casamagana Samba Member
Joined: February 21, 2009 Posts: 81 Location: West Covina, CA
Posted: Sun Feb 01, 2015 11:09 pm Post subject: 1978 Champagne Edition II Super Beetle |
This will be my first time starting a vehicle thread. Hope you all enjoy the pictures and comments on our latest addition to the family. These are some of the first photos we have as we just brought the car home today.
The initial plan is do the safety items first-inspect brakes, replace tires (they are 25 years old) then drive it a little to see what we've got here. So far the car runs, shifts, and brakes pretty good during the pre-purchase road test.
The car looks complete to me but I'm no expert. As this is our first injected Beetle and first Super, any comments are welcome and appreciated. _________________ 1966 Bug
1978 Super Beetle Convertible
allsidius Samba Member
Joined: February 02, 2010 Posts: 1475 Location: Norway
Posted: Mon Feb 02, 2015 5:52 am Post subject: |
The car would look so much better if you had the wheels detailed, while you are at it replacing the tires. This year vert normally came with 165 SR 15 tires with a thin white stripe. While the tires are off, why not take them to a painter, sandblast and repaint the correct silver. Dark cars look so sad with dark rims. Be warned that the late supers do not use the most common 4 bolt rims, if you think about putting aftermarket wheels on it. Due to difference in offset, the "old style" four bolted wheel make the rubbers stick out, especially at the front, and it doesn't look nice. There is a little code on your wheels, pressed into the steel, which says ET 36 or something, make sure that the replacement for that right side rear wheel has the same ET.
The top needs new tension wires, along the edges over the windows there are one wire on each side, that pull the outer skin tight when locking down the top. These seem to have stretched, or maybe even broken. They are quite cheap and I think they may be replaced without too much hassle.
Otherwise, these cars look really good in their original color if presented properly, I guess you are in for a repaint. Be aware that the aluminium chrome strip around the windshield cannot be bought new, so if you replace that rubber strip, take care not to damage the chrome strip when it is transferred to the new rubber. It can be polished to a bright sheen with a little elbow grease. If you look at most restored super verts, it is missing the chrome strip, since it is not reproduced. If by any chance there is a plastic coat surrounding the chrome, it may be bought by the yard at a VW parts outlet, but you need to look in the Golf/Rabbit Mk I parts bin.
_________________ 1973 1303S w sunroof Click to view image
1978 1303 convertible (sold)Click to view image
1966 1300 RIPClick to view image
BenJAMin Samba Member
Joined: February 01, 2004 Posts: 461 Location: Michigan
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Mon Feb 02, 2015 9:57 am Post subject: |
One of my all-time favorite beetle colors- nice car. _________________
EverettB wrote: |
FU#5 |
Posted: Mon Feb 02, 2015 10:31 am Post subject: |
That is actually a very good tip. It has been a few years since I struggled with this on my vert, the preshaped aluminium trim could not be sourced in 1998, so the plastic trim as shown by Chucks was my choice.
From the introduction, the super beetle had an aluminium profile chrome strip, but as the Golf/rabbit came onto the market, VW sought to save cost by introducing parts that interchanged between models. The aluminium strip has to be pre-shaped by special tooling, while the plastic strip of the Golf can be shaped into any form. I am not sure when they changed on the super Beetle, but the plastic strip looks every bit as good and does not corrode. _________________ 1973 1303S w sunroof Click to view image
irvanm Samba Member
Joined: January 09, 2008 Posts: 609 Location: Lawrence, Kansas
Posted: Mon Feb 02, 2015 2:15 pm Post subject: |
Super car, I have found myself coveting a late model Beetle convertible like yours. Congratulations on a really nice find, looks like you're going to have a lot of fun. |
Dwayne1m Samba Member
Joined: December 31, 2011 Posts: 3538 Location: Pennsylvania
Posted: Mon Feb 02, 2015 10:13 pm Post subject: Wheels |
Thanks for all the great tips. Thanks allsidius for the picture. I was planning on black wall tires but I've reconsidered. The white walls look very good with the white interior. I found my wheels are 4 1/2 J 15, 4/78, ET 41. No real work today but here are some pictures of one.
