Jzsquared Samba Member
Joined: August 16, 2014 Posts: 218 Location: West of Chicago, IL
Posted: Tue Feb 03, 2015 6:17 pm Post subject: Removing brake light button |
So I want to add a few gauges to my car but the brake light button is in the way. What does this even do ? Does it it just tell me if I loose brake pressure ?
I rewired my car this winter so I was thinking of just leaving it connected behind the dash so I can install gauges in that area. Any reason why I wouldn't want to do this ?
This is what I mean when I say brake button not sure what the correct term is
and yes that's just paint to look like wood grain |
GI Joe Samba Member
Joined: April 28, 2005 Posts: 2012 Location: Athens, TN
Posted: Tue Feb 03, 2015 6:22 pm Post subject: |
It Is a warning light, in the case either brake light switch doesn't function(in other words front or rear brake circuit is Not functioning... ).. Or at least that's how I understand it.
I'd say you can relocate it to another spot on the dash, to have it provide early warning to you, as it was intended..
I moved mine when I did gauges... There will be room.
And Great paint work there for the Faux wood!! I figured it was vinyl! _________________ '74 Thing, "Our Thing"....
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...p;start=60
'71 Beetle RPU
http://www.thesamba.com/vw/forum/viewtopic.php?p=8080337#8080337
www.NLEOMF.com
Respect, Honor, Remember |
Posted: Tue Feb 03, 2015 6:34 pm Post subject: |
Good idea to just move it I'll go that route |
liken127 Samba Member
Joined: June 27, 2013 Posts: 102 Location: Upland Ca.
Posted: Sat Feb 07, 2015 7:46 pm Post subject: |
GI Joe, that's a great looking dash! Looks like a tack, amp. and oil pres.
I was thinking oil temp also, but not sure if there is room. is the tack helpful?
was thinking not using.
Thanks |
GI Joe Samba Member
Posted: Sun Feb 08, 2015 8:19 pm Post subject: |
I see you moved the hazard to the left side of the steering wheel. Mine has a plugged hole right there. Any chance do you remember if the hazard fit in the hole without modification? |
GI Joe Samba Member
mondshine Samba Member
Joined: October 27, 2006 Posts: 2765 Location: The World's Motor Capital
Posted: Sun Feb 08, 2015 8:30 pm Post subject: |
It's easy enough to re-create the little dimple adjacent to the hole, which keeps the body of the switch from rotating, once the trim bezel is tightened.
I think the hazard switch body has 4 grooves (allowing 4 different possibilities for the little dimple) so the switch body can be mounted at "3-6-9-12 o'clock".
Here's a photo of a dash with almost everything re-located:
Good luck, Mondshine |
GI Joe Samba Member
Posted: Sun Feb 08, 2015 9:04 pm Post subject: |
Joe-
I plan to see you in Dayton, July 24 |
GI Joe Samba Member
Posted: Mon Feb 09, 2015 7:54 pm Post subject: |
Mondshine, That is also a great looking dash! Wow do I have a lot of work
ahead of me, to be ready by summer! |
Posted: Sat Feb 14, 2015 2:51 pm Post subject: |
Ok GIJoe I guess your dash inspired me to put my 3 gauges on the right side. Only thing is I damaged the paint enough that I had to redo the finish. Decided to go back to plain so I had the parts powder coated.
GI Joe Samba Member
Posted: Sat Feb 14, 2015 4:34 pm Post subject: |
Looks a little like this
2010 VW Beetle Gecko Green
With the rims
Got pissed off at new new SVDA being way off so I bought me a crank fire
gathering parts to go FI German plenium, check |
