67 Sunroof Samba Member
Joined: February 22, 2014 Posts: 1836 Location: Salisbury, MD
Posted: Thu Feb 19, 2015 8:43 am Post subject: 1600 first start-very hard to turn over.? |
Okay I just double checked and triple checked everything on my motor it's looking good! I'm trying to start it on the floor and I ran jumper cables to my battery on my jeep with it running so it have a good juice. When I go to crank over the bug motor it's real hard turning over. I checked and I do have gas to the carbs but my concern is with the starter straining to crank the motor over!? Compression is good on all cylinders, oil filled up and end play is set correctly. I guess I'll pull the starter and look for binding somewhere? |
Marv [UK] Samba Member
Posted: Thu Feb 19, 2015 8:57 am Post subject: |
Did the crank turn freely before you put the cylinders and heads on? _________________ The opinion of the author as expressed does not always reflect that of the author nor does he extend any apologies or assume any liability or responsibility for its content or lack thereof or for any lack of humour of the reader of any content at all, anywhere, ever. The reader agrees to all risk by reading it and is advised that any ‘issue’ is theirs alone as they chose to read it. |
PumaVW79 Samba Member
Joined: January 31, 2012 Posts: 487 Location: WGS84: 22.9083° S, 43.1964° W
Posted: Thu Feb 19, 2015 10:08 am Post subject: |
Retard the timing turning the distributor clockwise and try again. |
HRVW Samba Member
Joined: May 01, 2011 Posts: 2531 Location: Rosarito, Mexico
Posted: Thu Feb 19, 2015 10:27 am Post subject: |
Lot of potential answers to NO questions asked.
Pull; the spark plugs and try turning the engine over using the starter.
If it turns FREE then re install the plugs.
Bring the pully to TDC ad make sure the rotor is directly under the cap wire and in the 1-4-3-2 order. Static set the dist...tighten the dist clamp...make sure the carb sprays gas and then try it. This was my procedure for starting all my rebuilds before installing into a customers car. I would run the engine for about 1/2 hr...allow to cool and then install....a piece of mind and LABOR saving. |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Thu Feb 19, 2015 10:33 am Post subject: |
Read up on static timing your distributor. I static time to 9 or 10 degrees for break in. Double check ground connections. Did u forget a 12 v lead to your coil? _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
Posted: Thu Feb 19, 2015 12:50 pm Post subject: |
I haven't had time to mess with it I had to go over my friends house and install a radio. Here's a picture before I left I'm thinking the timing is definitely off.
Just got home and had about 15 min to play with it.
Yes coil wire is hooked up. I static timed it, but not sure if I had it set on the #1 cylinder or #3 cylinder....I turned the distributor another 1/2"-1" clockwise and the motor is really TRYING to start but still just cranks and cranks! Haha
It definately cranks easier though. I'm wondering if my plug wires are right. I'll check it out tomorrow and see. Certainly sounds better though. The pic below is BEFORE I turned it clockwise 1"....
Does it look about right?
I'm off work tomorrow morning so I'll try your suggestions. Thank you!
Posted: Thu Feb 19, 2015 12:59 pm Post subject: |
'67 Sunroof wrote: |
I think the screwdriver in your fuel pump is yer problem right there _________________ The opinion of the author as expressed does not always reflect that of the author nor does he extend any apologies or assume any liability or responsibility for its content or lack thereof or for any lack of humour of the reader of any content at all, anywhere, ever. The reader agrees to all risk by reading it and is advised that any ‘issue’ is theirs alone as they chose to read it. |
theDrew Samba Member
Posted: Thu Feb 19, 2015 1:08 pm Post subject: |
check the engine of course -- when I was trying to start an engine out of the car, my crappy jumper cables didn't give a solid connection and the starter could barely turn it over. _________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
1985 Vanagon Campmobile w/ 2005 EJ25 |
Posted: Thu Feb 19, 2015 1:14 pm Post subject: |
Marv [UK] wrote: |
I think the screwdriver in your fuel pump is yer problem right there |
That was BEFORE I hooked up the gas lines, etc and was setting static timing silly.... |
Posted: Thu Feb 19, 2015 1:40 pm Post subject: |
2 more pics before I go to work. I have a DVDA distributor. I used the outside nipple and went to a "T". From there i split the vacuum lines and went to each carb like this:
Here is another pic:
I have a 205 dustributor and static timed it to 7.5 degrees btdc. Correct? Both carbs are getting gas. I push on the crossbar and see the gas squirting into them. I also "pre-tuned" the butterflies with a feeler gauge so they would both open up the same and set the idle stop and air screws before I instalked them. Haven't messed with them at all yet though. |
Posted: Thu Feb 19, 2015 4:09 pm Post subject: |
Youre arent lined up right on your distributor. The rotor needs to point more to the line so turn your distributor body clockwise. Look for the spark jump just as it opens, lock the nut and start it. _________________ 2276 IDA's 86C 11-1 DD !
