effvee Samba Member
Posted: Sun Feb 22, 2015 10:14 am Post subject: 6 stud cylinders |
Hi everyone, anyone have pic's of the type IV engine that has been 6 studs mods. George at EMW only does 5 suds |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5410 Location: Holland, MI
effvee Samba Member
Posted: Thu Mar 05, 2015 4:38 am Post subject: |
Hi, they are going to be 103 or 105 also "o"ringed. Brothers machine shop in Ontario CA does the mod, but only to un-completed engines. My engine is very near completion,so they won't do the service.. at the time it was 1300$. I also don't know if it's now possible since I had dual plugs added. |
Bleyseng Samba Member
Posted: Thu Mar 05, 2015 8:09 am Post subject: |
For big cylinders everyone has gone to Nikkies as they don't have the sealing problems that the steel cylinders do and the need for 5 or 6 studs. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
effvee Samba Member
Posted: Thu Mar 05, 2015 8:57 am Post subject: |
it depends on the size of the cylinder and the size of the sealing surface. when you put 15 pounds of boost even nikies leak. I have my own nikie-like cylinders made, I just need them coated.
user/effvee/media/2011-03-26_15-47-10_465.jpg.html][/URL]
914werke Samba Member
Posted: Fri Jul 10, 2015 11:54 am Post subject: |
effvee wrote: |
Who did the dual plugging to your heads? Do you have any pictures? |
effvee Samba Member
Posted: Sat Jul 11, 2015 9:36 am Post subject: |
European Motorwerks did the work.
Posted: Fri Nov 06, 2015 9:39 am Post subject: |
effvee wrote: |
I am embarking on a 2366 (NA) T4 build and wanted to dual plug my heads. (Im sticking with OE 4 stud & Nickkies) Can you provide some details? I reached out to EMW about that work but never got any response. |
effvee Samba Member
Posted: Fri Nov 06, 2015 9:00 pm Post subject: |
914werke wrote: |
effvee wrote: |
Hi, you may need to call them, George is the co-owner, he will help you. It will depend on several things. Such as new valves, larger valves. How much work that will need to be performed. I have two sets of heads. A 1.7 and a 2.0. From what I know the 2.0 would yield he best power. But the 1.7 are not slouch, there is porting to be done. This head is the 2.0, now what you don't see is the dual "O" ring grooves in the head sealing surface.
These are the same 2.0 heads, notice the barrels, you will see the dual groove. The grooves are in both head and barrel. Also there is a builder in Germany by the name of Ralf Klaus. Mr. Klaus suggest that we add fins very near the spark plug holes to aid in heat dissipation, notice the 1.7 heads.
Here's the 1.7 Also get the smaller spark plugs and nut serts installed in the new spark plug holes. Here's the back side of the second spark plug hole, also have the second spark hole nut serted, George already did mine without asking. Those none serted holes are going to strip out. Get them ported while you are at it.
suggest adding heat sinks very near the spark plug area to aid in head dissipation, you will see this on the 1.7 heads. |
