richparker Samba Member
Joined: November 24, 2011 Posts: 6982 Location: Durango, CO
Posted: Thu Jan 29, 2015 8:10 am Post subject: Brake pressure switch, '68 only??? |
Last night on my way home my brake pedal begun to get soft. I just adjusted the brakes for our big road trip to Tucson this weekend, so I thought it was odd. Pulled over and checked the wheels and pan for fluid, nothing. Got home, pulled the pan and wouldn't you know the brake pressure switch was leaking . Part number 0343102008. I pulled it, inspected it, cleaned it and used some JB weld on it to no avail. Can't find it in the US. I did find a cross reference number on a UK site, which is 90161311500. I googled that number and found a Porsche supplier in Littleton, just outside Denver with it listed. I'm gonna call them this morning and see if they have it and if so can it be shipped today and next day aired to me.
Is there a work around for this switch?
Is this a '68 only part? I can't find it on any ACVW supply site but they are on the Porsche sites. Used in the 911 thru '74.
Thanks
Rich P. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51144 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Jan 29, 2015 8:31 am Post subject: |
Are we discussing the one in the middle that's a little lower down?, or the ones on each end a bit higher up? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16970 Location: San Diego, California
Posted: Thu Jan 29, 2015 8:46 am Post subject: |
Here's a pic of a 1968
_________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Thu Jan 29, 2015 8:49 am Post subject: |
Damn, if you are capable of noticing when the pedal is getting soft and the front or rear brakes aren't working well you can replace that switch with a plug (you'll have no dual circuit warning light), if you want the warning light eventually use the later 3 prong switches and do a little bit of rewiring down there. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22665 Location: NYC/Upstate/ROW
Posted: Thu Jan 29, 2015 8:57 am Post subject: |
...and, after checking with your lawyer, you can probably bleed the air out of the MC at the plug by starting it into the threads, then, with two-person method, spritzing fluid out onto your face below while you tighten it.
A careful test drive afterwards to see if you have air in your system, of course.
If your brake fluid is more than two years old, ignore this and replace it. _________________ .ssS! |
Posted: Thu Jan 29, 2015 8:59 am Post subject: |
busdaddy wrote: |
Damn, if you are capable of noticing when the pedal is getting soft and the front or rear brakes aren't working well you can replace that switch with a plug (you'll have no dual circuit warning light), if you want the warning light eventually use the later 3 prong switches and do a little bit of rewiring down there. |
What I am gathering here is that I can just plug the hole where the switch should go. Should I picktail the wires together? I'm in tune with my brakes and adjust them all the time.
Aeromech,
If that's a '68 then what do I have? Totally possible the PO changed the master cylinder out at some point. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Posted: Thu Jan 29, 2015 9:00 am Post subject: |
Would a three prong switch work? Just use two of the prongs. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Thu Jan 29, 2015 9:06 am Post subject: |
Aeromech,
Yep, and I still have that MC somewhere. That's the first bus I did the brake booster mod to so the original MC came out and a booster with a 1971 MC went in. I have no idea why yours looks different and I couldn't tell you which is correct. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
richparker wrote: |
busdaddy wrote: |
Aeromech,
If that's a '68 then what do I have? Totally possible the PO changed the master cylinder out at some point. |
You have demonstrated that the brake warning light is useless to those who are situationally aware to the beast that bears them.
Well done.
Just tape up the wires to keep clean until you find that switch or rewire. _________________ .ssS! |
Posted: Thu Jan 29, 2015 9:50 am Post subject: |
Happy to help.
Too bad you pulled the switch. Had you waited, you might have been able to get around bleeding the system. Now I'm afraid you'll need to. Finding a proper plug may prove harder than going to your local FLAPS and buying a three prong switch for $5 and just using it to plug the hole if just using two of its prongs won't work. Where's Telford when I need him? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12722 Location: on a bike ride somewhere
Posted: Thu Jan 29, 2015 9:55 am Post subject: |
The 68/69 brake years were really funky from VW; especially when you take POs into account, and 45 years of negligence.
From what I understand, there are three setups of non-powered MCs:
Double switch, two prongs each - basic brake lights with no warning light options. One switch for each circuit, front and rear.
Triple switch, two prongs each - same as above but with a third (smaller and leaky ) switch to monitor pressure difference between circuits and light-up your ejector seat button.
Double switch, three prongs - a combination of above switches; it has one switch for each circuit, and a third wire on each switch to compare pressure/voltage.
All of these are easily converted to other styles, like BD said a plug works, then you can use three-pring switches if you want your light back.
www.airschooled.com |
Having a custom plug made at the machine shop this afternoon. I understand that will have t bleed the brakes after it is installed. I already told the wife her assistance will be needed to pump the brakes.
I wonder if my bus has that MC because it was a tourist delivery bus. There are a few other odd items on the bus as well. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Posted: Thu Jan 29, 2015 9:59 am Post subject: |
richparker wrote: |
I wonder if my bus has that MC because it was a tourist delivery bus. There are a few other odd items on the bus as well. |
I'm just guessing but is it M10X1.0? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Brian Samba Moderator
Posted: Thu Jan 29, 2015 10:19 am Post subject: |
hmm, I'm curious as to what your vin is. Because if it's a nice early bay then not only are you going to have problems with the plugs but your rear drums are impossible to find.
I think my VW manual has a diagram of that MC and the cutoff date for it. Let me see if I can find it.
Edit: well, the MC you have is apparently used up until 219061567, so never mind that. From the diagram in the book, I wonder if you could just tap that entire cylinder and stick a bolt in it then use the three prong switches. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
Posted: Thu Jan 29, 2015 10:28 am Post subject: |
never mind about the rear then.
Airhead Jim wrote: |
211 501 615 A - Bus Mar 55-Aug 63
211 501 615 D - Bus 62-63 w/Big Axle Redux Boxes & Brakes (M216)
211 501 615 E - Bus 64-67
211 501 615 F - Bus Early 68 (to 2x8 109 823) (RAREST of the Rare)
211 501 615 G - Bus Late 68-70 (fr 2x8 109 824) |
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
