Phil911 Samba Member
Posted: Fri Feb 20, 2015 10:23 am Post subject: lugs/studs |
anyone drill out the threads and install lugs/studs? is this advisable? what combination did you use - lugs / bolts / thread pattern?
My wheels are 19-20mm thick, and 32mm to get through the rim and the hubs.
the hole in the rim is 17mm diameter and the fronts are not beveled (rears are). I need a flat or shank styled nut.
can you advise a combination of lugs and nuts?
thanks. _________________ 1990 911 Porsche C2 (964) - Sold
1976 VW bug (sold) |
