PressY4Pie Samba Member
Joined: December 10, 2014 Posts: 73 Location: Redding Ca
Posted: Wed Jan 28, 2015 6:51 pm Post subject: Mounting to Super Beetle Dash? |
so like many of you im sure my dash is cracked to crap. i want to mount a phone stand to the dash in the corner of my speedometer circled in red:
but there is no real way of putting a screw through the dash without it just smashin it up. has anyone been able to mount to a crackled ol' dash board? _________________ Who? |
cjsuner Samba Member
Joined: January 04, 2013 Posts: 476 Location: Bay area CA
Posted: Wed Jan 28, 2015 7:37 pm Post subject: |
industrial strength velcro? _________________ 71' Super Convertible (Orange)
74 Super Beetle (Red) |
mikeonthebike Samba Member
Joined: December 08, 2012 Posts: 953 Location: Sacramento, CA
Posted: Wed Jan 28, 2015 7:39 pm Post subject: |
I would try adhesive mounts that stick to it. An adhesive mount will have more contact area. A screw will pull out too easily. |
windfish Samba Member
Posted: Wed Jan 28, 2015 8:10 pm Post subject: |
Window mount would be easiest and least-destructive.
I really like my iOttie mount, I've got the arm all the way condensed on my Standard, it extends a fair amount so you could probably put it fairly close to where you've marked.
The sticky foot is impressively strong, like annoying to switch between cars strong -- it's actually designed to stick to a dash, but won't work on that pad.
(Amazon link)
Edit - If the area under the pad in that corner isn't cracked you can mount the iOttie (or similar) to the dash. Just notch the mat to fit around the base.
Kinda thinking that gluing, velcroing, etc to the top of that dash pad isn't going to work all that well -- the mount just wont be stable. |
Posted: Wed Jan 28, 2015 11:36 pm Post subject: |
Hm. That looks much easier, and not as bad as I thought. Maybe I'll try a window mount _________________ Who? |
bobbydeon Samba Member
Joined: September 09, 2005 Posts: 7 Location: Morgan Hill
Posted: Wed Jan 28, 2015 11:54 pm Post subject: |
Sticking stuff other than a rear view mirror on your windshield is illegal in CA. no exceptions.So if you are ok with giving law enforcement a reason(no matter how lame you think it is) to pull you over...check out a thing called the plug and chug it replaces your ashtray with a twin cup holder and a cellphone holder. |
Posted: Thu Jan 29, 2015 8:32 am Post subject: |
Today I learned....
btw, that's incorrect that its totally banned in Cali, they just require it in a "5 inch area in the lower corner of the windshield on the driver side, or a 7 inch area in the lower corner of the passenger side"
(source), and apparently the law is still evolving - (link)
Seems a rather silly law, glad it doesn't apply in NC
So the way I have mine mounted would be illegal, but you could put it on either side.
Or just dash-mount it, should have a 3" diameter section of dash under that mat that's in decent shape, given you don't mind notching the mat.
Then again... I've driven through VA, SC, GA and other states where the ban is in place and there's been window mount GPS units on every third car.
So /shrug. |
cletus_zuber Samba Member
Joined: January 08, 2010 Posts: 2408 Location: Gladstone, Ore
Posted: Thu Jan 29, 2015 7:56 pm Post subject: |
When are you gonna get some knobs on that radio? local junkyards etc don't have a few you could try to fit? Makes me think I'm lucky my Kenwood of the same vintage has the knobs... _________________ 1972 1302
HPMX 40's & 019 |
Posted: Fri Jan 30, 2015 7:41 am Post subject: |
cletus_zuber wrote: |
When are you gonna get some knobs on that radio? local junkyards etc don't have a few you could try to fit? Makes me think I'm lucky my Kenwood of the same vintage has the knobs... |
Hah. Eventually!
The local scrapyards are actually very picked over, have to get lucky to find anything worth while. Someone had started to pull that radio (probably why it's missing the knobs), but didn't want to take the time to get it out (old work van, very tight fit).
It's also low on the priority list, as it's functional as is. |
vamram Samba Member
Posted: Fri Jan 30, 2015 10:34 am Post subject: |
Just like the old Alpine I had in my '72 standard oh...30 years ago. _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
TheAmazingDave Samba Member
Joined: April 11, 2013 Posts: 788 Location: San Jose, CA
Posted: Fri Jan 30, 2015 1:23 pm Post subject: |
I also use a windshield mount, but I use a tablet in the Bug, not my phone.
bobbydeon wrote: |
While technically true, I have not had a single problem with law enforcement. I don't have a front plate either, no troubles. The mirror dice are also illegal; no problem.
In fact, most police I buzz by just smile. Others don't look twice. That's the kind of stuff you get pulled over for if you're driving like an asshole. |
