Molly1973 Samba Member
Posted: Tue Feb 24, 2015 1:34 pm Post subject: Difficulty in Rolling Window Up |
...so, on my passenger door ('73 Super), whenever the window is about an inch from being completely rolled up, it gets extremely difficult to roll (almost feels like I am going to break the handle). Any ideas?? |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13842 Location: White Mountains Arizona
Posted: Tue Feb 24, 2015 2:30 pm Post subject: |
The best thing to do is to remove the door panel and plastic vapor barrior and lubricate the mechanism in the door. It is called the window regulator. Anything you find associated with the window up and down. It will be smooth as silk when completed. Take an afternoon and do it. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Posted: Tue Feb 24, 2015 3:03 pm Post subject: |
What should I lubricate it with? |
hopkin Samba Member
Joined: June 25, 2012 Posts: 2469 Location: Ottawa, Ontario
Posted: Tue Feb 24, 2015 3:09 pm Post subject: |
This thread has some nice info about disassembling the door and lubricating the regulator:
http://www.thesamba.com/vw/forum/viewtopic.php?t=335018 _________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
1991 Honda Civic (Original Owner)
1996 'Open Air' Mexican Beetle (current)
2015 Golf (current)
2017 Dune Edition (daughter's car) |
Posted: Tue Feb 24, 2015 3:19 pm Post subject: |
Thank you for that....very good write-up! |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31266 Location: Hot Arizona
Posted: Tue Feb 24, 2015 5:24 pm Post subject: |
I've done the clean/lube thing on my 1971 VW Convertible every few years (four roll-up windows). Especially because Convertible window regulators are EXPENSIVE, and one of the ones for the rear is no longer available new. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
KAmes Samba Member
Joined: February 16, 2014 Posts: 876 Location: Illinois
Posted: Tue Feb 24, 2015 6:02 pm Post subject: |
You'll be surprised how much difference clean and lube can make. I couldn't raise my window at all without grabbing the glass and helping it as I cranked. No new parts, just wiped the gunk off all the moving parts and applied some fresh grease, smooth as can be now. |
jlex Samba Member
Joined: January 23, 2009 Posts: 2902 Location: NW Pennsylvania
Posted: Wed Feb 25, 2015 7:44 am Post subject: |
Right. If you force it, you'll break the mechanism then you're into a whole new can of worms. I used WD40 initially to break down the old grease and crud. After it was cleared, I used a heavier, but not too heavy white lithium grease (like assembly lube) on the mechanism. _________________ jlex.
'70 std. "Elsie"
'88 Carrera |
68IHscout Samba Member
Joined: March 10, 2010 Posts: 3122 Location: santa ana ca
Posted: Thu Feb 26, 2015 1:34 pm Post subject: |
Best to take it out ,remove all that old grease that sometimes hardens up ,then regrease it ,it will work just like new... |
Posted: Thu Feb 26, 2015 3:49 pm Post subject: |
Looks like a project.....but it needs done.... |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5360 Location: Lefty, CA
Cusser Samba Member
Posted: Thu Feb 26, 2015 8:12 pm Post subject: |
Molly1973 wrote: |
It's not that bad Molly. Buy a door panel clip removal tool, under $10, worth it. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
hopkin Samba Member
Posted: Fri Feb 27, 2015 6:06 am Post subject: |
While you're at it, you may want to vacuum out the bottom of the door, clean up as much surface rust as you can and apply some POR-15 at the bottom and new sound deadener material (I used Quick Roof from Home Depot).
Don't forget to replace the vapour barrier. You can cut out new ones from any thicker plastic material you can get at Home Depot or Lowes.
When I did my scrapers I also ordered a bunch of these (see links below from Wolfsburg West) as a few always break when you remove the door card:
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=113881000
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=N143893 _________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
2015 Golf (current)
Cusser Samba Member
Posted: Fri Feb 27, 2015 6:25 am Post subject: |
Take off the two Phillips screws; one is hidden under plastic and holds the window crank on, the other is under the plastic for the inner door release pull. Put like two layers of masking tape over the paint just above the panel to avoid scratching (like stacked to make wider swatch).
I start at the bottom, use the panel tool too release the clips, and work your way around the door. Once all are released, grab the door-close handle and pull slightly towards you as you lift the panel up and out (the pulling towards you is so the top row of clips doesn't scratch the paint/masking tape).
Then gently peel back plastic moisture barrier and get cleanin' and lubin' !!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
