one, too. grab a 1600 exhaust and hold it up to it, if it is too wide, you have a 40horse still |
Awesome, will have to check that out. The PO stated that it was a 1500cc. I am still learning the ropes of bus parts specifically. Would it be a fresh air, or stale air 1200cc? I still do not know how to figure that out... |
Posted: Tue Mar 10, 2015 5:00 pm Post subject: |
Schwing wrote: |
Here is the link to the Alan Schofield center heat pipe. I bought their full kit since all of mine were rotten and my center was missing too. Check the others and make sure they are solid because you can't buy the others individually.
http://www.alanhschofield.com/ourparts/prod_2429768-Heater-Tube-72-211255785A.html
Also you have a fresh air motor due to the tubes that are coming off the fan shroud. Its hard to tell the difference between a 1200 and 1500, at least for me.
I checked your engine number and it looks like an Aug 65 Type 1 1200cc motor according to the charts. |
Thanks for the helpful link. I noticed when clicking on it, it says for bay window..are those the same size tubes for both splits and bay windows? So the engine in the bus is actually for a beetle? I have been searching mufflers, etc, and the only thing that has me thinking its a 1500cc is the actual layout of the muffler having the small tube on the right side as shown in the pic. Most of the 1200cc bus mufflers I have seen on various websites all have the small tube on the left side. I am not sure if that makes a difference... |
Posted: Tue Mar 10, 2015 5:43 pm Post subject: |
Schwing wrote: |
Yeah good point, its listed under the splitty section but shows up as a bay window part. Maybe you could call and ask if they are the same or if they just sell the long tube?
Here is the link to the full part:
http://www.alanhschofield.com/ourparts/prod_2429781-Complete-Heater-Tube-Set-67-LHD-211255715.html
So the bus and bug engines are pretty much the same, so more than likely someone installed a bus muffler on your bug engine, and there is no shame in that. They literally bolt up the same way. I am pretty sure both the 1200cc and the 1500cc both exit on the left, but I could be wrong. _________________ Shadetree Westy
Posted: Tue Mar 10, 2015 6:09 pm Post subject: |
Thanks a bunch for the link and help. I will have to call them to check on that. It is a relief to know that I am able to get this tube to fix the lack of heater tube present on the bus. Based on the numbers, I will go with it being a 1200cc distributor. Chances are I will change out the aftermarket distributor with another distributor that I have on a space beetle 1200cc engine. Maybe it's me being to anal, but I like the look of the original better |
Posted: Sat Mar 21, 2015 5:31 pm Post subject: |
Another nice day in PA, so I pulled the engine and gas tank out of the back. After pulling the engine, my mind is now blown as to what size it is. After checking my other two 1200cc engines, the intake manifold is completely different, looking like one for a 1300cc or above. Also, the manifold preheat tubes look larger in diameter as well. I am at a complete loss as to what size it is, but would like to know so I can start ordering parts. I did not plan to split the case apart or measure pistons, as the engine spins freely, has compression, and no end play. I have included pics below of intake manifold in hopes of help...
Posted: Tue Apr 28, 2015 5:46 pm Post subject: |
I finally had a free night, so I tackled cutting out the front floor. When cutting it, I noticed there were some rust spots that need replaced on the front nose as well. This is my first bus, first time cutting it out, etc. I think I did a decent job thus far...Critics welcome to comment please.
One question I have was in regards to the A- Pillar in the front. Each side has the same parts rusted as shown in the picture. Looking at the funky green metal, I am a bit confused as to which A-pillar section repair piece I need. Anyone able to help, that would be great!
Edit: Anyway admin could change the thread title to 65' Velvet Green Walk Through Build
