mrjim1 Samba Member
Joined: June 08, 2010 Posts: 1 Location: Springfield, Ohio
Posted: Mon Mar 02, 2015 4:31 pm Post subject: Good heat in my 1967 VW. |
I have discovered a way to have heat in my 1967 VW. It is such a simple idea I don't know why heat was ever an issue. If you cover up the cold air intake in your house furnace, you will soon feel cold because you don't get any air flow through the system. |
spanky324 Samba Member
Joined: September 28, 2006 Posts: 1070 Location: Greeley Pa
Posted: Mon Mar 02, 2015 4:45 pm Post subject: |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16754 Location: State College, PA
Posted: Mon Mar 02, 2015 5:35 pm Post subject: |
I think you are saying crack the window or vent? I do and hot air blasts in. _________________ D-Dubya Manx clone - 63 Short pan,1914.
greasemonkey Samba Member
Posted: Mon Mar 02, 2015 6:14 pm Post subject: |
Are u saying keep your foot on the pedal?? |
Dynaflash Samba Member
Posted: Mon Mar 02, 2015 7:15 pm Post subject: |
Please explain |
wcfvw69 Samba Purist
Posted: Mon Mar 02, 2015 8:15 pm Post subject: |
andk5591 wrote: |
I think you are saying crack the window or vent? I do and hot air blasts in. |
This^^ _________________ Contact me at [email protected]
The Samba member since 2004.
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Mon Mar 02, 2015 8:29 pm Post subject: |
Maybe he removed the pillow from the back of his fan shroud inlet? _________________
EverettB wrote: |
FU#5 |
bluebus86 Banned
Posted: Mon Mar 02, 2015 8:35 pm Post subject: Re: Good heat in my 1967 VW. |
mrjim1 wrote: |
Does anyone else detect the effect of mind altering drugs on the above post?????? _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
fla2smoker Samba Member
Joined: December 31, 2011 Posts: 574 Location: Parrish, Florida
KTPhil Samba Member
Joined: April 06, 2006 Posts: 33883 Location: Conejo Valley, CA
Posted: Tue Mar 03, 2015 10:53 am Post subject: |
Or the heat was from directing the exhaust directly into the cabin. |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11053 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Tue Mar 03, 2015 11:17 am Post subject: |
Battery powered Carbon Monoxide detectors are available and reasonably priced ...
Buy one today... and save your brain cells.
No air flow is no air flow... makes no difference if you cover the inlet or outlet...
Crack window to let the warm air flow..and the fumes out..
All outlined in the owners manual..
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
bluebus86 Banned
Posted: Tue Mar 03, 2015 11:54 am Post subject: |
VOLKSWAGNUT wrote: |
excellent advice on the CO detector. I occasionally place my home CO detector in my cars to test for Co leaks in the heater system. I noticed an exhaust smell in my 914 once, used the home Co detector and sure enough it was a very bad high reading. The heat exchanger was cracked, raw exhaust going into the cabin!!!!
Keep in mind that the Co detector may pick up trace amounts of CO in the car simply because of the tail pipe exhaust getting in thru an open door or window if the car is idling, not being driven depending on the wind. when I had the faulty heat exchanger the detector went into full alarm mode, much more than a trace reading.
if you eyes burn when the heater is on, that is a bad sign!!!! Periodic use of the detector is a good idea, test your VW's heater!!!!! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Tue Mar 03, 2015 12:01 pm Post subject: |
bluebus86 wrote: |
if you eyes burn when the heater is on, that is a bad sign!!!! Periodic use of the detector is a good idea, test your VW's heater!!!!! |
I mainly noted it as nod ...due to the rambling initial topic stater statement.. as it may indicate.. .. an issue...... but yes.. a CO detector in a vehicle to periodically check is not a bad idea either...
I often wonder... if VW put the note about venting a window for two reasons...
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11739 Location: Redding, CA
Posted: Tue Mar 03, 2015 12:06 pm Post subject: |
Sometimes the words don't seem clear to the reader--not as clear as the writer intended.
In this case, however, we all knew what the OP was speaking of ,
Tim |
Posted: Tue Mar 03, 2015 2:52 pm Post subject: |
Just an FYI regardin CO detectors. Our geriatric dog ended up with ringworm which come from spores....so its a fungus kind of skin condition. During the treatment, my wife has been Lysoling the hell out of the house. What we discovered is that Lysol will make our CO detector go up. did some research and there are quite a few things that will show an increase in CO (but there really isnt)
That being said, I would suggest using a non running test as your baseline in case you have something in the car that gives an elevated reading. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Digger89L Samba Member
Joined: May 16, 2013 Posts: 1130 Location: Western Canada (SK)
Posted: Wed Mar 04, 2015 10:10 pm Post subject: |
Yes...I agree completely: rolling a window down an inch or so, or cracking a vent window, can hugely improve airflow from the heating system. Did it all the time back in the day - makes a lot of sense really: if you have to crack a window to relieve the air pressure so its easier to close a door, or if the vehicle is airtight to the point where it will float, then there's likely not enough natural air leakage to allow the engine cooling fan to force hot air into the cabin in an efficient manner. As I've mentioned before, I've owned and driven 59, 63, 66 and 68 beetles (none with auxiliary gas-fired heater) back in the 60's through these bitterly cold western Canadian winters (-42C with the windchill today!) and managed to get enough 'natural' heat into them to avoid frostbite for 6 months of the year! |
pdowty68 Samba Member
Joined: April 07, 2014 Posts: 224 Location: Long Island, New York
