msimoni Samba Member
Posted: Wed Jan 28, 2015 1:30 pm Post subject: Pertronix Flamethrower Timing |
Hi guys... I had to re-do my engine, and now trying to get the timing I came to an issue: the engine will iddle smooth at about 25 degrees advance... and at 3000RPM's it will be reaching 45 degrees...
If I get it to 7,5 to 10 degrees at 1000RPM it will run rough, stutter on acceleration...
any ideas what is wrong? _________________ By Colella sand rail A.K.A.: "Electric Chair" - VW 2.150cc, dual EMPI HPMX44's, Engle W110, 44mm intake/35mm exaust dual spring valves, fully modded and ported heads, Pertonix Flame Thrower Distributor and Digital Ignition, Flamethrower Epoxi filled Coil, Flamethrower 8.8mm spar plug cables, Dual UMP air boxes 3"intake, Raised dual K&N 3"air filters, Full Rancho RS9000XL shocks, etc. |
Mr.Duncan Samba Member
Joined: May 12, 2012 Posts: 3542 Location: Houston, TX
Posted: Wed Jan 28, 2015 1:43 pm Post subject: |
with the engine sitting in a parking lot, not moving, and the vac line connected to the dizzy, you will see a high advance like that.
On the road, when the engine is UNDER LOAD, the vac signal drops. (so your max advance is really only the mechanical advance.
Just:
Unplug and block the vacuum line.
Rev to 3000 rpm
at that rpm adjust timing to 28*31* BTDC.
Re-hook the vac line up.
Cheers- _________________ (Owner) www.vintagecarleds.com
Red 1971 Squareback Thread
Red 1966 Beetle Thread
1971 Green Super Beetle (sold)
1966 Ghia (sold)
1971 Blue Super Beetle (sold)
1966 Java Green Std Beetle (sold)
1971 Red Squareback (sold)
1966 Red Beetle |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Wed Jan 28, 2015 2:04 pm Post subject: |
Mr.Duncan wrote: |
Just:
Rev to 3000 rpm
Cheers- |
45 degrees is too high even it's running right which it's not. 36-40* with the advance working correctly at 3000+rpm's is normal. _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
Posted: Wed Jan 28, 2015 8:39 pm Post subject: |
Thanks guys!
My ignition is a pertronix billet distributor with ignitor II, and a pertronix epoxi coil, so no vacuum here.
If I set my timing to about 10 degrees at iddle, it will run rough... could I have a timing shaft misplaced under my distributor when the engine was put back together? and this could lead to a wrong number reading at the pulley?
I've been thinking about that... since it feels, and starts easy and smooth at 25 degrees BTDC, and at over 3.000RPM's I see over 46 (even 50's) degrees BTDC, it would make sense, my reading could be about 10 degrees off, just the reading? _________________ By Colella sand rail A.K.A.: "Electric Chair" - VW 2.150cc, dual EMPI HPMX44's, Engle W110, 44mm intake/35mm exaust dual spring valves, fully modded and ported heads, Pertonix Flame Thrower Distributor and Digital Ignition, Flamethrower Epoxi filled Coil, Flamethrower 8.8mm spar plug cables, Dual UMP air boxes 3"intake, Raised dual K&N 3"air filters, Full Rancho RS9000XL shocks, etc. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76935 Location: Sneaking up behind you
Posted: Wed Jan 28, 2015 8:45 pm Post subject: |
msimoni wrote: |
could I have a timing shaft misplaced under my distributor when the engine was put back together? and this could lead to a wrong number reading at the pulley? |
No... the orientation of the driveshaft will not change the crank timing. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Wed Jan 28, 2015 9:03 pm Post subject: |
gee... wonder what could it be... when I removed the engine, it was 10 degrees at iddle and 32 at 3000rpm... _________________ By Colella sand rail A.K.A.: "Electric Chair" - VW 2.150cc, dual EMPI HPMX44's, Engle W110, 44mm intake/35mm exaust dual spring valves, fully modded and ported heads, Pertonix Flame Thrower Distributor and Digital Ignition, Flamethrower Epoxi filled Coil, Flamethrower 8.8mm spar plug cables, Dual UMP air boxes 3"intake, Raised dual K&N 3"air filters, Full Rancho RS9000XL shocks, etc. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Thu Jan 29, 2015 8:25 am Post subject: |
Best range is 28-32° BTDC at 3000 rpm... Forget what idle timing is.... If your distributor puts in more than 20-22° centrifugal advance you can never get the two values you are looking for to work... You can't have 7.5 at idle and 30 at 3000 rpm....
