mrbuchholz Samba Member
Posted: Mon Mar 02, 2015 8:16 am Post subject: Red light flickering at higher rpms |
My 1967 generator light flickers at higher rpms, goes off when low and idling. The regulator does not have a brown ground wire going to it. It has the 3 wires on the front side and a wire in the DF and a wire in the D+ on the back side. Should there be a ground wire from the body to the regulator.
The belt seems fine, but maybe one shim out will take care of the flicker? |
mukluk Samba Member
Joined: October 18, 2012 Posts: 6985 Location: Clyde, TX
Posted: Mon Mar 02, 2015 9:49 am Post subject: |
Doubt it's a ground problem as it's working at lower rpms. It could be your belt slipping, but it'd have to be slipping pretty bad for the light to come on. My thought would be worn generator brushes or their springs. _________________ 1960 Ragtop w/Semaphores "Inga" |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 33875 Location: Conejo Valley, CA
Posted: Mon Mar 02, 2015 10:38 am Post subject: |
Agreed, check the brushes and spring tension. Also look at the commutator and see if the gaps need to be undercut.
pdowty68 Samba Member
Joined: April 07, 2014 Posts: 224 Location: Long Island, New York
Posted: Thu Mar 05, 2015 7:21 am Post subject: |
I agree, replace the brushes and the springs. |
Posted: Sat Mar 07, 2015 4:40 pm Post subject: |
I went ahead a replaced the regulator with a newer one from my previous 67. It took care of the flickering. The old one when I turned it over the thingymajig on the backside was very worn and almost broken, So it looks like that was the trouble. Now if all the rest of the bug was that easy. |
planenut Samba Member
Posted: Sat Mar 07, 2015 8:41 pm Post subject: |
Yep, sounds like the brushes bouncing. |
