2387engine Samba Member
Joined: March 01, 2015 Posts: 4 Location: Rosecity,Michigan
Posted: Sun Mar 01, 2015 7:59 pm Post subject: tranny |
Hi out there my discussion is on a tranny workin on installing the gear cluster and housing shims at pinion on inside tranny how to figure out the shim cuz the trany working on I thought had one thin shim and a thicker one with a flat on it installing it together the pinion binds after tightened so how would I figure this out Anyone know |
Dougy Dee Samba Member
Joined: August 21, 2004 Posts: 1668 Location: Niagara Region, CANADA
Posted: Mon Mar 02, 2015 6:50 am Post subject: |
The thin one is the shim that goes on the pinion bearing before you install it in the case the thick one is a washer that goes on before the big nut on the pinion bearing you may be in over your head but you know that by now thankfully your spelling skills are adequate and I figured out what you were saying I think oh and it binds up because the thick shim is in the wrong location
Tough to read, isn't it! Do a search and learn where the comma and period keys are on the key board |
andrewvwclassic Samba Member
Joined: January 25, 2012 Posts: 920 Location: los angeles
Posted: Mon Mar 02, 2015 7:39 pm Post subject: |
You need a good service manual man dont you know better than to do that on your own. |
Posted: Fri Mar 06, 2015 1:35 am Post subject: |
I say agin get a manual if you dont like posive reinforcement and harm reduction dont post on a public forum. and please dont pm with retarded ass remarks treat my pm as a telephone and a number to someone you dont know and does not want to talk to you. I dont care if you forgot if you had a manual you would not need to remember. |
