TSFR Samba Member
Joined: May 14, 2013 Posts: 365 Location: Columbia, SC
Posted: Fri Feb 20, 2015 9:02 am Post subject: 1975 VW Beetle FI Fuel Tank - Will it fit? |
Hello everyone, I'm on a fact finding mission and need to know if the 1975 VW Beetle FI fuel tank will fit in the standard Manxter 2+2 dune buggy.
When my build starts I'm going with a Subaru drive train and need a fuel return line.
Can I use a Super Beetle fuel tank or is it a completely different size?
Thanks! _________________
Thanks,
Jeff
Manxter 2+2 #160 |
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6767 Location: Northern California
Posted: Fri Feb 20, 2015 10:28 am Post subject: |
You may already know about it but there's a forum on this specifically for the Manxters
http://www.meyersmanx.info/forum/ |
TSFR Samba Member
Posted: Fri Feb 20, 2015 11:23 am Post subject: |
I didn't think that forum was still active. I was trying to ask where there is a lot of traffic. _________________
Thanks,
Jeff
Manxter 2+2 #160 |
streetbuggy8804 Samba Member
Joined: August 25, 2009 Posts: 652 Location: Placentia,ca
Posted: Fri Feb 20, 2015 7:17 pm Post subject: |
What is the turn around time they gave you between deposit and when it will be ready for pick up? |
TSFR Samba Member
Posted: Fri Feb 20, 2015 7:32 pm Post subject: |
6-8 weeks _________________
Thanks,
Jeff
Manxter 2+2 #160 |
jsturtlebuggy Samba Member
Posted: Sat Feb 21, 2015 3:35 pm Post subject: |
Yes a STD Beetle FI fuel tank will fit. A Super Beetle fuel tank will not. It is different dimensions.
You can have someone install another fitting on a Non fuel injection tank. It may be cheaper then buying a fuel injection tank.
The only stock fuel tanks I will recommend are the ones that Wolfsburg West sells. They do not have a tank for fuel injection.
This is the new site www.manxclub.com
I have some of my build/rebuild of my Manxter Dual Sport there. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
didget69 Samba Member
Joined: July 22, 2004 Posts: 4927 Location: Raleigh, North Carolina
Posted: Sat Feb 21, 2015 5:01 pm Post subject: |
jsturtlebuggy wrote: |
You can have someone install another fitting on a Non fuel injection tank. It may be cheaper then buying a fuel injection tank. |
I am not aware of anyone reproducing the Standard Beetle FI fuel tank. However, I have heard tell that the FI tank has a baffle or some other difference in the tank besides a simple return line - can anyone confirm? I'd rather not cut open my FI tank to find out!
bnc _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
GS guy Samba Member
Joined: December 03, 2007 Posts: 968 Location: Maryland
Posted: Sun Feb 22, 2015 6:48 am Post subject: |
I'll confirm that digit.
I've got an original std. Beetle EFI tank and it does have a couple of differences from a non-EFI. Namely, the return inlet next to the standard outlet, and inside there is a box-like enclosure around these two ports about 6" square (give or take) and a couple of inches high? It's open on top, and IIRC has small gaps (or other openings) between the box walls and bottom of tank - so it can still draw fuel when it gets below the height of the box walls. A simple small baffle chamber to keep fuel around the pick-up.
I don't have a pick of the internal baffle-box, but here's the bottom of the tank:
Jeff _________________ 70's vintage Deserter GS buggy - undergoing transformation to Super GS! |
Posted: Sun Feb 22, 2015 8:39 am Post subject: |
Thanks Jeff: you were probably the person the mentioned this on forum before. It's why I tracked down an FI tank for a CIS build.
bryan _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
TSFR Samba Member
Posted: Sun Feb 22, 2015 2:07 pm Post subject: |
Just so I know for sure, will the 12 gallon tank fit under the hood of the Manxter kit?
