croSSeduP Samba Member
Joined: June 13, 2004 Posts: 1106 Location: Western Washington State
Posted: Sun Feb 15, 2015 5:30 pm Post subject: Weber Jet Doctor |
So, I've been having trouble with my street car plugging idle jets every other time I drive it, or so it seems. The fuel is hospital sterile; there is NO WAY dirt from the fuel system is clogging things because it is utterly clean. Today I am installing these jet doctor things in my dual 44's, and I gotta say... From a shade tree engineer viewpoint it totally escapes me how these can stop the idle air from getting plugged. It's so goofy looking. Time will tell, I guess. _________________ Please check my '67 sedan project progress!
http://www.thesamba.com/vw/forum/viewtopic.php?t=502253&highlight= |
Bajaman65 Samba Member
Joined: January 16, 2007 Posts: 469 Location: Borrego Springs
Posted: Sun Feb 15, 2015 6:45 pm Post subject: |
If you look at how the air gets to the idle jet, it's right on top of the carburetor usually under the air filter housing. Any little chunk of dirt or crud that may get past you filter can easily go down that hole and plug your jet. It is a lot less likely for the crud to go to the top of the Jet Doctor snorkel that sticks up about an inch. I have used them on off-road cars for many years where even with the best filters some crap gets on the top of the carburetor and finds its way into that little hole, not with the snorkel Jet Doctor. I have not had a 'dirt or crud' plugged idle jet in many years. Here are the ones that I make for myself.
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Sun Feb 15, 2015 7:33 pm Post subject: |
Bajaman65 wrote: |
Like "Bajaman65" says....
deho Samba Member
Joined: February 23, 2004 Posts: 62 Location: McCordsville, In.
Posted: Sun Feb 15, 2015 7:40 pm Post subject: |
I had the same problem with the idle jets then I used the jet doctor and never clog an idle jet again . They work! |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Mon Feb 16, 2015 5:20 am Post subject: |
Easy mod with brake line. 5 minutes a carb.....
_________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
modok Samba Member
Joined: October 30, 2009 Posts: 26788 Location: Colorado Springs
Posted: Mon Feb 16, 2015 7:01 pm Post subject: Re: Weber Jet Doctor |
britegreenVWSB wrote: |
From a shade tree engineer viewpoint it totally escapes me how these can stop the idle air from getting plugged. |
Yep. A lot of effort for almost nothing. Extending the whole carb vent UP like normal does a lot more. we should call that the carb doctor |
scotth17 Samba Member
Joined: January 30, 2012 Posts: 335 Location: Bedford Texas
Posted: Mon Feb 16, 2015 8:13 pm Post subject: |
For the cheapest of cheap VW bastards out there, you can cut a strip of pantyhose material and stretch it across the vent before installing the air cleaner base and it will keep the big chunks out.... |
Posted: Mon Feb 16, 2015 9:00 pm Post subject: |
scotth17 wrote: |
Man. That IS cheap. How do you know the pantyhose won't cause an air restriction in the idle air circuit and it not meter properly because there isn't enough air? _________________ Please check my '67 sedan project progress!
mark tucker Samba Member
Posted: Mon Feb 16, 2015 9:06 pm Post subject: |
in 12 years of idf style crabs I have had 2 cloged idle jets. you might want to find the place crap is getten in. under the airfilters?under the filter bases, through the filter,etc.Ive always run the outer wears over my filters.my car is a baja style in the rear with everything hanging out there in the breezzee. Ive seen many k&n filters turned to junk by the owners/mechanic and the velostity stacks.I reform my stacks so they do not come into contact with the filters.I also have gaskets under the stacks so i can sync them better. |
Posted: Mon Feb 16, 2015 11:39 pm Post subject: |
This is a very common problem and an easy fix, use the Jet Doctors - or listen to the none believers and sputter down the road, it's just cheap insurance but some people have to argue every post |
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Fri May 29, 2015 1:38 pm Post subject: jet doctor |
Question on re-tuning after installing the CB Performance jet doctors
on weber 40 idf's.
Since now the idle circuit has longer vent tubes is it now in need of larger idle jets?
My problem: when first starting my bus now is hard starting that I never had
before installing these
Thanks' in advance _________________ V.W.owner since 1967 |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Fri May 29, 2015 2:52 pm Post subject: |
scotth17 wrote: |
Man. That IS cheap. How do you know the pantyhose won't cause an air restriction in the idle air circuit and it not meter properly because there isn't enough air? |
It depends on where you get the pantyhose, I went to Amargosa dunes here in NV with a buddy and his Dad once, Well they forgot the Outer-filters for the Webers so my buddies dad went down the Cat-house about 10 miles away.
He had to pay 20$ for a pair but he got to take them off, He was gone for 3 hours too.
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
hill Samba Member
Posted: Mon Aug 03, 2015 5:52 am Post subject: |
earthquake wrote: |
Casey |
Lota traffic on the road that day, eh? _________________ '78 Biegephalia |
jbbugs Samba Member
Joined: September 16, 2002 Posts: 2152 Location: Behind the wheel
Posted: Mon Aug 03, 2015 6:31 pm Post subject: |
I have had great luck keeping my idle jets clear be just taking a big finger full of bearing grease and smearing Thick on the rubber base of my air cleaners before installing them on their bases.
Zero clogged idle jets. _________________ Drag bus! http://www.youtube.com/watch?v=s2MOVmKdhX4
69 OG paint Transporter
73' Super Beetle Champcar Endurance Roadracer
Patina my ass, that's a Rust Bucket! |
Posted: Tue Aug 04, 2015 10:31 pm Post subject: |
jbbugs wrote: |
Zero clogged idle jets. |
And have you done a lot of Off Road ? I am sure your grease works great for you but about 90% of off road people will have an idle jet plugging problem at one time or another. This is just a simple solution to a very common problem. I do not understand why some many people want to argue everything |
jbbugs Samba Member
Posted: Wed Aug 05, 2015 4:27 am Post subject: |
I'm Not arguing anything. Just stating what works well for me. I run an open engine compartment on my roadrace bug, where it sees plenty of dirt/ debris during 24-hour long races. I've also installed a few sets of Jet Doctors on a Few customers cars. They seem to work too. I haven't tried them on my racecar, as I haven't had a need for them. _________________ Drag bus! http://www.youtube.com/watch?v=s2MOVmKdhX4
Greezy Joe Samba Member
Joined: April 12, 2010 Posts: 1534 Location: Crawfordville, Fl
Posted: Wed Aug 05, 2015 7:01 am Post subject: |
I quess I'm one of them cheap VW Guys, black panty knee high stockings over the air filters, never a plugged jet. Now this is on a cheapie $7,000 stroker. _________________ Current:74 Ghia Coupe w/ 2276
71 Ghia Vert w/ 1835
07 GMC Truck
12 Jeep Wrangler
73 Harley FLH 93 cid
89 Harley 883 Sportster (1200)
Owned before: 58, 69 Ghia Coupes, 64 Canvas Sunroof, 68, 72, 73, & 74 Bugs, 63 Single Cab, 65 Bus, 66 & 70 Camper
" Duct tape can't fix stupid, but it'll muffle the sound". |
Oil Phil-M Samba Member
Joined: October 08, 2005 Posts: 541 Location: Vancouver, BC
Posted: Thu Aug 06, 2015 11:10 am Post subject: |
At the same time I got the Doctors I replaced the cheap stamped flexy chrome air filter housings with CB's alloy units and started using a thin layer of wheel bearing grease on the top and bottom of the filter edge where in makes contact with the filter housing. So i cant say which had the biggest effect but clogged idles are a rare occurrence now. |
