mastorna Samba Member
Posted: Thu Feb 19, 2015 2:25 pm Post subject: Should I replace this metal? |
I'd like to keep as much OG metal as possible and I have a replacement panel but curious if you'd suggest to keep what's there? Do you think this is too much rust? The far side has some cancer that would remain if I didn't cut it out. This panel area is a bitch to weld\grind.
_________________ 1959 Type II Mango SO-23
1962 Type II Kombi Light Gray
1963 Type II Standard Sunroof SWR\BG
1963 Type II Deluxe MG\PW |
theKbStockpiler Samba Member
Joined: July 07, 2012 Posts: 2316 Location: Rust Belt
Posted: Thu Feb 19, 2015 3:24 pm Post subject: |
Maybe you could use only part of the replacement panel? _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask. |
CiderGuy Samba Member
Joined: December 23, 2013 Posts: 1351 Location: Bucks County, Pa
Posted: Thu Feb 19, 2015 5:43 pm Post subject: |
I would ... on a ghia I'm restoring, I replace the bottom 12 inches of almost the entire car. _________________ ----------------------
Cars Currently Owned:
1970 Karmann Ghia Coupe
1973 Karmann Ghia Coupe - Project car for sale
1970 Karmann Ghia Convertible (Body off restoration)
Timing is everything |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Thu Feb 19, 2015 9:06 pm Post subject: |
If I was to leave it, I would sandblast the rust clean, and then treat it with ospho to kill whatever little bit of rust might remain. If you're going that far, with new panels to give the car a new life, you've got to get all of the rust gone. Sandpaper and wire brushes aren't enough. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Sun Apr 05, 2015 8:37 pm Post subject: |
Wire wheel, sandpaper, and phosphoric acid. Then let acid dry out (covering the area in plastic wrap will let the acid last longer by not drying out and work better) and repeat the process till all rust is gone and steel turns shiny silver color. If it buffs with the wire wheel a lead color there is more rust that needs to be removed.
Found while it takes time, this leaves as much of the metal as possible. _________________ In Stereo, Where Available! |