Thanks,
Jeff
Manxter 2+2 #160 |
Posted: Sun Feb 22, 2015 6:24 pm Post subject: |
No, It will not fit it is to tall.
If you are looking for a larger fuel tank. Get a hold of Tom of "Tom & Kathleen" he has a custom made Stainless Steel tank in Kathleen's Manxter.
On the Australian Manx Club Gallery site it shows it.
Bruce Meyers Yellow Manxter has the same type of tank made out of aluminum. Both of these tanks were made in the USA. _________________ Joseph
Elrod Motorsports
TSFR Samba Member
Posted: Sun Feb 22, 2015 7:00 pm Post subject: |
Will do! Thanks for the information! _________________
Thanks,
Jeff
Manxter 2+2 #160 |
RedBaronofRedBud Samba Member
Joined: July 05, 2013 Posts: 505 Location: Southeast Missouri
Posted: Wed Feb 25, 2015 3:20 am Post subject: |
Bruce Meyers Yellow Manxter has the same type of tank made out of aluminum. Both of these tanks were made in the USA. |
The tank is actually sold by Turn Key Manx. Brad is on this forum and can help you out with it. They are extremely nice and are 15 gal tanks. _________________ Or you can call me………Tim
My two pennies…your mileage may vary
I’m not a complete idiot, there are parts missing |
TSFR Samba Member
Posted: Wed Feb 25, 2015 4:30 am Post subject: |
I called and talked to Nate @ TKM because Brad is still in AUS. He actually did tell me they had made them and was supposed to call me back yesterday with some details about making more. I'm Sure he got busy and I'm hoping to hear from him today. He did say 15 gallons and EFI setup so it should be perfect. He also added they were in the process of redoing the website which is why the tank was no longer listed. _________________
Thanks,
Jeff
Manxter 2+2 #160 |
Tom_Kathleen Samba Member
Joined: August 26, 2004 Posts: 919 Location: Vernon, CT
Posted: Wed Feb 25, 2015 7:29 am Post subject: |
jsturttlebuggy/TSFR - here is a link http://www.manxclub.com/forum/viewtopic.php?f=70&t=3449 to the details of the American made AL & SS fuel tanks. Tom _________________ Manxter #16, 1968 Meyers Manx & Kick-Out SS #16 (WIP)
Manx Club & CVA |
TSFR Samba Member
Posted: Wed Feb 25, 2015 12:18 pm Post subject: |
Thanks again Tom! I updated info there as well but, TurnKey said they should produce/acquire more of the 15GL tanks. I spoke with Nate today who said he would talk it over with Brad when he gets stateside. I will keep everyone informed when I find something out. _________________
Thanks,
Jeff
Manxter 2+2 #160 |
wythac Samba Member
Posted: Wed Feb 25, 2015 12:32 pm Post subject: |
http://www.thesamba.com/vw/forum/viewtopic.php?t=5...p;start=20
In the thread above, Joecoolcustoms posted some tank modifications to the underside to improve fuel capacity....wouldnt be much more difficult to add an extra port to the underside. If you had the room it would be nice to add some fuel capacity at the same time. |
TSFR Samba Member
Posted: Wed Feb 25, 2015 1:10 pm Post subject: |
Honestly, it depends on how much this tank from TKM ends up costing me. _________________
Thanks,
Jeff
Manxter 2+2 #160 |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Thu Feb 26, 2015 5:47 am Post subject: |
Not hi-jacking, but a question about the FI tanks. The purpose of the baffle is ??? _________________ D-Dubya Manx clone - 63 Short pan,1914.
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Thu Feb 26, 2015 8:13 am Post subject: |
andk5591 wrote: |
Not hi-jacking, but a question about the FI tanks. The purpose of the baffle is ??? |
My guess is the baffle is there to help prevent the fuel pump running dry and causing a loss of pressure during the normal sloshing around of the fuel. On a carbureted car it wouldn't make much difference. But with FI you could have an immediate loss of power. _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
