pitdad22 Samba Member
Joined: February 24, 2015 Posts: 12 Location: Eugene, OR
Posted: Tue Feb 24, 2015 9:30 pm Post subject: 2027 build questions for a VW newb |
Hi all.
I've rebuilt small block chev's before but I'm new to VW's.
I have a sandrail that I recently purchased for my daughter to run that had a worn out stock 1600 in it with a broken valve spring tired crank and cracked heads.... So on....
I would like to upgrade the engine without totally blowing my budget but I also don't want to do it twice. I've been doing a bunch of reading and it sounds like the best thing to do is NOT just throw slip in cylinders but to go ahead and machine the case for 90.5's and since the crank is tired I was thinking of stroking it while I was at it probably have the clearance job done at the same time by Rimco or VW brothers or???
I was looking at the SCAT Volkstroker III Cast setup which is a 2027cc setup with 90.5's and a 78.8mm crank. I was thinking the SCAT C25 cam to keep the power down low since with the cast crank and relatively stock heads it won't be an RPM screamer.
My heads are stock dual port that I was going to put the rocker shim kit on and get rid of the wavy washers. I have dual Dellorto FRD 34 carbs. Tranny in the sandrail is a 3 rib bus IRS bus tranny.
But I have a few questions for all of you that are much more experienced than I...
Is this a decent engine setup that should be a good combo for sand?
When adjusting the deck height what am I shooting for?
How to you determine the length to trim the push rods too?
I've read that I should stay with the 8mm head studs to allow stretch and prevent pullout... do I need case savers installed or are heli-coils just needed for fixing a pulled thread?
Why can't you just buy the right crank, rod and piston combo with the wrist pin in the correct location to keep from shimming cylinders???... sorry chevy guy whinning...
Any advice does this all sound correct, anything else I need to know??? |
Posted: Tue Feb 24, 2015 9:43 pm Post subject: Re: 2027 build questions for a VW newb |
Post a picture of your case.
Do NOT use a cast crank. The forged crank will cost another $100, and is more than worth it.
If you are going to clearance the case, go 82mm stroke (not 78 ). Clearancing is the same for both.
Different cases require different "clean up cuts" when boring for larger cylinders, so there is no "Standard" to go on. It is what it is. Don't fight it. Order shims AFTER you mock up the engine. Same with push rod length. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Posted: Tue Feb 24, 2015 10:16 pm Post subject: case pics |
Question regarding the push rods. SCAT sends them with the kit are those designed to have end caps pulled out and then cut down the tubes on a lathe? And... how do you know what length they should be?? what should the rocker geometry be in the TDC condition?
Anyway here are the case pics:
Thanks! |
ekacpuc Samba Member
Joined: December 08, 2010 Posts: 1414 Location: ketchikan alaska
Posted: Wed Feb 25, 2015 12:05 am Post subject: |
The pushrods are the ones you cut to length. One end is left off. Remember chromoly PRs are set to a loose zero lash. I prefer aluminum.
I almost bought that volksracer kit in the same size but opted to buy individual pieces to save cash and get exactly what I wanted.
The c25 was a great cam in my old 1776 (in a class 11 look alike built for trails). I didn't have to give it much throttle risking burning out and loosing traction. I'm currently waiting on the parts to build my 2007cc (for same bug) and did go with a larger cam because its a stoker you could get away with a little more. I do have a 3 rib bus transmission waiting to go in, if the cam is lazy the gears will hide it. I don't think you could go wrong with the c25 though. |
Posted: Wed Feb 25, 2015 7:27 am Post subject: |
Do you have a list of the parts you bought that I might plagarize |
stan_tichomirov Samba Member
Joined: May 24, 2005 Posts: 1719 Location: San Francisco, CA
Posted: Wed Feb 25, 2015 9:09 am Post subject: |
I test-fitted a CB 76mm crank with 5.5 SCAT i-beams I have, and it all fit together with almost no clearancing of the case. With 94mm B pistons and .060" cylinder shims the deck is at .043" -- if your case isn't decked you may not even need cylinder spacers.
I may have the crank and rods for sale soon because I've decided to attempt an 82mm crank instead.
Stan _________________ Aircooled.net
Jansen Enterprise
My 1835cc build
My budget 2276 build |
Marv [UK] Samba Member
Posted: Wed Feb 25, 2015 9:32 am Post subject: |
I've got a bus with a 2017 in it with a scat C35 cam. Bags of low end, 110hp at the flywheel and runs out of puff just past 5000 revs. It's a pretty good size. I'm running DRLA's. With the smaller FRD carbs, a C25 would do well but you would be dragging the use able rev range down towards 4500 which would probably be a good thing in a rail. I'd say your probably going to come in at around 90 hp _________________ The opinion of the author as expressed does not always reflect that of the author nor does he extend any apologies or assume any liability or responsibility for its content or lack thereof or for any lack of humour of the reader of any content at all, anywhere, ever. The reader agrees to all risk by reading it and is advised that any ‘issue’ is theirs alone as they chose to read it. |
Posted: Wed Feb 25, 2015 7:54 pm Post subject: |
Thanks for all the input!
One question I have is on the push rods are the stock aluminum push rods okay to use with a Scat C25 or 100 grind cam? When should you not use them?
And... How do I know if I need to use trim to length push rods... If I run out of adjustment screw or am I looking at a particular rocker geometry? |
Posted: Wed Feb 25, 2015 8:29 pm Post subject: |
I ran a c25 with hd single springs and stock pushrods just fine.
