I Ride Sand Samba Member
Posted: Tue Feb 24, 2015 12:57 pm Post subject: drums on IRS? |
So, I guess I am really bad at using the search function.... I have a set of drums on my swingaxle trans that are wide 5 pattern, and was wondering, can be used on the IRS setup I have now? Will it work somehow or is a new set of drums needed? |
Brian Samba Moderator
Posted: Tue Feb 24, 2015 2:57 pm Post subject: |
I'm not sure.
But I know that the other easy way to get wide 5 rears is to have thing drums. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
DuaneL Samba Member
Joined: February 02, 2012 Posts: 511 Location: Spokane WA
Posted: Tue Feb 24, 2015 3:06 pm Post subject: |
as I recall the snout on a irs drum is 0.55 inches longer than a swing so the axle nut will not tighten against the drum (it was probably a bad idea but I was young and dumb at the time and once used washers to make a similar swap work not sure how long it might have lasted, I traded in the car shortly afterward) _________________ ____________
1971 std bug, 1776, ACN Super Stock 34-3, dvda dist, 27x8.50 14 tires |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5411 Location: Holland, MI
Posted: Tue Feb 24, 2015 3:09 pm Post subject: |
There are a couple ways to go about it. Easy way is to use '58 - '67 backing plates and hardware with wide 5 drums and a spacer between the drum and axle nut. If you do this you still have the narrower early shoes which wear faster than the wider later shoes.
The other way is to use '68 and newer backing plates and hardware and use spacers to set the wide five drum so that the shoes completely contact the drum lining. This will need a spacer between the drum and axle nut and possibly between the drum and bearing spacer. Depending on the drum, some people also have to turn the inside face of the drum back a hair so that the shoes fit.
At the end of the day, the weak link will still be the drums. When you beat on them, especially with wider wheels/offset, they have a tendency to crack starting from the oil slinger hole in the face. That is why I went with thing drums. They bolt straight up to '68 and newer backing plates and hardware, have the long splines which are stronger than the earlier short splines, and the drum is physically much stronger than the early wide fives. _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
Posted: Tue Feb 24, 2015 4:10 pm Post subject: |
Vanapplebomb wrote: |
Sweet! This is the way to go for now. the brakes in my old sandrail were done last year with new everything. hardware, hydraulics, shoes... you get the idea. I really didn't want to ditch all of these new parts just to replace them.
I will hang on to everything off of the IRS setup just so I can convert it back next time though. |
BUGGUTZ Samba Member
Joined: March 13, 2007 Posts: 537 Location: Luzerne Mich
Posted: Tue Feb 24, 2015 6:35 pm Post subject: |
I ran 66 wide 5's on 72 backing plates and wider shoes. Cut the outer nose if the drum about 7/16". They fit and worked. I believe I ground the steel back on the shoes a tad to not cut the drum. Long time ago but thats how I remember it. |
Posted: Tue Feb 24, 2015 8:56 pm Post subject: |
Why cut the nose of the drum back farther? The wide fives were already shorter than the four lug drums to start with. Cutting them back would require and even larger spacer and would further reduce the load bearing surface area of the splines...which was already a good deal less than the 4 lugs to begin with. _________________ 1800 Type 4 Berrien 295
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Wed Feb 25, 2015 7:01 am Post subject: |
The Thing had wide 5 rims on an IRS rear and balljoint front end, why not source Thing drums? |
Posted: Wed Feb 25, 2015 7:20 am Post subject: |
That is what I did. evwparts.com has a great deal on Thing drums. High quality German drums made by Sebro. In my opinion, they are actually a bit beefier than the original VW Thing drums. They have thicker webbing and the webbing on the face has been offset by 18 degrees to provide more support to the bolt holes. Currently listed at $105 per drum. That is a very fair price for a quality Thing drum, and actually cheaper than when I ordered mine a couple years back. Hard to go wrong with that. Win-win!
Posted: Wed Feb 25, 2015 12:29 pm Post subject: |
Bashr52 wrote: |
Because the early backing plates are sitting there covered in new hydralics, hardware and shoes, while the late backing plates have junk on them. plus, I have a good set of early drums. It is just a sandrail, so wear is not really an issue as 1000 miles a year shouldn't wear parts out very fast.
Plus, I'm a cheap bastard. |
Posted: Wed Feb 25, 2015 4:57 pm Post subject: |
My drums had a long nose on them. Fresh off the 66 sedan. The 72 was a super, maybe that had to do with it? I had a couple buddies then that told me how to do it. Cut the drum, used a washer and the castle nut set right where it needed to be. It was a decade ago or more. I may have put a spacer behind the drum to set the shoes in the right spot. I have disc now and looing back........hit the swap meet and go to disc. |
Posted: Wed Feb 25, 2015 5:09 pm Post subject: |
Ok I got it. I cut the drum and used a bearing spacer from the swing axle to make the difference. Otherwise a smidge of the axle spline sticks past the drum. |
mkparker Samba Member
Joined: October 12, 2004 Posts: 332 Location: Sherman, Tx
Posted: Wed Feb 25, 2015 9:23 pm Post subject: |
Those work well, but any hardened spacers will work. A buddy of mine uses two or three Grade 8 flat washers between the drum and axle nut. Been that way for years, and drives the piss out of it. Axle nut is still tight as a drum (no pun intended). _________________ 1800 Type 4 Berrien 295
Posted: Thu Feb 26, 2015 7:07 pm Post subject: |
Washers work. I didnt like them because I couldnt get the exact fit to match the drum and snugly fit the stub. It looked ghetto so I did the spacer deal. Smooth factory look. |
Posted: Fri Feb 27, 2015 5:17 pm Post subject: |
I ended up spinning a few drums. Tore the splines right out of them. Ya do what ya gotta do but always safety first. |
Posted: Sat Feb 28, 2015 5:58 am Post subject: |
I can see that happening with the reduced shear area of the splines from shortening the drums. '67 and older drums had a hard enough time as it was. Shortening them even more coupled with the less than average material some were/are made with...add a little power, and boom! No more splines. _________________ 1800 Type 4 Berrien 295
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Sat Feb 28, 2015 6:38 am Post subject: |
If you want to keep from spinning splines out of drums.... TORQUE THEM to 237ft-lbs...
