TheGreenVW Samba Member
Posted: Mon Sep 28, 2015 6:08 pm Post subject: |
With the piston style shift knob
dawerks Samba Member
Posted: Fri Oct 02, 2015 8:21 am Post subject: |
Love the build and the shifter location! _________________ "There is only one sin; disconnection from self." |
Posted: Fri Oct 02, 2015 10:42 am Post subject: |
dawerks wrote: |
Love the build and the shifter location! |
Thanks!
I decided to make a modification to the shifter before I re-install it. The Powerglide transmission that I am using has a transbrake and a manual valvebady. That said, I will be shifting back and forth between 1st and 2nd gear a lot. The shifter, in stock form, allows you to slip it from 2nd to neutral without depressing the shift button, as most shifters do. However, to get it back in to 2nd (Drive) you must depress the button. I can see winding up in neutral by accident, often, so I drilled and tapped the shift gate to create a neutral lock out.
Machined the tip of a 10-24 grade 8 bolt
and affixed it to create the lock out.
The shifter and bracket are ready to go back in.
My Projects are here!
https://www.youtube.com/user/TheGreenVW/playlists |
Booky Samba Member
Posted: Sun Oct 25, 2015 12:27 pm Post subject: Build |
Please do not stop posting I like your build. Build it the way you want to the do not listen to the naa sayers. |
Posted: Sun Oct 25, 2015 3:28 pm Post subject: Re: Build |
Booky wrote: |
I am still at it…….
...just slowing down a bit to get the good V8 (400 hp also) in my Daihatsu Hijet Micro Truck so that I can continue driving it!
Videos here!
http://www.BenModified.com
Should be back to the normal pace with the Single Cab in a few days!
Thanks for the encouragement! |
HALS Samba Member
Joined: November 26, 2008 Posts: 120 Location: Valley Srings cal
Posted: Sun Oct 25, 2015 4:00 pm Post subject: Re: Build |
Booky wrote: |
YAHOO ... me to .... glad ta see your back .!!!! _________________ "Leave it to girls to take all the fun out of sex discrimination." |
Posted: Mon Oct 26, 2015 3:47 pm Post subject: Re: Build |
HALS wrote: |
Booky wrote: |
YAHOO ... me to .... glad ta see your back .!!!! |
Thanks! Here is todays progress
Installed oil pressure and water temperature sending units
Plug wires
Heater hose fittings/hoses/shut off valves
Carb studs
Engine is ready for fluids.
brettsvw Samba Member
Joined: November 22, 2007 Posts: 2145 Location: Florida
Posted: Mon Oct 26, 2015 3:52 pm Post subject: |
brettsvw wrote: |
Your singlecab will get a lot of attention when finished, Crazy fab work. |
Thanks!
Thanks again for the vents |
Posted: Tue Nov 03, 2015 3:54 pm Post subject: Video clip |
I managed to get a few things done on the Single Cab Street Rod today. I pulled the distributor and spun the oil pump to prime the engine. Also started installing the carb but had to order a few parts to finish the job. I started up the ZZ5 crate motor in Daihatsu HiJet which is the same type that is installed in the Single Cab. Here is a video clip of it firing up for the first time if you want to hear what it sounds like!
http://www.facebook.com/BenModified |
daanbc Samba Member
Posted: Tue Nov 03, 2015 8:51 pm Post subject: |
SIC! In a good way…. |
Posted: Sat Nov 07, 2015 6:35 pm Post subject: |
Wiring progress. Making my way from the back to the front.
Posted: Tue Nov 17, 2015 6:38 pm Post subject: Re: 1961 400 Hp Single Cab Street Rod Build |
Took a break from the wiring today to finish up all the welding near the empty gas tank. Welded in support frame work for removable body panels. Still have more to go. Just want to be able to put gas in the tank when the wiring is finished so that I can fire it up
Bakerby Samba Member
Posted: Wed Nov 18, 2015 11:27 am Post subject: Re: 1961 400 Hp Single Cab Street Rod Build |
Love both trucks, keep the updates coming |
Posted: Sun Nov 22, 2015 4:22 pm Post subject: Re: 1961 400 Hp Single Cab Street Rod Build |
Bakerby wrote: |
Thanks!
I finished up the wiring harness for the Cab today. Plan to install it and finish up the wiring this week.
Posted: Sat Nov 28, 2015 11:24 am Post subject: Re: 1961 400 Hp Single Cab Street Rod Build |
Got something done on several things today.
Routed the negative battery cable in conduit under the cab, but ran out of clamps. The wiring is mostly complete at this point!
Stripped the original seat frames of what was left of seat covers. Went over everything with a wire wheel on an angle grinder and sprayed them with some rusty metal primer.
Rough cut some sheet metal to fill in the inside of the rear fenders. Going to roll some beads into them and then weld in. This is the last of the welding that needs to be done before I can put gas in the tank.
Posted: Mon Dec 07, 2015 5:17 pm Post subject: Re: 1961 400 Hp Single Cab Street Rod Build |
The wiring harness is done and installed. Hope to test it tomorrow as well as fix a few imperfections in the steering wheel.
http://www.BenModified.com |
