ritchiet002 Samba Member
Joined: January 27, 2003 Posts: 1676 Location: Kaneohe, HI
Posted: Fri Feb 20, 2015 7:21 pm Post subject: Bus Slick |
I saw a bus in the handicapped space at the drug store. I went in to use my wife's phone to take a photo and it had left leaving this behind!
Appropriate parking stall---yes
_________________ Somewhere there is a jar with your name on it!
From now on, I'm gonna connect the dots my own way!______________________________________ |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8687 Location: Sunset, Louisiana
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Sat Feb 21, 2015 9:23 am Post subject: |
I can't tell you how many times I've backed into spaces just so my car doesn't look guilty of an OPEC-reportable incident. _________________
EverettB wrote: |
FU#5 |
Posted: Sat Feb 21, 2015 10:37 am Post subject: |
He was pulled up as far as possible by the front door---it was raining and the safaris were cracked open. I figure main seal? _________________ Somewhere there is a jar with your name on it!
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11053 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Sat Feb 21, 2015 11:49 am Post subject: |
Love it.... always marking their spot..
It always amazes me how many save the environment decals are plastered on old Vw's....specially the "Bus"...
Kinda a double standard from my perspective.
Granted old Vw's, in their time were "some" of the least auto polluters . . but today even though lower volume....they are higher polluters......
Just curious... does California consider excessive oil/fluid leaks into their auto emission standard....
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
thomas. Samba Member
Joined: July 31, 2010 Posts: 1288 Location: South West (Pa.)
Posted: Sat Feb 21, 2015 4:12 pm Post subject: |
Q-Dog wrote: |
Was it a mid-engine bus? |
Mine has a slight leak in that area of the shift lever/ nose cone. Common tranny fluid leak. |
Jacks Samba Member
Joined: July 15, 2006 Posts: 2344 Location: San Clemente, Ca.
Posted: Sat Feb 21, 2015 5:48 pm Post subject: |
Thomas, early full syncho trans used plastic plugs for the trans shift rails which shrunk and leaked. Later ones used aluminum plugs, 3 on the side, and a smaller low one above the lower stud on the mid casting of the trans on the left hand side near the nose piece. If that is the case, pry the plastic out and install the later type. You will have to double nut the lower stud to remove it before installing the new plug. I hope this helps. _________________ Jack Staggs
Actual name |
