mikething Samba Member
Joined: February 09, 2009 Posts: 95 Location: Dana Point
Posted: Mon Feb 23, 2015 3:15 pm Post subject: Stock thing wheels |
Having a hard time finding stock vw thing wheels in southern California..Anyone have 4 wheels, I would like to go stock and remove front rotors go back to drums.
Mike |
Ron Domeck Samba Member
Joined: August 05, 2007 Posts: 1466 Location: louisville Ky
Posted: Mon Feb 23, 2015 3:53 pm Post subject: |
The Thing Shop? |
Posted: Mon Feb 23, 2015 4:02 pm Post subject: |
I have bought from them years ago, i will check.
Thanks for reply
Mike |
Posted: Mon Feb 23, 2015 4:10 pm Post subject: |
Nope, need to find them private party, thanks
sam_w Samba Member
Joined: March 07, 2002 Posts: 1479 Location: Petaluma, CA
Posted: Mon Feb 23, 2015 5:42 pm Post subject: |
I have a set of four standard Thing wheels.
Right now they are in the treasure chest of my 63 VW Singlecab that is with Fresno James in Kingman AZ.
I plan to get to him 'Thing-a-thon' weekend. March 27th to 29th.
I will be with SoCalBajas and could give them to someone returning to SoCal.
Where are you located? I will find someone close to you, or you could come to Landers and drive your Thing in the Dirt with several others.
I will post info & a pic of this off-road Thing event.
I was using them to see if my 63 singlecab would run cooler with 14" wheels instead of the 15: wheels it has. What fixed the overheating was a Porsche generator pulley, which in 10% smaller in diameter, so I do not really need my old Thing wheels.
Maybe this should have been a PM, but here you are. _________________ 63 singlecab
73 thingster
74 Thing |
sam_w Samba Member
mondshine Samba Member
Joined: October 27, 2006 Posts: 2770 Location: The World's Motor Capital
Posted: Mon Feb 23, 2015 8:46 pm Post subject: |
I found that converting from (front) drum to disc brakes provided so much improvement, I would hate to go back to drums. That's from correctly adjusted front drum brakes to "small" disc brakes that fit inside the stock 14" wheels.
I suggest you think twice about reducing braking ability; maybe 15" non slotted steel wheels that resemble the stock wheels would be a solution.
It certainly would expand your choice of appropriately sized tires, as 14" tires are getting hard to find.
Good luck, Mondshine |
sam_w Samba Member
Posted: Mon Feb 23, 2015 9:26 pm Post subject: |
BTW
15" wheels were standard on German things.
If you look in the PDF parts manual the 15" wheel is the same as a bus wheel from 63 and earlier. I have a 63 bus so I can swap wheels.
You could try wide 5 early bus 15" wheels.
They have the correct offset for type 181's _________________ 63 singlecab
73 thingster
74 Thing |
ente_kaefer Samba Member
Joined: August 22, 2013 Posts: 242 Location: St Louis, MO
Posted: Tue Feb 24, 2015 1:23 am Post subject: |
I've been wanting to place disc brakes up front in my 1973 Thing, but I know I have to go to 15 inch rims.
CIP appears to have both 4.5 inch as well as 5.5 inch rims, http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC%2DC10%2D6626.
I need to contact them to see if their front disc brake conversion kit will 'work' with their 15 inch 'wide 5 ' rims, as well as the offset so I can determine the tires to purchase.
My 1973 Thing has 14 inch Thing rims up front, and Bus 14 inch rims in the rear.
Given my recent experience with working with drum brakes, I would keep the front disc, much safer and better braking performance than drum brakes. |
Posted: Tue Feb 24, 2015 1:42 am Post subject: |
sam_w wrote: |
BTW
They have the correct offset for type 181's |
Gads, here in the 'ol USA, the Typ 181 15 inch rims are just about a rare as hens teeth, I have been trying to locate same, as my 'long term' goal is to have my car resemble a Bundesgrenzschutz Typ 181 . . . |
sam_w Samba Member
Posted: Tue Feb 24, 2015 4:38 am Post subject: |
I posted in a previous thread the VW part number for 15" wheels. The are the wide fives to get the correct offset. Here is the pic. Note it has a 211 part number, that is for buses.
73 thingster
74 Thing
rrankin Samba Member
Joined: November 10, 2004 Posts: 287 Location: Austin Texas
Posted: Tue Feb 24, 2015 11:03 am Post subject: |
A few months ago I spoke to The Thing Shop and they said they were working on refurbishing some stock wheels... making sure they were true and powder coating them. They said it'd be a few month before they were ready. Might be any time now... _________________ '74 Thing [Fritz]
Austin, TX |
Posted: Tue Feb 24, 2015 11:56 am Post subject: |
thanks for replies,
15" wheels would be nice..impossible to find...I did not think bus wheels fit. but will look into it.
what is your price for 4 stock 14 " wheels?
Mike |
sam_w Samba Member
Posted: Tue Feb 24, 2015 12:17 pm Post subject: |
I got a set of wide 5's for my 63 singlecab, I think repros are available from several places.
I will pmail you re my 14" wheels. _________________ 63 singlecab
73 thingster
74 Thing |
Posted: Wed Feb 25, 2015 1:34 am Post subject: |
that would be cool |
Joined: February 21, 2003 Posts: 868 Location: Clifton Park NY Saratoga County
strelnik Samba Member
Joined: October 01, 2010 Posts: 352 Location: Michigan
Posted: Fri Feb 27, 2015 7:18 am Post subject: |
sam_w wrote: |
BTW
Sam.
Thanks for the info. BTW what is the correct offset for 15" 5 x 205 rims for Things? _________________ L'audace! L'audace! Toujours l'audace! |
sam_w Samba Member
Posted: Fri Feb 27, 2015 7:42 am Post subject: |
I don't know, I can measure the offset in one of my 63 bus wheels. What do I measure? _________________ 63 singlecab
73 thingster
74 Thing |
Posted: Fri Feb 27, 2015 10:36 am Post subject: |
sam_w wrote: |
I don't know, I can measure the offset in one of my 63 bus wheels. What do I measure? |
Definitions:
The offset of a wheel is what locates the tire and wheel assembly in relation to the suspension. More specifically, it is the measured distance between the hub mounting surface and the center line of the rim. Below is an explanation of the various types of offsets which are pictured in the above graphic.
Positive Offset- A positive offset occurs when the hub mounting surface is on the street side (the side you see) of the center line of the rim. Most factory rims will have this type of offset.
Zero Offset- When the hub mounting surface is centered within the rim, it is known as a zero offset.
Negative Offset- If the hub mounting surface is on the brake side of the center line of the rim, it is considered a negative offset or "deep dish "
[img]
[/img] _________________ L'audace! L'audace! Toujours l'audace! |
Shoyrtt Samba Member
Joined: August 21, 2010 Posts: 1009 Location: Redlands, CA
Posted: Fri Feb 27, 2015 12:43 pm Post subject: |
I have four stock 14" wheels with a set of old school BFG tires on them. I'm in Redlands. PM me for more info.
