cougarwatchmen Samba Member
Posted: Mon Mar 02, 2015 12:34 pm Post subject: Green Distributor Wire |
I'm not new to VW or thesamba, this is a new account so don't bash me.
I'm having problems with my distributor on a 1973 Beetle. There is a green wire that broke off but I can't figure out where the heck it is suppose to connect to. Any help is greatly appreciated. Thanks.
Http://s1104.photobucket.com/albums/h333/turtle_vw...111521.jpg |
volkswagen_bug Samba Member
Joined: November 04, 2008 Posts: 759 Location: Sumter, SC
Posted: Mon Mar 02, 2015 12:45 pm Post subject: |
The green wire goes from the distributor to the NEGATIVE side of the coil. _________________ 1968 Volkswagen Bug w/ 1600 Dual Port
"It’s better to give than to receive. Especially advice." -Mark Twain |
Posted: Mon Mar 02, 2015 12:49 pm Post subject: |
Thank you. Obviously you can't start the car without it connected correct? |
Posted: Mon Mar 02, 2015 12:51 pm Post subject: |
I'm not sure about that. I know when I was younger my condenser went out while at a friends house. I was able to drive it home in first gear, but it was missing like crazy. You'd just have to try it. _________________ 1968 Volkswagen Bug w/ 1600 Dual Port
Posted: Mon Mar 02, 2015 12:52 pm Post subject: |
That's my issue it's not starting. It turns over but doesn't start.... |
Posted: Mon Mar 02, 2015 12:53 pm Post subject: |
I doubt it will start. You'll need to replace the wire. You should be able to get it from your local auto parts store. You could always half tap the condenser wire. They're the same circuit. Both wires go to a spade terminal inside of the distributor. From there the points connect to the terminal. _________________ 1968 Volkswagen Bug w/ 1600 Dual Port
zoobyshoe Samba Member
Joined: June 26, 2014 Posts: 461 Location: San Diego, Ca.
Posted: Mon Mar 02, 2015 1:22 pm Post subject: |
Just buy a new condenser. They're not expensive. That wire is attached. In fact, I doubt you can just buy the wire by itself.
Just make sure you get the right condenser for your distributor. The 009 condenser is different than the one for the distributor with vacuum advance. One won't fit on the other. |
Posted: Mon Mar 02, 2015 1:44 pm Post subject: |
Thank you guys. I'll just buy a new condenser tomorrow. Dropping my 67 off at bugformance anyways. IF I have more issues, I'll let yall know.
Thanks again.
Last edited by cougarwatchmen on Mon Mar 02, 2015 2:03 pm; edited 1 time in total |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Mon Mar 02, 2015 1:55 pm Post subject: |
And where have you been that you assume you might be bashed for being a newbie?
You're in The Samba now. You're an ACVW owner. We won't bite your head off.
Welcome!
By the way, it would be better if you purchased a good Bosch condenser for your distributor. Get whatever Autozone of Napa has. That will get your running. But get a spare--and order it from Jbugs, Wolfsburg West, whomever, and make sure it's a proper Bosch brand.
Tim |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Mon Mar 02, 2015 2:29 pm Post subject: |
The green wire connects your points to the coil. Without it connected the points will not tell the coil to fire the spark plugs. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Fri Mar 06, 2015 9:05 am Post subject: |
Thanks everyone, got the car fired up. Just need a massive tune up. It's been sitting for almost a year now. |
