jamescowell Samba Member
Joined: April 19, 2014 Posts: 30 Location: United Kingdom
Posted: Tue Mar 03, 2015 6:15 am Post subject: Bogging at low RPM |
Noticed when driving to uni this morning that my bug has a habit of bogging down/stumbling/hesitating when I apply power at low RPM, i.e when pulling away from the lights or occasionally when coming out of a corner in say 3rd gear. Sometimes it backfires too. When the RPMs increase, the engine runs fine again with no noticeable loss of power. I've recently had the car serviced.
Any thoughts at what could be causing this?
Engine is a 1200 'D', carb is a Solex H30/31PICT, dizzy is a 009. |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13846 Location: White Mountains Arizona
Posted: Tue Mar 03, 2015 6:50 am Post subject: |
Is the carburator icing up? Look below the carb at the intake, is it icy? _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Posted: Tue Mar 03, 2015 7:58 am Post subject: |
No, the intake manifold is warm and I've checked previously that the heat risers are functioning. |
Randy in Maine Samba Member
Posted: Tue Mar 03, 2015 8:25 am Post subject: |
I would be looking at the idle jet to see if there is a bit of crud in there. |
MacLeod Willy Samba Member
Joined: February 18, 2014 Posts: 933 Location: Ontario Canada
Posted: Tue Mar 03, 2015 8:37 am Post subject: |
I would check the accel pump, the initial timing, dwell and see if the vac advance is working properly.
Especially if it was good before the service was performed |
Volks Wagen Samba Member
Joined: February 13, 2013 Posts: 2926 Location: Germany
Posted: Tue Mar 03, 2015 1:48 pm Post subject: |
Timing possibly? What did they do as part of the service? (Willy Mc it's a 009 so no vac advance.) _________________ 1973 1303 with AB-motor - sporadic
reconstruction as time permits, 1986 ex-Bundeswehr Doka - on the road again.
I'm definitely, probably, the worlds greatest lover.
Aithníonn ciaróg ciaróg eile. |
Posted: Tue Mar 03, 2015 3:40 pm Post subject: |
Volks Wagen wrote: |
Timing possibly? What did they do as part of the service? (Willy Mc it's a 009 so no vac advance.) |
ooops, didn't see that. No wonder the vac advance didn't work properly |
hava Samba Member
Posted: Tue Mar 03, 2015 7:35 pm Post subject: |
I have the 009 and h30/31 combo, I was having the same trouble so I put a little more advance and it fixed it.
I loosened the distributor and turned it counter clockwise very slightly - 3mm or so. |
Posted: Wed Mar 04, 2015 7:57 am Post subject: |
hava wrote: |
I'll try that, thanks! Noticed my coil is quite old too, could this cause similar problems? Just a thought... |
Posted: Wed Mar 04, 2015 1:38 pm Post subject: |
jamescowell wrote: |
hava wrote: |
If you are getting a good blue/white spark out of it then it's probably fine. _________________ 1973 1303 with AB-motor - sporadic
