JDub113 Samba Member
Posted: Mon Mar 02, 2015 6:32 pm Post subject: Brake booster rubber gasket/hose |
In the brake booster vaccuum line, there are segments that come together so the line slips over the other. Its the male end of the hose that has the short rubber over it to make the seal. I don't know where to source it and am probably calling it the wrong thing. Anybody have a link or lead? Thank you _________________ 84 Wolfsburg Edition Westy
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Tcash Samba Member
Posted: Mon Mar 02, 2015 8:23 pm Post subject: |
What number are you asking about?
Posted: Mon Mar 02, 2015 9:16 pm Post subject: |
I don't see it clearly labeled. The one I specifically need goes over the outlet on the back of the Brake Booster. The hard plastic hose goes over the rubber sleeve that is on the break booster nipple. Part 76 would fit over the rubber sleeve. There are probably 3 other rubber sleeves in the brake booster lines where two hoses come together. This secures the seal between the two lines and the tan plastic clamp with the screw in it clamps over where the two hoses connect male to female.
Actually, I think its part 63. _________________ 84 Wolfsburg Edition Westy |
Posted: Tue Mar 03, 2015 6:52 pm Post subject: |
I don't see this part anywhere. Any help? _________________ 84 Wolfsburg Edition Westy |
Posted: Tue Mar 03, 2015 8:51 pm Post subject: |
I know the piece you are speaking of. It is a thin rubber bushing that fits over the plastic hose. Never bought one, but I would guess that a phone call to BusBoys or Bus Depot would get you one pretty quick. |
Posted: Tue Mar 03, 2015 9:35 pm Post subject: |
Thanks, Alan. Its number 211-611-833 D. _________________ 84 Wolfsburg Edition Westy |
Tcash Samba Member
Posted: Tue Mar 03, 2015 10:02 pm Post subject: 211 611 833 D Brake Grommet |
http://www.germansupply.com/xcart/customer/product.php?productid=17051&cat=&page=1
"Rubber grommet for power brake servo (booster) hard plastic hose. This grommet goes around both ends of the brake servo check valve, also in the hard plastic hoses where they attach to the metal pipe in the chassis or the brake servo itself. The check valve is located in the engine bay or on early models, just in front of the firewall. Depending on the year of your bus there are up to 5 of these used." |
Posted: Tue Mar 03, 2015 10:42 pm Post subject: Grommet |
This is also used on Vanagon fuel filler neck pipe Both these vendors also stock them.
www.van-cafe.com
www.wolfsburgwest.com
But as I said check with Walter @ BUSBOYS since it's closer to you!
Pick up the PHONE and make that call _________________ V.W.owner since 1967 |
Hoody Samba Member
Posted: Tue Mar 03, 2015 10:57 pm Post subject: |
Go to Germansupplys website. There are are a 2 different rubber bushings that are used in this application. They look very close to be the same part but are actually different. I have a 78 as well. Original German is still available. I would advise against buying re-popped. Hope this helps. |
Posted: Sat Mar 07, 2015 9:45 pm Post subject: |
Got all 5 installed today. What a pita. Needed to be done for sure. I hope you all check yours if you've never done it. _________________ 84 Wolfsburg Edition Westy |
