VWTortuga336 Samba Member
Posted: Fri Jan 30, 2015 12:35 pm Post subject: Type IV 96mm Piston Identification? |
Looking on eBay for a set of 96mm pistons and cylinders for my Type IV motor and I saw this set:
http://www.ebay.com/itm/Porsche-VW-four-96...%3D251635106531
I asked if there were any marks inside the piston skirts and this is the answer I received from the seller:
"On one of the open boxes, inside the piston on either side of the shaft? there are four marks. Moving clockwise they are: the number 2, a circle with the letters TS inside, a diamond shape with the letters HJ inside, and finally the letter L. The other open box piston only has the number 2 visible, and part of the diamond shape. I do not want to open the other boxes. I was able to see the letters TS on the outside of the cylinder at the bottom of the fins. Hope this helps."
Anyone have any ideas as to what size engine these are for? Specifically, I'm turning my 2.0L into a 2056 - will these work? _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
