wellcraft Samba Member
Joined: September 12, 2014 Posts: 647 Location: Georgia
Posted: Sat Jan 31, 2015 7:04 pm Post subject: Lowered swingaxle beetle question. |
My mexi beetle was lowered by the po about 2.5" and today a friend of mine was driving behind me and old me the drivers side has more camber than the passenger side. When I came home I parked the car in a flat area and measured the rear fenders and found out the drivers side measure from the ground to the fender 23" and the pass side 24".
I need to correct this as I have to get new tires soon. I will like to go back k to stock but unfortunately the po installed drop spindles in the front and I don't have the stock ones. So I will just try to adjust the rear and maybe try to go a bit higher without looking bad compare with the front.
This would be my first time doing this and have watched some videos on how to do it And have a question, how do I now how low it would be when adjusting, should I just move one tooth?
What would be the max to start having camber issues with my new tires? |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Sun Feb 01, 2015 3:05 pm Post subject: |
Use the chart on this link. I think its a couple posts down.
http://www.thesamba.com/vw/forum/viewtopic.php?t=237102
When you pull things apart, you NEED to measure the current angle and I would suspect that one side is set diffently. And be very careful doing this job. You can get hurt if you screw up. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Sun Feb 01, 2015 5:18 pm Post subject: |
Thanks yuys. This would be the first time I do this. I do have an angle finder. Is there a detail instruction on how to do it as I don't have the Bentley manual. I do have the cheap one from autozone.
I read before t hat I must be very careful when workin with this, which I will have, would like to find a detail instruction on how to do it.
I found a video of a guy doing it but it didn't have any tension in the spring and it looks verybsimple. I remember seeing that the part where the splines are is numbered, I'm I correct?
When does the plate has tension in it? I ask because of that video, I would assume that at some point it should have tension and that's why I believe I should be very careful.
Thanks again. |
Posted: Sun Feb 01, 2015 6:04 pm Post subject: |
How do I know of what's the stock height when looking at the splines, is there a factory marking, what shape?
On a video I just saw they say the rule of thumb is 1 spline = 1 inch, is this true? |
Aussiebug Samba Member
Joined: June 03, 2002 Posts: 2162 Location: Adelaide Australia
Posted: Sun Feb 01, 2015 11:08 pm Post subject: |
wellcraft wrote: |
www.vw-resource.com/rearaxle.html _________________ Rob
Rob and Dave's aircooled VW pages
Repairs and maintenance for the home mechanic
http://www.vw-resource.com |
Posted: Mon Feb 02, 2015 5:38 am Post subject: |
Rob has you covered - without reading his link, I dont know if he has the variations on how to get the plates on and off. Would try a search on here in casethey arent there, but I would be surprised if its not covered. The one trick I use (and he probably covers this) is to get at least 2 new bolts for the spring plates 3/4" or so longer than stock. You use these when you are putting the end covers on initially to get them pulled in enough to get the factory bolts started. Then you take the long ones out and put the factory ones back in.
I have a small digital level and one of those cheap ($ angle finders. Both work equally well.
If you have a local VW club, see if anyone has the actual tool for removing and installing the spring plates that you can borrow. I have one and it makes life MUCH easier and safer. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Mon Feb 23, 2015 1:21 pm Post subject: |
Ok guys , I'm working on this today and have one of the spring plates off with out any problem. I'm reading through some information I have but can't understand the part were it say for example 20 degrees 20 minutes, what do they refer to minutes?
Can I just go buy the angle in the angle finder?
Also, how do I know what would be the correct angle I would say to get the car back to stock height?
Thanks. |
Posted: Mon Feb 23, 2015 4:02 pm Post subject: |
I just took the angles and I'm not getting this, not sure what angle I need to get back to stock height so I will post the info I have for the experts.
Driver side
DOOR SILL angle was about 5.5 degrees with the angler finder and with a digital one was 5.2 degrees
SPRING PLATE angle with the angle finder was 13 degrees and the digital one was 13.6 degrees
Passenger side
DOOR SILL angle was 5 degrees with the angle finder and with the digital one was 5.6 degrees.
SPRING PLATE angle was 13 degrees with the angle finder and with the digital one 13.2 degrees.
If I move 1 spline up outer it goes to 5 degrees and if I go 1 spline down outer it goes to 20 degrees.
If i move the spring plate down whatever splines I need, would the car be higher or the opposite?
When I measured the car at rest it measured 23" drivers side from ground to edge of the fender and passenger side was 23 3/4 but another day the measurement on the pass side was 24". I know there is a difference in height and the dr side looks more squad compared to the passenger side. |
Posted: Mon Feb 23, 2015 5:08 pm Post subject: |
UPDATE
I measured everything again but using the regular angle finder so I guess we can forget of the previous post.
