M113 Samba Member
Joined: August 12, 2003 Posts: 362 Location: Dripping Springs, TX
Posted: Wed Mar 04, 2015 2:39 am Post subject: Cosmics on Notch |
Been out of the loop a bit so I don't know the answer to my question, and I did a search but no specifies what they are running.
My question is if I run the CIP Porsche Cosmics, do I need to use a long axle or short axle. I know with Raders it's short axle, but I think the offset is different and more backspace on Cosmics. So long or short axle? Anyone know? _________________ Joe -----------
68 Ghia Vert |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Wed Mar 04, 2015 8:16 am Post subject: |
Give us a 'link' to the wheel you are contemplating buying, but the 15" Cosmics are not that wide or deepset I don't think. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Erik G Samba Member
Joined: October 16, 2002 Posts: 13280 Location: Tejas!
vwfye Samba Member
Posted: Wed Mar 04, 2015 9:03 am Post subject: |
4 or 5 lug or porsche version? _________________ 64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3" |
notchback Insensitive Jerk
Joined: December 16, 2003 Posts: 7024 Location: Behind the Zion Curtain
Posted: Wed Mar 04, 2015 9:19 am Post subject: |
And what color is the car? _________________
zeen wrote: |
Arguing with johnnypan is like mud-wrestling a pig. After a while you realize he just enjoys playing in the mud, winning the contest is not the point. |
FU#3 |
M113 Samba Member
Posted: Wed Mar 04, 2015 10:04 am Post subject: |
http://www2.cip1.com/ProductDetails.asp?ProductCode=C32%2DCOS%2D5515%2DBM
Tire size not sure either. I guess 185 65 15 in the rear and something a little smaller in front.
Color is a secret. I want to post a pic in a new thread to see if some other questions can be answered. _________________ Joe -----------
68 Ghia Vert |
squaretobehip Samba Member
Joined: August 23, 2004 Posts: 3693 Location: San Jose, CA
Posted: Wed Mar 04, 2015 10:41 am Post subject: |
I have short axles in the rear, and had to space them out to keep the tire and rim from rubbing. IIRC, I used 1/2" spacers. _________________ 1963 Notchback - Ruby Red
1963 Squareback - Pearl White
1965 Squareback - Baltic Blue
Follow ISP West on:
Instagram - @ispwest - www.instagram.com/ispwest |
Posted: Wed Mar 04, 2015 10:52 am Post subject: |
I'm running 185X60 & 205X70 on my similar spec 2.0 liters on my lowered square. _________________ https://imgur.com/user/FisherSquareback/posts
M113 Samba Member
Posted: Wed Mar 04, 2015 10:58 am Post subject: |
Mike is that with long axles? _________________ Joe -----------
68 Ghia Vert |
Posted: Wed Mar 04, 2015 11:07 am Post subject: |
My '69 is IRS, but I think they have similar fender clearance? _________________ https://imgur.com/user/FisherSquareback/posts
Air-Cooled Head Samba Member
Joined: October 15, 2002 Posts: 4070 Location: Chicago Suburbs
Posted: Wed Mar 04, 2015 11:49 am Post subject: |
IIRC, all swing T3s were born long ax. _________________ Everything known to man has been written.
Readers are Leaders! |
M113 Samba Member
Posted: Wed Mar 04, 2015 12:02 pm Post subject: |
I know they are all long axle. But I'm in the middle of putting a tranny together and was wondering if I should put long axle or short axle on for the Cosmics. When I did the JGE Raders a few years ago I needed to put short axles on for more room. But the cosmics seem to have more backspace so I was wondering if this time I need long axles. _________________ Joe -----------
68 Ghia Vert |
Posted: Wed Mar 04, 2015 12:18 pm Post subject: |
I think 5.5" ET45 wheels will fit fine on a KG w/long axles. Mike doesn't really need short axles it doesn't look like from this pic?
turbomicrowaves Samba Member
Posted: Wed Mar 04, 2015 4:27 pm Post subject: |
What size tire do you want to run? I have short axles on my car and I'm running gas burners with a 35mm offset and 205/65/15 tires. I just recently added 1/8" spacers to shim the wheels out so they don't rub on the spring plate and subframe. I believe the cosmics have a 45mm offset which is only 1mm less than a stock wheel, but they are an inch wider. I'm sure you would have no problems with staying long axle if you run the cosmics with a 195 or smaller. _________________ '68 Sunroof Squareback
"There are no pieces"
OCT3 - Orange County Type 3's |
M113 Samba Member
Posted: Wed Mar 04, 2015 4:51 pm Post subject: |
I was thinking 185 60 in rear I think that is the size close to stock, front unsure. I had 145/ 65 once, and I liked the look of the tire on the rim but had a lot of rubbing issues. So not sure what size in front. Maybe 165 50? _________________ Joe -----------
68 Ghia Vert |
Yeti69 Samba Member
Posted: Fri Mar 06, 2015 11:50 am Post subject: |
Hi Joe,
I am using those rims on my 1966 swing axle equipped fasty. (long axle this is). 165/65/15 up front and 185/65/15 in the back. I lowered the front 3 splines which is a little too much, so some rubbing in full lock-up is the consequence. In the rear, lowered ~2 splines, there is no rubbing or whatsoever.
One important note: Using these rims on a Type 3 rear drum brake requires at least a 5 mm spacer! The outer diameter of the Type 3 drum is greater than the Type 1 drum. Due to the slight convex inner shape of the rim, the spokes hit the outer drum diameter before the center is fully seated against the drum! Ignoring this might cause fatal issues!
If you convert to Porsche 5x130 bolt pattern by using beetle rear drum setup, no issues here!
This is how it looks:
_________________ 1966 Fastback "The Volksback"
watch my Blog: http://yeti69.blogspot.com/
My Baja build Blog: http://volksstreaker.blogspot.de/ |
M113 Samba Member
Posted: Fri Mar 06, 2015 1:49 pm Post subject: |
Yeti69
Thank you. That is exactly the info I needed. By the way love the fasty.
And great tip about the rear. I have drums that are sized to t3 but porsche pattern, so probably need the spacers. _________________ Joe -----------
68 Ghia Vert |
