tomfreo Samba Member
Joined: May 24, 2009 Posts: 373 Location: Western Australia
Posted: Wed Mar 04, 2015 7:06 pm Post subject: Lead replacement upper cylinder lubricant |
I can't remember the circumstances when I started using "valve saver". I guess I'd been convinced it was necessary on older cars designed to run on leaded petrol.
I've since been wondering whether it's a needless expense.
Here's some promotional material describing its benefits eg. "minimizes valve seat recession", "increases fuel economy", etc.
http://www.flashlube.com/en/products/valve-saver-fluid.html
It's not very expensive - c. AU50c/US40c in 30L/9gallons of petrol. Nonetheless, I've run out of the stuff again and wondering whether I really need it.
My beetle engine is a 1600sp that was rebuilt in 1990. I don't know whether it has so-called 'hardened valves".
Any thoughts? _________________ _________________
'77 Kombi 2L dual carbs
'61 Bug 6V 1600sp |
bluebus86 Banned
Posted: Wed Mar 04, 2015 7:37 pm Post subject: Re: Lead replacement upper cylinder lubricant |
tomfreo wrote: |
Any thoughts? |
the issue with lead was primarily for soft valve seats, more common in cast iron cylinder heads where the seat was machined directly into the head, with no hardened insert. The VW with the aluminum head has always had hardened inserts. So no problem with VW valve seats.
In California we have had lead free gasoline for over 30 years I recall. No problems with the VW's I have owned all that time.
don't worry about it.
the other thing that lead helps with is that it is an octane booster. it slows the burn rate down, preventing detonation, the tetraethyl lead is some what opaque to the flame in the cylinder. now days other additives are used to improve the octane rating of gasoline. The octane rating is a measure of how well the fuel resists detonation. so it is ok to get the lead out .
_________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Thu Mar 05, 2015 10:34 am Post subject: |
Forget the lead! And be very careful handling any of the lead additives! That stuff is really bad for you. _________________ Mother Nature is a Mean Evil Bitch! |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 33875 Location: Conejo Valley, CA
Posted: Thu Mar 05, 2015 2:45 pm Post subject: Re: Lead replacement upper cylinder lubricant |
bluebus86 wrote: |
I have had all sorts of problems "back in the day" with low-lead and unleaded gas in ACVWs.
Most of the problems came about due to the very low octane of early LL/UL gas. Timing had to be retarded and/or compression ratios lowered, and they ran hotter. Early heads had troubles with valve seats and so valve jobs lasted 50K or so, not 75K like they used to. Dark days.
Then they added MTBE to gas which helped the octane but then ruined some rubber parts and polluted groundwater, so back out it came.
Whatever they add now seems to have solved the problems, and valve and valve seat materials seem to be better as well. |
Karly Samba Member
Joined: August 01, 2002 Posts: 641 Location: Australia
Posted: Thu Mar 05, 2015 3:57 pm Post subject: |
I haven't been running any in mine since I bought it about 10 years ago - which is around the time when they phased out 'super' fuel here which supposedly had lead replacement stuff in it. I do run some marvel oil through mine for the supercharger. I also do use premium fuel - I find I get better economy.
Chatting to others in the Vw club I found most don't use it. Some chuck it in cause its not that expensive and I guess it's just habit. _________________ 1960 Beetle ''Heidi" daily driver
1964 Karmann Ghia project |
planenut Samba Member
Posted: Thu Mar 05, 2015 4:32 pm Post subject: Lead replacement upper cylinder lubricant |
Had a customer one time that added a quart of Marvel Mystery Oil to his aircraft engine at every oil change. When his engine was way past recommended overhaul, we tore it down, and could still push piston pins out with our fingers, and the engine was clean. I'm a firm believer in MMO. Good stuff. |
blue77bay Samba Member
Joined: February 11, 2006 Posts: 631 Location: Brisvegas Australia
Posted: Thu Mar 05, 2015 5:26 pm Post subject: |
Just run good gas ,not that cheap regurgitated yak piss they pass off for 91,you will get cleaner internals ,better mpg and better performance _________________ I like hammers. Lots of hammers. Hammers and me go way back.
A large hammer collection is like an instant problem solver
Mark tucker wrote:,wack off as needed |
my59 Samba Member
Joined: August 13, 2003 Posts: 3780 Location: connecting the dots
Posted: Thu Mar 05, 2015 6:27 pm Post subject: |
I have a 36 hp with over 175k on it, never apart, original heads never worked on. I put lead additive in about every tank full. Dunno if it does any good but WTF it's not like the engine was designed to run on today's crap gas. I could chalk the 175k+ up to 56 yrs of religious oil changes and by the book maintenance but maybe every little bit helps. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
