Jbarnestennis Samba Member
Joined: September 17, 2014 Posts: 236 Location: Maryland
Posted: Tue Jan 27, 2015 10:37 pm Post subject: A lot of Bondo and whether to cut the metal or not |
Alright I know I have been bothering you guys on here about an engine, but while I have the bus in the garage I wanted to fix some of the rust.
Well... turns out there is a lot of bondo. Now, I am not even close to getting all of it off, but I was lucky enough to buy another bay as a package deal. I chose to restore the 76 because the interior and exterior seemed to be better and for the most part I still believe it is better than the 78. And where most of the bondo and rust is on the 76, the body on the 78 is in pretty good condition.
I am scared to ask, but should I cut up the 78 or buy the panels online because I am not sure how hard it is to pull off and put on an entire panel. The majority of the damage is on the drivers side middle panel; the big panel. I will post pictures tomorrow. Thanks |
kkjellquist Samba Member
Joined: June 04, 2013 Posts: 752 Location: Asheville, NC
aerosurfer Samba Member
Joined: March 25, 2012 Posts: 1602 Location: Indianapolis, IN
Posted: Wed Jan 28, 2015 5:58 am Post subject: |
whats your hangup on doing the 78 instead? They are essentially the identical car, variations being possible seat tracks. Why cut out good metal when its in a perfect spot now?
But yes if you have to use as much original metal as you can. I have most of the lower 6 inches of a bus sitting in a room above my garage waiting to be used someday _________________ Rebuild your own FI Harness..My Harness
77 Westy 2.0L Rockin and Rolling Resto!
72 Sportsmobile (sold)
79 Tran$porter... Parts car money machine (gone) |
morymob Samba Member
Posted: Wed Jan 28, 2015 6:57 am Post subject: |
Good sheet mtl 1st, the bolt on/off /in stuff the easy part. |
Rumdum Samba Member
Posted: Wed Jan 28, 2015 7:45 am Post subject: |
Without seeing a pic I think it would be hard to make a call. Especially on the large side panel. Unless you're talking about welding in the entire side panel, you"re going to have to use filler ("bondo") for the weld seams anyway. Without seeing a pic, I might would suggest removing the filler first (free) and assess..... then consider straightening the panel (also free) and use a skim coat of filler. _________________ 1975 Westfalia Campmobile
CB Performance Dual IDF Weber 40
- jetted and optimized by Aircooled.net |
barefootwestie Samba Member
Joined: September 19, 2005 Posts: 1551 Location: Johns Island, SC
Posted: Wed Jan 28, 2015 8:05 am Post subject: |
Just remember, most purchased panels are not going to match as good as the original metal. _________________ My Bus Restoration Blog
https://myvolkswagenbus.com/
1973 Westfalia
"Getting better....one repair at a time."
Other VW's owned through the years, in no particular order:
'67 Beetle,
'67 Ghia Hardtop,
'72 Ghia Convertible,
'72 Westfalia |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51147 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Jan 28, 2015 8:33 am Post subject: |
Body work and rust repair is hard, pick the best body and transfer all the mechanical stuff onto it. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed Jan 28, 2015 9:48 am Post subject: |
busdaddy wrote: |
Body work and rust repair is hard, pick the best body and transfer all the mechanical stuff onto it. |
Agreed, two full days of labor can move the engine, tranny, front suspension, plus a lot of other stuff over. |
Posted: Wed Jan 28, 2015 11:50 am Post subject: |
I will post pictures tonight and tomorrow. the 78 is pretty rusted out especially on the front because it didn't have a front windshield and was left outside. but for some reason the side that isn't damaged on the 78 is damaged on the 76. |
Posted: Thu Jan 29, 2015 5:18 pm Post subject: |
Posted: Thu Jan 29, 2015 5:19 pm Post subject: |
Front end
Posted: Thu Jan 29, 2015 5:23 pm Post subject: |
Posted: Thu Jan 29, 2015 5:28 pm Post subject: |
This is the 78 on the drivers side that I think I can use
Posted: Thu Jan 29, 2015 5:30 pm Post subject: |
Posted: Thu Jan 29, 2015 7:01 pm Post subject: |
Rumdum wrote: |
Without seeing a pic I think it would be hard to make a call. Especially on the large side panel. Unless you're talking about welding in the entire side panel, you"re going to have to use filler ("bondo") for the weld seams anyway. Without seeing a pic, I might would suggest removing the filler first (free) and assess..... then consider straightening the panel (also free) and use a skim coat of filler. |
What do you think about transferring a panel from the white one over to the yellow or is the yellow repairable enough? |
Joined: January 01, 2007 Posts: 16879 Location: sticksville, ct.
Posted: Thu Jan 29, 2015 7:42 pm Post subject: |
hate to say it, but I think you have 2 turds _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Thu Jan 29, 2015 7:58 pm Post subject: |
skills@eurocarsplus wrote: |
hate to say it, but I think you have 2 turds |
yeah that's what it is looking like. The white one has minimal bondo though. So I am not sure what to do. |
Posted: Thu Jan 29, 2015 8:44 pm Post subject: |
I wouldn't waste the time to cut anything out of the supposed donor, you'll be replacing crap with crap. That side panel doesn't look too rotten, aside from the dent it's relatively intact, either bondo it up again or just replace the outer skin with off the shelf bulk sheet metal, when you dig into the seams the job becomes enormous and you'll be sorry.
Once you start digging deeper you'll find far more sh*t that's even worse than on the outside, sometimes it's best to leave sleeping dogs be. That doesn't mean you can't use the bus, just don't get any dreams of a Pebble beach invitation anytime soon. Besides the rough ones are more fun than the museum pieces sometimes, what's one more scratch or dent as long as you had fun doing it?, nothing beats an action bus! _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Jan 29, 2015 8:53 pm Post subject: |
busdaddy wrote: |
Once you start digging deeper you'll find far more sh*t that's even worse than on the outside, sometimes it's best to leave sleeping dogs be. That doesn't mean you can't use the bus, just don't get any dreams of a Pebble beach invitation anytime soon. Besides the rough ones are more fun than the museum pieces sometimes, what's one more scratch or dent as long as you had fun doing it?, nothing beats an action bus! |
Yeah I have no worries about how it looks, but if it needs to be fixed or I can do it myself I will. I was thinking about removing all the bondo, moving the sink and cabinets from the inside and banging the dent out. I don't know how it would go, but I have it in my garage and it's worth a shot. I will just spray it with some primer after the bondo is gone and it is sanded. Not looking for a full restoration.
I don't want the 78 to just sit out and rust, but I have no room for it so I was trying to think of a way to use it. If I do move the sink out I might switch the fridges out because the 78 has an actual fridge where the 76 is just a cooler. |
Posted: Thu Jan 29, 2015 9:01 pm Post subject: |
You'll be pulling the sink cabinet and almost the whole rest of the interior to fix it either way, there's no easy way to do it. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
