joemama Samba Member
Joined: February 09, 2006 Posts: 1636 Location: La Crescenta, California
Posted: Sat Jan 31, 2015 7:40 pm Post subject: dual to single vacuum advance? |
Can you convert a bosh dual vacuum advance distributor to single vacuum advance? Is it just a matter of changing the can? |
mcdragracer Samba Member
Posted: Tue Feb 03, 2015 2:35 am Post subject: |
What would be the purpose? For starters the vacuum units aren't interchangeable between the distributors, the single from what I remember has a spring that pulls the advancement plate back when at idle, what pulls the advancement plate back on the dual vacuum is the bigger spigot port on the dual vacuum unit. |
Marv [UK] Samba Member
Posted: Tue Feb 03, 2015 3:02 am Post subject: Re: dual to single vacuum advance? |
joemama wrote: |
Yes, your dual vacuum dual advance distributor has vacuum advance and mechanical advance and vacuum retard, hence dual vacuum, dual advance.
Simply disconnect the vacuum retard line and plug the hose from the carb with a screw. Your timing will then not be retarded to 5 degrees ATDC and run like hot crap. _________________ The opinion of the author as expressed does not always reflect that of the author nor does he extend any apologies or assume any liability or responsibility for its content or lack thereof or for any lack of humour of the reader of any content at all, anywhere, ever. The reader agrees to all risk by reading it and is advised that any ‘issue’ is theirs alone as they chose to read it. |
HRVW Samba Member
Joined: May 01, 2011 Posts: 2531 Location: Rosarito, Mexico
Posted: Tue Feb 03, 2015 3:26 am Post subject: |
Assume the dist is a single vac and adjust timing to the 7.5 mark. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76912 Location: Sneaking up behind you
Posted: Tue Feb 03, 2015 4:46 am Post subject: Re: dual to single vacuum advance? |
joemama wrote: |
Yes, but mixing and matching the cans can give unpredictable results.
I would just disconnect the vacuum retard. _________________ Glenn
Member #1009
#BlueSquare |
