36hp Lifter Oil Groove ?
snowbug
snowbug is offline
PostPosted: Sun Feb 22, 2015 8:56 am    Post subject: 36hp Lifter Oil Groove ? Reply with quote
Do you think there is any advantage to grinding a notch between the oil grooves on a 36 hp lifter? I have done this on 1600 lifters. Suppose to be for better oiling. Jim
slalombuggy
slalombuggy is offline
PostPosted: Tue Feb 24, 2015 6:28 pm    Post subject: Reply with quote
Anything you can do to get oil to the top end is good. Did you do the Hoover mod to add an other oil galley going to the right side of the case as well?
brad
snowbug
snowbug is offline
PostPosted: Wed Feb 25, 2015 7:09 am    Post subject: Reply with quote
brad
What case oil mod? Now you tell me after I glued it together. thanks Jim
slalombuggy
PostPosted: Wed Feb 25, 2015 5:16 pm    Post subject: Reply with quote
On my cases I drill the galley plugs out and on the 1/2 side I extend the oil galley fron the center cam journal to the one closest to the gear and then drill down through that bearing saddle to meet up with the extended galley. I don't know if it can be done on a 36 case? Sorry, should have said that in my original post.
EDIT: I just looked in the gallery and the 36 cases are different. But you can do this to your 1600 based cases. It really adds to the oil getting to the top end on that side of the case.
brad
avus
avus is offline
PostPosted: Fri Feb 27, 2015 3:09 pm    Post subject: Reply with quote
Here's how I modified some lifters--turned about .5mm off the land separating the oil hole from the feed groove, so that the pushrod gets oil all the time instead of only when the valve is open.
slalombuggy
PostPosted: Fri Feb 27, 2015 6:41 pm    Post subject: Reply with quote
You guys and your fancy lathes and skills Rolling Eyes Wink Wink
brad
avus
avus is offline
PostPosted: Fri Feb 27, 2015 8:34 pm    Post subject: Reply with quote
brad
Well, you could chuck it in your Harbor Freight cordless, and chew it down with a rasp, too.
slalombuggy
PostPosted: Sat Feb 28, 2015 10:02 am    Post subject: Reply with quote
avus wrote:
brad
Been there done that. Very Happy
brad
snowbug
snowbug is offline
PostPosted: Sat Feb 28, 2015 10:52 am    Post subject: lifter Reply with quote
Well I ground a notch between the 2 grooves. I did notice some thing else. Had to buy a couple of WW lifters to make up a complete set. The grooves on the WW lifters are quite sharp so I stoned the edges off in the lathe. Brad , it`s so nice having my own little machine shop. Jim
earthquake
earthquake is offline
PostPosted: Wed Mar 18, 2015 10:47 am    Post subject: Reply with quote
how much oil flows past the piece of wood in a 36hp pushrod?
Casey
74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison]
Mr. Motorhead
Mad Scientist
Mr. Motorhead is offline
PostPosted: Wed Mar 18, 2015 11:13 am    Post subject: Reply with quote
Casey
None........I always pull the chopsticks out. Most all the later style lifters don't have them. As for the cutting between between the spaces, well not all lifters have the two grooves. Some lifters have a single groove which tends to hold more oil.
30 years experience in the sales of new and used auto parts!
36 horsepower parts for sale at http://www.aircooledresearch.com/
Or the new site at http://www.bugparts.com
Check out the Bonneville project:
http://aircooledresearch.com/docs/thebonnevilleproject.html#
"All limitations are self imposed."
Some Chinese guy
mark tucker
mark tucker is offline
PostPosted: Wed Mar 18, 2015 8:12 pm    Post subject: Reply with quote
I would remove the center grove.hmm on second thought,I would remove the high spot between the two grooves and in the prosess lighten the lifter some. and or add a slot to the lifter bore.and enlarge the oil gallys a bit if needed.
avus
avus is offline
PostPosted: Wed Mar 18, 2015 9:12 pm    Post subject: Reply with quote
An issue I can see with sending too much oil up the pushrod is possibly starving the cam bearings. I think the "chopsticks" and the timed grooves on the tappets are meant to limit the amount of oil sent to the top end. The engineers had some reason...
snowbug
snowbug is offline
PostPosted: Sat Mar 21, 2015 10:12 am    Post subject: lifters Reply with quote
The replacement WW lifters don`t have any wood in them.
