ajeambler Samba Member
Joined: January 29, 2015 Posts: 8 Location: United States
Posted: Thu Jan 29, 2015 9:38 am Post subject: New 66' bug Cross country trip |
Hello all,
I am new to this forum and the bug world though I have learned alot in the past couple days. I drove out from PA to California with 6 friends in a 1986 rv and sold the rv in California. On the last day of the trip my girlfriend and I decided to drive back across the country to PA and long story long I bought a 66' bug that is on a 67' chassis with a 1776cc motor. I have spent the last 3 days installing pushtube seals, valve adjustment, oil change, all new tins around the engine (it didn't have any), and replacing all the heater hoses. I also installed a scat short shifter, grant wheel, cigarette lighter port, and speakers along with redoing the back since it had no back seat. I've also checked all the obvious, brakes, wheel bearings, oil change.
I'm leaving on the trip today so a little late on asking but does anyone have any advice? Also mechanical advice/assistance could prove to be very helpful along the way![/img] |
Dynaflash Samba Member
Posted: Thu Jan 29, 2015 9:55 am Post subject: |
Please post pictures along the trip. Should be fun |
anthracitedub Samba Member
Posted: Thu Jan 29, 2015 3:16 pm Post subject: |
Only advice, don't try to drive as fast as the rest of the yahoos...just sit back and cruise. |
kirkpwomack Samba Member
Joined: February 05, 2011 Posts: 67 Location: Brookville, Indiana
Posted: Thu Jan 29, 2015 4:20 pm Post subject: |
I could have saved you some $$ and you could have bought mine on your way thru Indiana. |
KTPhil Samba Member
Posted: Thu Jan 29, 2015 5:45 pm Post subject: |
Search for threads on "what to take on a long trip" or such words. Lots of good and varied advice depending on the car, your tolerance for breakdowns, and insecurities. |
jensenflagg Samba Member
Joined: February 10, 2013 Posts: 104 Location: United States
Posted: Thu Jan 29, 2015 6:03 pm Post subject: |
Sounds like fun. Remember the obvious- check your oil every couple of gas stops until you know the consumption and bugs often go better then the stop... Have a spare fan belt and enjoy!
Keep us posted. |
gt1953 Samba Member
Posted: Thu Jan 29, 2015 6:55 pm Post subject: |
Take the back roads lots easier. Enjoy the ride, what to take would be the three "C's" cash, credit card, cell phone. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Thu Jan 29, 2015 7:21 pm Post subject: |
When I first read your title thought you meant "Cross Country" in a Beetle like the pioneer days or something...now that would be fun
On a serious note, if you're taking US 40 to US 44 (The New "Rt 66" ) or US 70 through the Saint Louis area, be sure to check here for member contacts, events and info...
http://www.gatewayvwclub.org/news.php
If the VW needs any simple work at all, you can bring it to where I live in St Charles, Mo. or if major where I work week days at a new car dealer in Maplewood, Mo.
There I can choose to work on whatever I want to and have full facility's.
Glad to be of any help if needed, so PM for phone numbers. _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
Posted: Fri Jan 30, 2015 1:08 pm Post subject: |
Thank you everyone for the advice and offers to help, its greatly appreciated. I've been cruising at around 60 and it seems to be pretty happy there. We made it to from San Francisco to Los Angles last night a 7 hour drive with only minor issues. Someone in the past had taped together wires from the alternator (updated from the generator) to the battery that started to give out. Luckily I caught the dash light coming on and was able to get it stopped before anything burned up.
I will try to take more/ better pictures of the bug later today. The motor home in the picture is the 86' I drove from Pennsylvania that I sold yesterday. |
Posted: Fri Jan 30, 2015 1:32 pm Post subject: |
Also I'm new to the forum and this might be categorized somewhere but I am hoping to find someone that knows carbs and could check the timing on the bug in the Los Angles area. Any suggestions/ideas/shops to recommend? |
61SNRF Samba Member
Posted: Fri Jan 30, 2015 7:39 pm Post subject: |
The only place I know of is a retail facility. Worked with Dave years ago and knew him as a honest and hard working guy with lots of experience, and still consider him a good friend to this day.
His shop's been there since the '80's, has great reviews and he's right off US 10 in Walnut on your presumed way to US 40.
If you do talk to him, please tell him Bruce from Rollings referred you, he will get a kick out of it...
http://www.daveslittlecarshop.com/ _________________ -Bruce
Posted: Sat Jan 31, 2015 6:41 pm Post subject: |
I have a question in regards to the timing. The engine has a degreed pulley installed and with the current settings the timing on the pulley is set to 28 degrees past TDC with the rotor pointing at the notch in the distributor. Does this make sense? From reading it sounds like it should be set at around 7 degrees ramping up to 28 degrees with the advance. I am in the Los Angeles and don't have access to a strobe unfortunately. |
KTPhil Samba Member
Posted: Sat Jan 31, 2015 7:06 pm Post subject: |
Where in L.A.? That covers a large area! Maybe someone can come over with a strobe.
Timing should be before TDC, not after, or maybe near TDC itself.
Maybe your distributor os clocked on the wrong drive gear tooth?
I'd check the points, and if new, set point gap to get dwell right, then recheck timing. |
61SNRF Samba Member
Posted: Sat Jan 31, 2015 8:26 pm Post subject: |
Wait a minute, in your opening statement, you said you checked everything, right?
Anyway, the notch in the distributor is not what you set the timing by, it's only there to get you in the ball park and let you know the engine in on #1, so if you're looking at that to set timing and then down at the pulley that is not going to be right.
Besides that, if the engine had been timed at 28* ATDC all this time, you probably wouldn't have made it as far as you have.
In fact it probably wouldn't even start or run.
Yes you set the timing statically when the rotor is pointing near the notch for #1, but most importantly for the points to open at about 7-10 degrees before TDC #1. _________________ -Bruce
shortride Samba Member
Joined: October 10, 2010 Posts: 1323 Location: Oklahoma
Posted: Wed Feb 04, 2015 11:58 am Post subject: |
So I've made it to bolder Colorado and still only relatively minor issues. I used an empi aluminum spring loaded push rod tube kit and the left side of the engine seals have remained leaky. Last night we stayed up until 2am pulled them all out and put in new seals, hopefully this round they seat a little better. The job could be easier if I wasn't on the side of the road on my aunts street in the snow. The good news is I think I have gotten the technique down a little better and the install was def cleaner with less abuse to the seals going in. The left front outer tie rod is on its way out so I am going to replace that today. Luckily my aunt in Bolder lives pretty close to a specialty VW shop called Nu Vintage so parts are available. Before I left LA I managed to borrow a strobe light to look at the timing. It appears to advance correctly from the 28 degree mark on the pulley so I am now thinking that someone just did something strange with the pulley install. Thanks everyone for the advice there. |