Dale M. Samba Member
Posted: Thu Feb 19, 2015 8:06 pm Post subject: |
jfats808 wrote: |
Youre arent lined up right on your distributor. The rotor needs to point more to the line so turn your distributor body clockwise. Look for the spark jump just as it opens, lock the nut and start it. |
Yep ..
If in picture engine at TDC (Actually 7.5° BTDC) and your rotor is pointing at pulley (4:00) then bring notch in dist body (now at 2:00) around to line up with rotor (this will also be #1 tower on dist cap) .... When points just open and light comes on, lock it down...
This is how the gods that created heaven and earth and VW's intended it to be....
I would also disconnect vacuum retard side and leave it disconnected.... maybe replace dist with SVDA dist...
Posted: Thu Feb 19, 2015 11:35 pm Post subject: |
That makes sense Dale. I turned the distributor about 2" clockwise and the engine turns over MUCH easier and even wants to start! I pulled a plug and I'm getting spark but don't smell any gas though...uh-oh!
Wonder where the gas is going that I am squirting into the carbs with the cross bar?
Hope it's not washing out the cylinders.
Anyway, I'll mess with it tomorrow. Soo excited to get her started! |
Posted: Wed Feb 25, 2015 8:51 am Post subject: |
Okay today I went out and double checked my points gap and they were good. I also made sure my wires were not mixed up and labeled my cap-they are good. I set the static timing so I was in the ballpark too. I got out my strobe timing light too for when it started up I could double check. I hooked the motor up to my car with a pushbutton starter.....(it is sitting on the floor dolly now)
Coil wire is hooked up
Timing at 7.5 btdc
Fresh gas
Plugs are getting spark
I don't really want to mess with the throttle linkages because one will affect the other side and I pre-set both at .003 before i installed the carbs per the superformance book.
Ok, When I crank the motor over and give it some gas it wants to run but as soon as I stop pushing the button on the starter it dies every time!? If I keep holding the starter push button down and give it gas it will run....
The Dellorto superformance book says to screw the idle screws out 1 1/4 turns as a baseline but I've tried anywhere from 1/2 turn to 2 turns out and I see no difference. The engine just will not idle by itself. I checked the timing with my strobe while cranking it and it is spot on-7.5° before top dead center.
Any ideas where to start?
I'm gonna pull a plug and see what it looks like I guess. The distributor is a DVDA Bosch 113905205AJ.
I believe the timing should be 7.5btdc right? Do I have to disconnect the vacuum lines when timing it? I don't think so.
(I'm only using the outside nipple on the vacuum canister-correct?
Any help at this point is appreciated! |
Posted: Wed Feb 25, 2015 9:05 am Post subject: |
Think I might be onto something....the starter isn't disengaging...I got it running somewhat but I can hear the starter still dragging or turning over while it is running!!? This is a new starter...gonna pull the starter and try it outside the car. |
Posted: Wed Feb 25, 2015 9:24 am Post subject: |
Try the old 16oz universal starting accessory - smack it with a hammer _________________ The opinion of the author as expressed does not always reflect that of the author nor does he extend any apologies or assume any liability or responsibility for its content or lack thereof or for any lack of humour of the reader of any content at all, anywhere, ever. The reader agrees to all risk by reading it and is advised that any ‘issue’ is theirs alone as they chose to read it. |
Posted: Wed Feb 25, 2015 9:57 am Post subject: |
Have you double checked the valve timing?
TDC mark when both valves of cylinder #1 are closed - check gap (.004 in/.10 mm for hot climates and .006 in/.15 mm for cold ones).
Rotor must be pointing to cyl #1 distributor cap connection->#1 spark plug cable
B- Turn the pulley 180 degrees clockwise. Check gaps of valves / rotor position to cyl 4
Repeat the step B with cyl 3 and again with cyl 2.
Position of cylinders is:
Front of the car
3---1
4---2
Back of the car
Posted: Wed Feb 25, 2015 10:27 am Post subject: |
Got it! I pulled the starter out of the bellhousing and cranked it off of my battery...IT STUCK OUT and wouldn't retract! I got a new starter and hooked it up. I also realized I had the coil wire hooked up to the wrong side of the switch!!!?? So I guess it would ONLY be hot when i PRESSEDmy starter switch. Duhhhhh..
Anyway, it started and runs great!! Strobe timed it and it sounds wonderful!
I occasionally get a backfire out of one of the carbs. I'll hook up my snail and check the sync of both carbs later on. What should they read at idle? I am getting 10 kg/h at idle? Seems high to me.? |
yamaducci Samba Member
Joined: March 30, 2010 Posts: 2335 Location: Mount Airy, Maryland
Posted: Wed Feb 25, 2015 11:37 am Post subject: |
yamaducci wrote: |
They just need to be equal at the proper RPM |
Yamaducci has it right.... No numbers are the same from engine to engine.... But left and right side on your engine should be same...
Generally backfire out carbs indicates lean mixture...