The 7.5° BTDC is generally a "static" value not with engine running...
You dont drive your car at idle, you drive it at 3000 RPM...
Posted: Thu Jan 29, 2015 8:33 am Post subject: |
Dale M. wrote: |
Dale |
Thanks Dale!
I will ask my engine builder if he has put the gear that turns the distributor in the correct position, and have him here to double check it. Would that make me read over 10 degrees difference (let's say if he has put the gear one or two tooths after TDC position? _________________ By Colella sand rail A.K.A.: "Electric Chair" - VW 2.150cc, dual EMPI HPMX44's, Engle W110, 44mm intake/35mm exaust dual spring valves, fully modded and ported heads, Pertonix Flame Thrower Distributor and Digital Ignition, Flamethrower Epoxi filled Coil, Flamethrower 8.8mm spar plug cables, Dual UMP air boxes 3"intake, Raised dual K&N 3"air filters, Full Rancho RS9000XL shocks, etc. |
Posted: Thu Jan 29, 2015 5:55 pm Post subject: |
msimoni wrote: |
Dale M. wrote: |
Dale |
Thanks Dale!
I will ask my engine builder if he has put the gear that turns the distributor in the correct position, and have him here to double check it. Would that make me read over 10 degrees difference (let's say if he has put the gear one or two tooths after TDC position? |
The gear has NOTHING TO DO WITH IT...... Its all about where timing mark on pulley is located in relationship to case split line when points "open" for # 1 cylinder...
What is total mechanical advance internal in distributor?...
Do you understand how to static set timing?
Posted: Thu Jan 29, 2015 6:22 pm Post subject: |
FACTORY spec allowed up to 44 degrees of total timing. The limit is NOT 40 degrees.
udidwht wrote: |
45 degrees is too high even it's running right which it's not. 36-40* with the advance working correctly at 3000+rpm's is normal. |
_________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Posted: Thu Jan 29, 2015 9:56 pm Post subject: |
Dale M. wrote: |
msimoni wrote: |
Dale M. wrote: |
Dale |
Thanks Dale!
Dale |
Dale
Not sure about static timing.
My distributor will mechanically (centrifugal) advance 24 degrees .
I have set the timing on the distributor with both valves on cyl one closed . Is there any tips on this? Thanks _________________ By Colella sand rail A.K.A.: "Electric Chair" - VW 2.150cc, dual EMPI HPMX44's, Engle W110, 44mm intake/35mm exaust dual spring valves, fully modded and ported heads, Pertonix Flame Thrower Distributor and Digital Ignition, Flamethrower Epoxi filled Coil, Flamethrower 8.8mm spar plug cables, Dual UMP air boxes 3"intake, Raised dual K&N 3"air filters, Full Rancho RS9000XL shocks, etc. |
Posted: Fri Jan 30, 2015 7:24 am Post subject: |
msimoni wrote: |
Dale M. wrote: |
msimoni wrote: |
Dale M. wrote: |
Dale |
Thanks Dale!
Dale |
Dale
I have set the timing on the distributor with both valves on cyl one closed . Is there any tips on this? Thanks |
To set static timing #1 cylinder has to be on compression stroke (both valves closed)...
Crank pulley has to be on 7.5° BTDC...
Put a test lamp across across negative (-) terminal of coil and ground.
Turn key on (do not start)..
Loosen and rotate distributor till lamp just comes on... Tighten distributor (be sure rotor is still pointing to #1 tower on dist cap) ..
Your static timing is now set at 7.5° BTDC...
With 24° mechanical advance and 7.5° of static timing your total timing should be about 31.5 degrees at full advance (3000+ RPM) ...
