wellcraft Samba Member
Joined: September 12, 2014 Posts: 647 Location: Georgia
Posted: Fri Jan 30, 2015 7:48 pm Post subject: Going from 1600cc to 1776cc. |
What options are out there if I want to go from 1600 cc to 1776cc?
I would like it to be as healthy and reliable as possible as this is my daily driver. Just trying to get some more power. Mine is a 1999 mexican beetle so I don't know if that would make a difference as mine is fuel injected and has a computer, 02 sensor and all that sh@#.. whit the ac is a bit slower so I could benefit of the extra hp
I don't want to have to upgrade injectors or anything like that.
was told that I only need to swap pistons and thats it, no machining or anything, is this true?
I believe my car has around 40hp and I would like to get around 70hp, is this possible this way?
How much will this affect my mpg?
What kit would u guys recommend, post a link if possible as I'm not that familiar with the kits available.
Thanks in advance for any help. |
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Fri Jan 30, 2015 8:27 pm Post subject: Re: Going from 1600cc to 1776cc. |
wellcraft wrote: |
was told that I only need to swap pistons and thats it, no machining or anything, is this true? |
FALSE!!! 1776cc with stock stroke . . . 90.5mm pistons AND cylinders require machining to the case and heads!
That small increase in displacement is NOT going to give you 30 H.P.!
Probably have a small effect on M.P.G. _________________ Jesucristo es mi Seņor y Salvador!
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Fri Jan 30, 2015 8:31 pm Post subject: Re: Going from 1600cc to 1776cc. |
57BLITZ wrote: |
1776cc with stock stroke . . . 90.5mm pistons AND cylinders require machining to the case and heads! |
Yes, machining case and heads is required.
I run an 1835cc engine that except for single Weber carb and quiet exhaust, all the internals are stock (non-counterweighted crankshaft, stock cam, stock rebuilt heads - except for boring for the cylinders) and it runs great. Runs great since 1986.
My first 1835cc engine was similar, but the case cracked in 1986 from the way they machined them back in 1976. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Fri Jan 30, 2015 8:47 pm Post subject: |
Thanks guys. I'll leave my engine the way it is then. The engine feels great and strong so I don't want to mess with It.
Will definitely do it if when I need to rebuilt the engine.
If I want to shoot for +/- 70hp, what would I need to do to achieve it? |
Posted: Fri Jan 30, 2015 9:21 pm Post subject: |
wellcraft wrote: |
You would need to do modifications that probably would prevent it from passing an emissions inspection! _________________ Jesucristo es mi Seņor y Salvador! |
gt1953 Samba Member
Posted: Sat Jan 31, 2015 8:05 am Post subject: |
Keep your current engine and start collecting parts for the 70hp engine. My 1776cc has 60 hp to the ground on a dyno at 5500 feet. The engine offers spirited driving. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
67jason Samba Member
Joined: August 28, 2005 Posts: 4741 Location: behind my back feet - Pittsburg CA
Posted: Sat Jan 31, 2015 8:38 am Post subject: |
you can easily achieve 70 hp out of a 1600. heres one i had built.
as41 crase set up for full flow
69mm counter weighted crank
13lb flywheel
slr xv260 cam with 112 lobe centers, .418 lift (when assembled and measured came out to .420)
stock vw 1.1 rockers with swivel feet adjusters
new slr lifters
ported and polished stock vw heads - flow bench said heads flow at 127.45 cfm intake and 110.77 cfm exhuast and 7.6:1 cr
85.5 new cima/mahle pistons and cylinders, balanced.
rebuilt and balanced stock vw rods
GB oil pump and pump cover
40mm kadrons with 130 main jets and 55 idle jets on short manifolds, also match ported to the heads.
csp linkage
GB 1.5 quart oil sump
1 3/8 header with single quite pack
stock german doghouse and engine tin and t-stat
peak torque: 82.8 lb-ft @ 3900
peak hp: 70.8 bhp @ 5000
at whatever elevation phoenix az is. _________________ 67 bug x3
67 ghia
64 bug |
VERTED71 Samba Member
Posted: Sat Jan 31, 2015 9:51 am Post subject: |
gt1953 wrote: |
Keep your current engine and start collecting parts for the 70hp engine. My 1776cc has 60 hp to the ground on a dyno at 5500 feet. The engine offers spirited driving. |
x2!..if your current engine is running well, KEEP IT. Build another engine, this way if anything goes wrong with the 1776 or 1835, you can quickly swap it out. I made the mistake back in early 2003 when I removed a completely stock running engine and sold it to build a 1903...long story short, wish I kept the original 1600. The cost and up keep negated the power gains that I received.
Good luck. _________________ Aloha'z and have a great day!
71 Super Beetle Vert
15x4.5 Front
15x6.5 Rear
155/60R15 74T tires FRONT
205/65/15 tires REAR
1600 Dual Port
Progessive Carb
Electronic Ignition
Tri Mil "hotdog" exhaust |