DRIVERS SIDE
DOOR SILL angle was about 5 degrees with the angler finder.
SPRING PLATE angle with the angle finder was 13 degrees.
I measured the spring plate with the floor at the actual position and it measured 10 1/8", now if I go 1 spline up the it goes from 10 1/8" to 12 9/16" and 5 degrees.
If I go down 1 spline then it goes from 10 1/8" to 7 3/4" and 21 degrees.
PASSENGER SIDE
I measured the spring plate with the floor at the actual position and it measured 10", now if I go 1 spline up the it goes from 10" to 12.5" and 5 degrees.
So its a 8 degrees difference going up or down either side, my guess is that I should go 1 spline down and I should be a stock height , M I right?
If I'm right, how do I address the difference when I measured the car when it was in the ground, there was 3/4" difference between dr side and pass side. |
Posted: Mon Feb 23, 2015 6:07 pm Post subject: |
You dont care at all about the measured distance - its all about the angles. If your door sill is 5 degrees and the spring plate is at 13, then the question is this....are they the same direction or opposite directions? I bet they are opposites. This would mean you need to add the two angles. You are at 18 degrees. Makes sense?
Now you should have the tables that show what one click outside does and one inside does. FYI 1 outside clicks changes it around 2" if I remember correctly. Its kind of a pain to figure out which way and how many. What I do before I start adjusting is make a witness mark on the end of the spring so I know what my starting point was.
And the minutes - (28 degrees 30 minutes) is 28.5 degrees. 60 minutes = 1 degree. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Mon Feb 23, 2015 6:11 pm Post subject: |
What do u mean by opposite direction?
Sorry for the ignorance but even thou I been reading I can't understand much about th3e angle stuff, first time working with angles
andk5591 wrote: |
And the minutes - (28 degrees 30 minutes) is 28.5 degrees. 60 minutes = 1 degree. |
EVfun Samba Member
Posted: Mon Feb 23, 2015 6:31 pm Post subject: |
That chart gives the spring plate angle change, not the actual spring plate angle. The other thing needed for someone to work back toward stock is what the stock angle of the spring plate should be. A little research shows that is 17 degrees 30 minutes for short axle Bugs (stock through 1966) and 20 degrees 50 minutes for long axle and IRS Bugs (1967 and newer.) I suspect what most people think of as stock is actually slightly less (perhaps 1 degree) as there has been a lot of years for some sag to take place. _________________
Wildthings wrote: |
Dougy Dee Samba Member
Joined: August 21, 2004 Posts: 1669 Location: Niagara Region, CANADA
Posted: Mon Feb 23, 2015 6:44 pm Post subject: |
I had one in the shop a while back with similar situation. Drop spindles, screwed up rear camber... Turns out it had stock BJ shocks on the front that were bottoming out on one side making the rear camber uneven...
So be careful...not all drop spindles are made correctly. The correct short shocks may be your solution. |
Posted: Mon Feb 23, 2015 6:51 pm Post subject: |
Dougy Dee wrote: |
I don't know what drop spindles the po put in there, I will be going back to stock height front and rear, I replaced the shocks when I bout the car like 5 month ago and went with kyb excel black, the old ones were in pretty bad shape. |
Posted: Mon Feb 23, 2015 6:54 pm Post subject: |
when u referred to opposite direction is when the swing plate is pointing down instead of level or up like the door sills?
andk5591 wrote: |
modok Samba Member
Posted: Mon Feb 23, 2015 7:12 pm Post subject: |
There are 40 inner splines and 44 outer splines, so you can adjust it 8.2 degrees or 9 at a time, so that means you can fine tune to within one degree by moving inner and outer splines.
Move it one inner spline in the direction you want to go, then move back one outer, and you have moved it about 1 degree.
If the car appears to sit lower on one side then I'd go ahead and set one side 1 degree higher than the other, you know, "fudge" it a little in the desired direction.
To see if the car sits level you should go off the front and rear torsion housings. Fenders vary, and even when new the bodies were not 100% accurate.
Deep in the service manuals there is specs for the angle it is supposed to be. I would guess somewhere between 19 and 22. A lot of the IRS cars were set at 19 but being a 68, it might be 21, 22.....something like that. |
Posted: Mon Feb 23, 2015 7:19 pm Post subject: |
modok wrote: |
Need to check the manual I have to see if it has the specs, I have the cheap one (hanes).
But my question is, if I move the swing plates down whatever clicks I need, would it be higher or lower when resting?
What I believe is that if I move the swing plate up the car would be lower and if I move the swing plate down the car would be higher when done and resting on the ground, is that right? |