Posted: Mon Feb 16, 2015 1:19 am Post subject: |
[email protected] wrote: |
udidwht wrote: |
More like 44 degrees with max vacuum advance.
That may have been true from the factory but with a distributor from today? _________________ 1972 Westy Hardtop/Type-4 2056cc
71mm Stroke
Bosch W8CC plugs
3 rib 002 Trans
Zylinderkopf Samba Member
Joined: September 09, 2012 Posts: 679 Location: SE Oklahoma
Posted: Sun Mar 25, 2018 2:16 am Post subject: |
udidwht wrote: |
udidwht wrote: |
That may have been true from the factory but with a distributor from today? |
Got my Pertronix running at 44 total advance without pinging or overheating issues. I found that if I set the timing any lower it won’t idle right. Was concerned at first but it’s been running well this way for a couple of years now. _________________ 1963 Beetle
1966 Beetle 1300
1970 Karmann Ghia Coupe
1971 Super Beetle
1974 Thing
"A lot of people never use their initiative because no one told them to." |
laker Samba Member
Posted: Mon Mar 26, 2018 5:51 pm Post subject: Re: Pertronix Flamethrower Timing |
If you have a shop that has a dyno in your area see if you can get 1/2 hour on it and time the car on the dyno (my favorite way to time a vehicle)...put the vehicle under a steady load, loosen the distributor, advance the timing slowly until starts to ping then back it off till stops pinging, tighten distributor and check your timing at idle & 3,000 rpms for future reference. |
jeffinohio Samba Member
Joined: February 02, 2017 Posts: 197 Location: Scio Ohio
Posted: Tue Mar 27, 2018 6:47 am Post subject: Re: Pertronix Flamethrower Timing |
Pertronics SVDA on mine is set at 44 degrees total.Stock 1600DP.No ping or heat issues.6000 miles on it. _________________ 64 Sunroof
73 Standard
70 Convertible
67 Cougar
3 Subarus |
Posted: Thu Mar 29, 2018 3:49 am Post subject: |
Zylinderkopf wrote: |
udidwht wrote: |
udidwht wrote: |
Got my Pertronix running at 44 total advance without pinging or overheating issues. I found that if I set the timing any lower it won’t idle right. Was concerned at first but it’s been running well this way for a couple of years now. |
Consider yourself lucky. Those Pertronix dizzies are all over the map in-terms of overall advance. No 2 are alike. _________________ 1972 Westy Hardtop/Type-4 2056cc
71mm Stroke
Bosch W8CC plugs
3 rib 002 Trans
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2742 Location: Hamble, Hampshire, UK
Posted: Thu Mar 29, 2018 9:31 am Post subject: Re: Pertronix Flamethrower Timing |
At 1000 rpm you may already be seeing some centrifugal advance. Back off to 850-900 rpm and set the timing.. may be iterative .. _________________ Ancient vehicles and vessels
Bob Brugge Samba Member
Joined: April 09, 2015 Posts: 721 Location: Missoula, MT
Posted: Thu Mar 29, 2018 1:03 pm Post subject: Re: Pertronix Flamethrower Timing |
Not sure if this is right or not, but this is what I do.
I make sure #1 is on power stroke and at tdc.
After verifying the rotor points to #1, I turn the key on and rotate the dizzy back and forth until I hear the 'click' made by the pertronix unit. Then I know I am good to fire it up.
Once started I use the timing light to see where the max advance is and lock it down.
Again, not sure if thats right or not. I run a German uh oh 9 and had it on a sp 1641.
Any input? _________________ Keep on Dubbin'! |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3847 Location: San Jose, CA
Posted: Thu Mar 29, 2018 1:46 pm Post subject: |
Dale M. wrote: |
msimoni wrote: |
Dale M. wrote: |
msimoni wrote: |
Dale M. wrote: |
Dale |
Thanks Dale!
Dale |
Dale
Dale |
Dale, correct me if I'm wrong, but I don't think he could set static timing with an Ignitor. I said "could" because the OP hasn't reported back to this thread, so we don't know his outcome or just what he ended up doing. |
