Batwing resto
veskovici
veskovici is offline
PostPosted: Tue Feb 03, 2015 1:52 pm    Post subject: Batwing resto Reply with quote
Ok, I did this before but back then my batwing was much better shape. this was submerged in the oil and dirt at least 30 years and that is face down. There was even horn button on it , but only i was able to salvage is metal button ring.
This started as joke as i didn't had any illusion that it might actually work ( i was thinking to hang it as wall art) but as I progressed i realized that this silicone is VERY good for purpose.
Pictures are crap, at least first ones, sorry.
Now, first I removed steering column and easy detached remaining parts of the puzzle Smile
what remained was crappy rusted wire. I removed all chips rust and cleaned what was rest of it, then used "Wurth" rust converter on it.
This way i learned that batwing şoft material is definitely a rubber. So I used hard bonding silicone to attach puzzle parts back on wheel wire.
I can strongly recommend to all that need right material to fill hair cracks on the batwing to use this or similar kind of silicone because it is very strong bonding and filling material but rubberish (400% stretching ) so it definitely wont crack ever.
This is only to be used to fill cracks because it cannot be sanded . I have to think best solution to use to sculptor missing parts.
More pictures as i progress.
Oval 1954
Barndoor1954
Doubledoorsunroof
Bruce
Bruce is offline
PostPosted: Tue Feb 03, 2015 8:08 pm    Post subject: Reply with quote
Don't you think it would be better if you sandblasted the core first?
veskovici
PostPosted: Wed Feb 04, 2015 2:30 am    Post subject: Reply with quote
Not necessary. It would be nice though.
I cleaned it with wire brush on grinder , so there was no rust on it ( there is a two pictures -one while removing soft parts and rust and another after cleaning and Wurth rust converter application).
And it started as a joke anyway Wink
Oval 1954
Barndoor1954
Doubledoorsunroof
beetlekey
beetlekey is offline
PostPosted: Wed Feb 04, 2015 4:12 am    Post subject: Reply with quote
for sure and the cracs will come thrue the paint. I think it is a dead born child. Crying or Very sad
Hebmüller 581
1953 oval Typ 11G metalblue
1966 1300
If you are searching for vintage keys, look here:
https://www.facebook.com/WagenmanufakturHO
veskovici
PostPosted: Wed Feb 04, 2015 10:56 am    Post subject: Reply with quote
Not born yet. Anyway it is a very harsh diagnose -dead born!! I mean it will last at least as all other solutions so why do you think so? I disagree.
Why? because as I understand (using logic not seen in practice) bondo will crack as different materials will react different in temperature oscillations, but this is very strong bonding sealant and it can stretch up to 400%. so why it will crack?
Oval 1954
Barndoor1954
Doubledoorsunroof
pastellgreen
pastellgreen is offline
PostPosted: Thu Feb 05, 2015 4:03 am    Post subject: Reply with quote
He does not mean it will crack. He means, you will see the places of fracture through the paint (provided that you plan to paint it).
coolparts
coolparts is offline
PostPosted: Thu Feb 05, 2015 10:01 am    Post subject: Reply with quote
your pissing in the wind. send it to Koch to be recast
veskovici
PostPosted: Fri Feb 06, 2015 12:57 am    Post subject: Reply with quote
Nice words , thanks, so let see what will come out.
Oval 1954
Barndoor1954
Doubledoorsunroof
Steve22
Steve22 is offline
PostPosted: Fri Feb 06, 2015 9:36 am    Post subject: Reply with quote
interesting project, let's see what happens...
'65 Karmann Ghia 'vert
'73 Super Beetle
'59 Beetle ragtop
'73 Sunroof Transporter
eurodub
eurodub is offline
PostPosted: Fri Feb 06, 2015 10:57 am    Post subject: Reply with quote
if it cracks again it can be used as wall art.
the only thing i'm concerned about is grabbing it firm at critical times.. not to end up with pieces in hand. and of course, safety.
any saved old part is worth the work if done right.
1960 1200 model 117 deluxe ragtop
1974 T2 Westfalia Campmobile
1976 MK1 Golf
ZENVWDRIVER
ZENVWDRIVER is offline
PostPosted: Fri Feb 06, 2015 1:23 pm    Post subject: Reply with quote
Sweet...more than one way to approach everything... looks great!
5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK
splitjunkie
splitjunkie is offline
PostPosted: Sat Feb 07, 2015 9:55 am    Post subject: Reply with quote
If you are going to use it without completely restoring it it will probably be fine. The thing about rust converters is that they don't really work all that well under a finished surface. They slow the rust down but it will still grow and that is what will eventually pop the pieces off. I would have had it sand blasted first to make sure every bit of the rust was gone then painted it with a rust inhibiting primer.
Chris
veskovici
PostPosted: Mon Feb 16, 2015 3:16 pm    Post subject: Reply with quote
Time to move on.
Continued with 2component epoxy putty, brand is BISON and it is called epoxy repair . This batwing will come to life at the end, and who would thought that at the beginning? Me not.
Putty is clay like and it hardens in 5 minutes .
Very easy for sanding and it fills nice.
I also have horn button base, spring and (not so) chrome ring , also have push button somewhere. Thinking how to fix missing base ring.
Oval 1954
Barndoor1954
Doubledoorsunroof
rlmartinez
rlmartinez is offline
PostPosted: Mon Feb 16, 2015 4:05 pm    Post subject: Reply with quote
Nice work so far Applause can't wait to see this complete.
54 Bug
56 convertible
veskovici
PostPosted: Wed Feb 18, 2015 12:21 pm    Post subject: Reply with quote
First hand is done, now fine tuning.
Oval 1954
Barndoor1954
Doubledoorsunroof
veskovici
PostPosted: Thu Mar 26, 2015 3:28 pm    Post subject: Reply with quote
Oval 1954
Barndoor1954
Doubledoorsunroof
Steve22
Steve22 is offline
PostPosted: Thu Mar 26, 2015 4:32 pm    Post subject: Reply with quote
nicely done! a good coat of ivory on it and it is ready for the wall.
'73 Super Beetle
'59 Beetle ragtop
veskovici
PostPosted: Fri Mar 27, 2015 2:33 am    Post subject: Reply with quote
ha ha thank you ..
Oval 1954
Barndoor1954
Doubledoorsunroof
eurodub
eurodub is offline
PostPosted: Fri Mar 27, 2015 11:13 am    Post subject: Reply with quote
i have the perfect split dash for it... Cool
1976 MK1 Golf