Search geometry for the pushrod length answer. You use a adjustable pushrod and set your valve geometry so the adjusters are in a straight line with the valves. You could shim the rockers but ideally you'll want the adjusters almost all the way screwed in when you get the proper geometry. If you get custom pushrods don't use shims, just make the pushrod the correct length without shims.
I got everything from aircooled.net. I have heads but the chamber sizes aren't right for a stroker, no squish/quench with a .080" deck and a .050ish step.
ACN L3 heads
4140 78mm crank (4140 is a compromise, at least it isn't cast)
4340 scat 5.5" rods. You want em longer than stock so u can shim for deck height instead of machining anything.
Redline weber idfs setup by John
Gasket set with flywheel seal
Flywheel shim kit
Rocker arm shim kit (have a empi solid shaft kit already, works fine)
Chromoly gland nut with 36mm head
90.5mm AA pistons/cyls (b pistons iirc, it's for a stroker)
Kolbenschmidt rod bearing
Silverline mains (steel backed)
Web 163 on a 108lsa (105 be better for you)
Scat 72g lifters
Plus I got a engine hardware kit, cam plug, oil cooler seals (gasket kits come with two) |
mcdragracer Samba Member
Posted: Thu Feb 26, 2015 2:56 am Post subject: |
My suggestion with the FRD carbs though, you should dump them and get a set of 40 Dells, if your budget able's you to, you would be so much happier, more power and much smoother. |
Posted: Thu Feb 26, 2015 3:14 am Post subject: |
mcdragracer wrote: |
It's not as big a difference as you think. Set them up properly with a balance tube for idle smoothness and you won't notice a huge difference in the low end. Sure the 40 dual twins will allow a much higher top end but at the expense of the bottom end. I'm running 36's with 32 vents and there is not a great deal of difference at the low end of the scale than of it was running 34 weber or dells.
The OP is putting it in a rail. Low end is the key and smaller carbs will deliver torque in spades. Dual twins are a pig to seal with the open engine so simplicity is also key. Dell 40's wouldn't be so good in this case _________________ The opinion of the author as expressed does not always reflect that of the author nor does he extend any apologies or assume any liability or responsibility for its content or lack thereof or for any lack of humour of the reader of any content at all, anywhere, ever. The reader agrees to all risk by reading it and is advised that any ‘issue’ is theirs alone as they chose to read it. |
SoCalJes Samba Member
Joined: November 02, 2011 Posts: 1093 Location: Broward, FL
Posted: Thu Feb 26, 2015 5:11 am Post subject: |
pitdad22 wrote: |
I was in the same boat as you were (coming from "Chevy" world ). The only reason to cut a push rod is to adjust the alignment of the geometry of the valve train. You will only know where you are at after you assemble it and then you make adjustments to get it were its supposed to be. Aluminum rods = less weight = less mass to fight valve spring float at high rpm. Same idea with light weight lifters. _________________ Jesse
71 Ghia
______________________________________
Just because it didn't come that way, doesn't mean it shouldn't have. |
jbbugs Samba Member
Joined: September 16, 2002 Posts: 2152 Location: Behind the wheel
Posted: Thu Feb 26, 2015 5:45 am Post subject: |
While you are having the case clearanced, have it drilled, tapped, and case saver installed.
Otherwise, you are wasting your time and money. _________________ Drag bus! http://www.youtube.com/watch?v=s2MOVmKdhX4
69 OG paint Transporter
73' Super Beetle Champcar Endurance Roadracer
Patina my ass, that's a Rust Bucket! |
jbbugs Samba Member
Posted: Thu Feb 26, 2015 10:05 pm Post subject: |
Thanks guys for the input. on the 34 FRD's any idea what I should jet them as a starting point elevation sea level average temp 60 deg F
I ended up starting with the 100 grind engle cam
Dual port long reach heads with 40 x 35.5 valves
90.5 pistons, 78 stroke crank, and 5.4 Rods.
I'll try and shim to about 8.5 to 1 |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Fri Feb 27, 2015 12:20 pm Post subject: |
Everyone has given great suggestions. To highlight some certain aspects of your build and since its going into a rail:
-Keep the cam light. Engle 100, Scat 25 or 35. Web might have a few grinds too.
-Lifters Id use for this build would be either Empi billets or Brazil resolence lifters. Cb carries these.
-Have the case clearanced, full flowed and case savers put in
-Invest the minimal additional $$ associated with spending on a forged crank. Many of have good experience using a cast crank, but imo its better for a forged crank in the long run. I have used some of these components and found it to be a nice bang for the buck:
http://www.thesamba.com/vw/classifieds/detail.php?id=598753
-Stock aluminum pushrods wont work without ridiculous shimming. You'll have to run CTF(cut to fit) chromoly or CTF HD aluminum pushrods and complete valve train geometry
-A weber dual 40 or Dell 40 set up is a great investment and worthwhile performance upgrade that will also give you a bump in economy/mpg. A set up HPMX can do the trick as well but Im partial to dells.
-Stock heads and valves will work fine, get them looked at if they require a rebuild. Now is the time. For another 100-150 a "fluff and buff" port job could help the power range and low end capabilities.
-If the case is clearanced, stock rods rebuilt if needed can do the trick and work just fine.
-Get the rotational parts balanced. Pistons, flywheel, crank, rods etc. An AA
"b" set will work just fine for this build.
-Converting the stock rocker assemblies to HD is a great idea.
-A Sachs clutch kit is fine for this build. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