We'll keep these wheels. Now to find a local sand blaster. Anyone have a tire recommendation? _________________ 1966 Bug
1978 Super Beetle Convertible |
Posted: Wed Feb 04, 2015 11:26 pm Post subject: |
Small update today. Appointments set for Sat. to have tires removed and Monday to have the 4 road wheels sandblasted in preparation for paint. Ordered the BFG thin whitewalls. _________________ 1966 Bug
VWCOOL Samba Member
Joined: June 02, 2006 Posts: 1821 Location: Down under
Posted: Thu Feb 05, 2015 6:37 am Post subject: |
Lovely project car! |
Posted: Thu Feb 05, 2015 2:54 pm Post subject: |
casamagana wrote: |
Small update today. Appointments set for Sat. to have tires removed and Monday to have the 4 road wheels sandblasted in preparation for paint. Ordered the BFG thin whitewalls. |
Good choice. Thin whitewalls are the way to go.
Posted: Sun Feb 08, 2015 2:13 pm Post subject: |
Quick question, does anyone know what the spare steel wheel looks like for a 1978 Super? I ask because I found a date code of 4/66, F, 4J15 on mine. I'm thinking this is off of a 1967 Beetle. Also, its a black and white wheel. _________________ 1966 Bug
jhicken Samba Member
Joined: October 24, 2003 Posts: 9466 Location: Fallbrook, CA
Posted: Sun Feb 08, 2015 2:44 pm Post subject: |
Congratulations on your new ride, treat it right and it'll provide you years of joy.
Unless the wheel you are looking at is a wide five wheel, most likely the date code says 4/68, That would mean it's from a '68 Beetle which a black and white wheel would be standard. Originally your spare would should have been a sport rim.
Speaking of your rims, consider powder coating, it's more durable than paint and will be the last time you'll ever need to think about about the wheels again. I powder coated my rims 20 years ago and a little squirt of windex and they look as good as new. It's more pricey, but worth it.
I've got a '79 vert that I've owned since '83. Dump a pint of injector cleaner in every time you change the oil and you'll keep the injectors very happy. Also consider replacing all the soft fuel lines. The FI system is pressurized so when a line breaks, it can get messy. GermanSupply.com sells pre-cut kits with the proper German fuel lines and instructions.
Hopefully you keep the original color, the peach metallic is relatively rare in comparison to the other colors offered. Also, you choice of the BFG 3/4" white walls is a good one, they will look great on your car. Here's a shot of my '79 with the BFG white walls on it.
-jeffrey _________________ Der Kleiner Kampfwagens |
hitest Samba Member
Posted: Sun Feb 08, 2015 4:25 pm Post subject: |
casamagana wrote: |
Quick question, does anyone know what the spare steel wheel looks like for a 1978 Super? I ask because I found a date code of 4/66, F, 4J15 on mine. I'm thinking this is off of a 1967 Beetle. Also, its a black and white wheel. |
This sounds more like a type 3 wheel to me- too early for 4 lugs. Your spare should be identical to the others- as beetle manuals always recommended a 5-wheel rotation (like that ever really happened). _________________
EverettB wrote: |
FU#5 |
Posted: Sun Feb 08, 2015 4:52 pm Post subject: |
Thanks for the information. Time to look for another sport wheel.
Yes, it will stay the original color. The gas tank/spare tire well, under hood, and under dash paint is perfect and original. I intend only an exterior re-finish in order to preserve as much of the original paint as I can.
I spent time cleaning the interior today. Pics of paint label and rear seat labels in a little while. _________________ 1966 Bug
Posted: Sun Feb 08, 2015 11:15 pm Post subject: |
A few pics from today's cleaning session.
A trip to the sand blaster for the wheels in the morning. Then, need to order up a muffler and an egr filter. _________________ 1966 Bug
Posted: Mon Feb 09, 2015 1:28 am Post subject: |
Wow this is one sweet convertible, I never saw an unrestored under the back seat area as good as this! You are saving yourself a lot of money, and keeping the value of the car, by staying with the original color, but I guess it will need a repaint. No way of treating that peeling clear coat, which was typical for 70s metallic colors. Some cars started peeling in just a couple of years, as soon as the warranty was expired. Not just VWs, of course.
An interesting thread to follow, keep the pics coming! _________________ 1973 1303S w sunroof Click to view image
