motorjeffrey Samba Member
Joined: March 03, 2015 Posts: 4 Location: Cinnaminson
Posted: Wed Mar 04, 2015 6:27 pm Post subject: Lifted Spindles 6" |
So I have searched this forum and other websites to only find lifted spindles that are 3 to 3.5" of lift. So it got me wondering why there are not taller ones out there or at least discussed. I am considering doing an extreme baja with large swampers on it and have looked at different combinations of lift...body plus turned front beam and raised spindles up front could get me 9" of lift. Then in the rear a 3x3 TA with body lift and atomic raised swing arms should also yield 9" of lift. Thoughts on the limits of spindles lifts...if you use a 1/4 or more steel plate...is that strong enough. Thanks for your time. |
71StandardReduction Samba Member
Joined: December 04, 2012 Posts: 715 Location: Louisiana
Posted: Wed Mar 04, 2015 7:57 pm Post subject: |
Thanks for the link. Do you think those spindles are ~6"??? Also, it is hard to tell, but what size tire do you those are? 44" TSL Super Swampers? |
KrAzY-BaJa Samba Member
Joined: May 22, 2008 Posts: 1409 Location: Sacramento CA.
Posted: Wed Mar 04, 2015 8:35 pm Post subject: |
with something like that its, All Show No Go.
it would cause so much stress under offroad conditions and fail.
Ball joins or linkpins-tie rods-arms ect. _________________ 70% of what you buy is something to start with.
ForYotaWagen: A Ford/Toyota/Volkswagen http://www.thesamba.com/vw/forum/viewtopic.php?p=4871576&highlight=#4871576 |
Brian Samba Moderator
Posted: Wed Mar 04, 2015 9:10 pm Post subject: |
71StandardReduction wrote: |
The rear is lifted 7" with the double stacked gear reduction boxes. |
Maybe that's how they got the right gearing for those 100lb tires.
_________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
