6721Window Samba Member
Joined: January 26, 2015 Posts: 8 Location: Pleasant Grove, CA
Posted: Fri Feb 27, 2015 11:33 pm Post subject: Sunroof won't stay closed |
Hi folks. The sunroof on my bus won't latch shut and slides back as I drive even though I turn the mechanism handle as far as I can. On my prior busses, I remember the sunroof latching shut with almost a click or snap feeling and then holding closed. Does anyone have any suggestions on how to make the latch stay closed? Is something stripped or broken in the mechanism? Any suggestions would be helpful. Thanks. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69824 Location: Phoenix Metro
Posted: Sat Feb 28, 2015 8:55 am Post subject: |
I only have my '55 to compare but it doesn't click shut.
The latch does have a hook though so if it's totally shut, it can't slide backwards, the hook is inside the body holding it closed.
When you turn the handle to the closed position, even if the sunroof if partially open, it pulls the front edge down and holds it against the sliders with pressure. Does your Bus do that?
If you can, open it 1/2 way, turn it shut, then post some pics of the front so we can see if it looks locked down.
I tried to find a couple photos and only came up with this:
Hook and fully open photo:
_________________ How to Post Photos
Posted: Sat Feb 28, 2015 9:19 am Post subject: |
Thanks Everett. I have the hook piece, it slides into the section in the roof and then when I turn the handle, it pulls tight. But then when I drive, it comes loose and slides back. Anyone else have this problem? I just want the sunroof to stay closed. |
G-wood Todd Samba Member
Joined: January 11, 2005 Posts: 1047 Location: Colorado
Posted: Sat Feb 28, 2015 9:35 am Post subject: |
When I close mine, it does feel like it "snaps" in place. There is nothing in the handle itself that "locks". I think its a combination of the top bow sinking down (as Everett mentioned) as the sunroof tightens and stretches tight. I believe its this combo that keeps the sunroof latched in place. _________________ and take the kids for instance "Are we going in the Volkswagen bus?" and they say "Yay!" and clap their hands and if it's a glorious day you can slide the sunroof back and let a little of the glory in and all of a sudden, it stops looking funny.
-Volkswagen ad |
Posted: Sat Feb 28, 2015 9:59 am Post subject: |
I snapped a few shots for reference.
Mechanism and hook in the closed position.
Mechanism and hook in the open position.
-Volkswagen ad |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Sat Feb 28, 2015 11:42 am Post subject: |
6721Window wrote: |
I have exactly this issue, but with a '62 beetle. When the weather improves I intend to recover and refurbish the thing. I figured it had something to do with breaking my car out of a 6-year slumber in it's PO's driveway. It sat unmoved in the sun. The cover was so stiff it barely opened (even though plenty warm)- and tore out where each of the bows are inserted. I thought it would soften- but it really has not. After a few open/closing cycles, the thing is damn near impossible to fully latch closed- but yet it is weather tight. It will wiggle its way open at freeway speeds. I feels like I'm about to break the handle in the final push to latch it closed. I'm confident it needs lube, a softer cover and some love. _________________
EverettB wrote: |
FU#5 |
Posted: Sat Feb 28, 2015 3:11 pm Post subject: |
hitest wrote: |
6721Window wrote: |
I have exactly this issue, but with a '62 beetle. When the weather improves I intend to recover and refurbish the thing. I figured it had something to do with breaking my car out of a 6-year slumber in it's PO's driveway. It sat unmoved in the sun. The cover was so stiff it barely opened (even though plenty warm)- and tore out where each of the bows are inserted. I thought it would soften- but it really has not. After a few open/closing cycles, the thing is damn near impossible to fully latch closed- but yet it is weather tight. It will wiggle its way open at freeway speeds. I feels like I'm about to break the handle in the final push to latch it closed. I'm confident it needs lube, a softer cover and some love. |
I wonder if too stiff of tension on the OP's cover would create it to pull back and open? _________________ and take the kids for instance "Are we going in the Volkswagen bus?" and they say "Yay!" and clap their hands and if it's a glorious day you can slide the sunroof back and let a little of the glory in and all of a sudden, it stops looking funny.
-Volkswagen ad |
Posted: Mon Mar 02, 2015 4:24 pm Post subject: |
Thanks for the comments. Everett, I pulled it back and worked the mechanism. When it is disengaged from the bus body (i.e., the hook is free), it "snaps" shut like my other busses did. Then when I try to close it and secure it to the bus, it won't go all the way. There must be some kind of obstruction that is preventing it from going all the way. It's like the headliner is too thick or there is something between the sunroof and the roof metal that won't let it close. Oh well. I'll press on and figure it out. Don't want to mess with the headliner though since it is new. |
56reddy Samba Member
Posted: Mon Mar 02, 2015 4:41 pm Post subject: |
Sounds like the sunroof cover may be installed too short. This would keep the header bow from reaching the roof metal, and keep you from being able to fully turn the handle. _________________ New Vintage Specialist.
1974 ghia convertible
1981 Vanagon Westfalia
Making VW’s Fun Again.(MVFA) |
Posted: Mon Mar 02, 2015 4:58 pm Post subject: |
56reddy wrote: |
Sounds like the sunroof cover may be installed too short. This would keep the header bow from reaching the roof metal, and keep you from being able to fully turn the handle. |
This came to my mind too.
Or:
If the cover is new, it could be super tight, you may need to set it out in the sun for a while to try and stretch it out. _________________ How to Post Photos
Posted: Mon Mar 02, 2015 9:16 pm Post subject: |
The point about the canvas being too tight is a good one. When I try to close it as hard as possible (without breaking anything), the front bow is raised about 1.5 inches off the top of the bus. It doesn't press down like it should and seal the sunroof to the roof. I think you guys are right. Any thoughts on a fix? |
Posted: Tue Mar 03, 2015 5:53 am Post subject: |
A possible fix could be to loosen the hold down strip at the rear of the sunroof. This will allow the the canvas to move as you tighten the handle. Once the sunroof is fully closed then tighten the rear strip. _________________ New Vintage Specialist.
Bad Hippie Samba Member
Posted: Tue Jun 09, 2015 8:57 pm Post subject: |
There is a spring that should be attached to the hook in the guts of the header bow center mechanism. It appears one of its functions is to hold the hook over to the side, keeping it holding on to the socket in the roof. If the spring is broken or missing that hook may just flop around and not hold on. I see from your photo you don't have a headliner on the sunroof (just like mine) so it will be cake to just look to see if the spring is in good shape. It's not hidden or anything. While you're in there operate the handle. Make sure all of the pivot points are functional (there are quite a few). I found many of mine to be frozen, which would definitely effect the clamping action. |
