Mr. Chuck Samba Member
Joined: December 20, 2014 Posts: 18 Location: Menifee
Posted: Thu Jan 29, 2015 9:38 pm Post subject: Runs great then stalls and slow cranking for a bit, help! |
Ok samba peeps. Here's my problem. 1970 bug 1600. It started off as a random miss, or stutter, real quick like, and this was at cruising speed mostly. At first I thought it was a fuel delivery issue, almost like you're running out of gas. Well, then the problem got worse, it started to stall. A couple times I would just restart it and drive off. Then after a couple of those I would try to restart but it wouldn't fire AT All. I made sure it was getting fuel. Then I noticed it would slowly crank sometimes immediately after the stall. If I waited a couple minutes it would crank over faster and faster but still not firing AT ALL. Now its gotten so bad that when it does start and when it's idling it will start to stall then continue running without me touching anything. Almost like you're pulling the coil wire off and back on real quick. Now I came home from work and it had sat all day, and when I went to start it it was slow cranking again. Then I tried a few more times and cranking went back to normal (faster) cranking. It finally started without giving it any fuel like it normally would then quickly missed a few times like above and stalled completely. If it wasn't for the slow cranking I would say coil or ignition. I haven't had time to look but, maybe a bad chassis ground or something, or starter solenoid short. But could that cause a stall after its running IDK! Help is much appreciated. |
Volks Wagen Samba Member
Joined: February 13, 2013 Posts: 2926 Location: Germany
Posted: Fri Jan 30, 2015 12:23 am Post subject: |
Points? _________________ 1973 1303 with AB-motor - sporadic
reconstruction as time permits, 1986 ex-Bundeswehr Doka - on the road again.
I'm definitely, probably, the worlds greatest lover.
Aithníonn ciaróg ciaróg eile. |
Posted: Fri Jan 30, 2015 7:51 pm Post subject: |
No points. |
volkswagen_bug Samba Member
Joined: November 04, 2008 Posts: 759 Location: Sumter, SC
Posted: Fri Jan 30, 2015 8:10 pm Post subject: |
Please provide more information on what you have. If you don't have points, what do you have? We need information to help you. _________________ 1968 Volkswagen Bug w/ 1600 Dual Port
"It’s better to give than to receive. Especially advice." -Mark Twain |
Posted: Fri Jan 30, 2015 9:39 pm Post subject: |
Single port 1600, mild cam, light polish on heads, electronic ignition in it when I bought it, so not sure what kind, generator, solex carb. It does have a kill switch, connected to the ground with a key. |
Posted: Fri Jan 30, 2015 9:42 pm Post subject: |
Oh and bosch coil
