pdowty68 Samba Member
Joined: April 07, 2014 Posts: 224 Location: Long Island, New York
Posted: Wed Mar 04, 2015 8:30 pm Post subject: 1960 Beetle missing chassis number |
I just got an awesome 1960 Beetle in great shape, but when I looked at the car before I bought it, and I noticed the chassis number on the tunnel was missing. On the earlier cars I believe it was stamped onto a plate, rather than on the tunnel itself. I wasn't going to let a missing number stop me from buying this beautiful car. http://www.oldbug.com/galass60.htm Let me know what you think, it doesn't bother me much but I was wondering if anyone has seen anything like this before.
Thanks,
Paul |
bluebus86 Banned
Posted: Wed Mar 04, 2015 8:36 pm Post subject: Re: 1960 Beetle missing chassis number |
pdowty68 wrote: |
Thanks,
Paul |
On my 1961 it is stamped on the tunnel, not on a plate there. There should be a serial number plate behind the spare tire. don't let this on to the DMV when you register it. some DMV's consider the chassis as what is registered, NOT the body and a missing chassis serial number may raise a Big red flag. I am not sure where the number should be on the 1960 chassis however. I think it was stamped on the tunnel, but I might be wrong. If the pan was swapped out, maybe some one removed the serial number???? maybe cause they did not want to re-register the chassis???? something is fishy me thinks, could be an innocent work around from a chassis swap thing, could be a stolen chassis????? then again maybe the 1960 is supposed to be that way, but I kind of doubt it.
good luck _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
txoval Samba Member
Joined: January 23, 2004 Posts: 3553 Location: The Woodlands, TX
Posted: Wed Mar 04, 2015 8:42 pm Post subject: |
Should be stamped... |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Wed Mar 04, 2015 8:47 pm Post subject: |
....like this
(pic borrowed from gallery)
have fun getting to know the 60 only parts _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Posted: Wed Mar 04, 2015 8:56 pm Post subject: |
60ragtop wrote: |
....like this
have fun getting to know the 60 only parts |
Can't be near as bad as a 67 Never had one but I hear some parts are hard to find. I thought 61 was the year with the bad transmission mount, because it was the first year of the non-split case trans. |
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Wed Mar 04, 2015 8:59 pm Post subject: |
60ragtop wrote: |
....like this
I "heard" that all VWs are one-year-only cars. Just sayin'. |
bluebus86 Banned
Posted: Wed Mar 04, 2015 9:17 pm Post subject: |
pdowty68 wrote: |
60ragtop wrote: |
....like this
my 1961 has 330,000 miles, and no unusual problems with the tranny mount, sure it has been replaced a few times, cause the rubber got bad turned all spongy and soft, made worse by oil contamination from tranny leaks, but that is not unusual. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Bret2094 Samba Member
Joined: March 22, 2012 Posts: 665 Location: Linden, Texas or College Station Texas
Posted: Wed Mar 04, 2015 9:32 pm Post subject: |
if it was repainted, it could have been covered up, or it coulda got really rusty. I had to wire brush and clean the hell outta mine just to get it to show up....good luck man
Bret _________________ 1959 baja beetle ragtop( going back to Full body)
1959 beetle
1960 Beetle frame Custom buggy
1962 Karmann Ghia
1967 beetle( august 66, first car)
1967 beetle (parts car)
1977 Westfalia Camper
1972 Plymouth Duster
Just another 22 year old jackass who caught the bug, and lives by the motto " NO fatchicks allowed" , I've got too many cars as is (buses N/A) |
Posted: Thu Mar 05, 2015 5:55 am Post subject: |
Bret2094 wrote: |
Bret |
It seems smooth like it was covered over. I want it to be there! Ill sleep better at night. Also, it has a choke cable installed under the carpet, rathe than through the tunnel as usual. If there is no choke cable tube in the tunnel, then its probably a later chassis, but it does have the rotary heater knob. I really hope it is the original numbers matching chassis, because she's a beautiful car and has the original engine and the correct split case transaxle. Its been very cold and snowy lately, and I got the car and towed it home from Rochester to Long Island, so it was a long weekend. But I'm very happy with the car, but because of this awful weather, I haven't had much time to "play with her" yet
Take a look at the photos of the car at the attached link.
Thanks again,
Paul |
Posted: Thu Mar 05, 2015 6:45 am Post subject: |
iowegian wrote: |
Yeah they are all one year only cars but try the parts for a 60
Tranny, front mount, keys, dipstick + 60-61 steering wheel, horn ring and horn system
just sayin' _________________ Rick
tasb wrote: |
sb001 wrote: |
Posted: Thu Mar 05, 2015 7:45 am Post subject: |
60ragtop wrote: |
iowegian wrote: |
just sayin' |
60 and 61 parts cant be as hard to find as 67 parts. When I bought the car I noticed that the horn ring was broken. I'm glad the ring is broken and its not a 64-65 wheel. Now I just need to find a 60-61 horn ring. |
60ragtop wrote: |
iowegian wrote: |
just sayin' |
panicman Samba Member
Joined: December 18, 2011 Posts: 2290 Location: Canby, OR
Posted: Thu Mar 05, 2015 8:09 am Post subject: |
There were almost 25% more 67's made than 1960's, and they are 7 years newer; 7 years less less rotted, less altered, and less likely to have been scrapped or crushed. And no one is reproducing most of the 1960 only parts. Also, 60 was the last year for a lot of stuff; screw type electrical connections, split case trans, 36hp engine, manual choke, screw connection fuse blocks, humpback tank, steel brake fluid res., older style clip elements, and more.
Glad the horn ring is broken? That's an odd sentiment. Good luck finding a replacement. _________________ Plate of shrimp |
Posted: Thu Mar 05, 2015 8:22 am Post subject: |
pdowty68 wrote: |
Also, it has a choke cable installed under the carpet, rathe than through the tunnel as usual. If there is no choke cable tube in the tunnel, then its probably a later chassis, but it does have the rotary heater knob. |
when the old cable seizes up, it is a bitch to get out of the tunnel .... dont count it out yet, the P/O mat have just given up removing the old one. You have a pretty complete car there , for the most part. Definitely a great starting point. An easy way to count the older chassis (-1959 ) out as a swap before breaking out the wire wheel is the presence of bump stops in the rear suspension. earlier cars did not have them. with the presence of the bump stops and the heater knob , it narrows you down to the 1960-1964 range, but the best thing will be to do a quick once over on the tunnel once you get the seats out of the way.
1959 beetle
1962 Karmann Ghia
wayne1230cars Samba Member
Posted: Thu Mar 05, 2015 9:32 am Post subject: |
panicman wrote: |
Glad the horn ring is broken? That's an odd sentiment. Good luck finding a replacement. |
Absolutely agree. Having restored a 1960 bug over the past few years I have an appreciation of how difficult certain parts are to find. The 60/61 steering wheel and horn parts can definitely be a challenge to locate. The Samba classifieds are a great source.
Best of luck with your car. _________________ 1960 beetle
1970 beetle convertible |
Posted: Thu Mar 05, 2015 9:36 am Post subject: |
panicman wrote: |
I worded that wrong... I meant Im glad its the correct 60-61 wheel. When I was looking at the photos of the car, I thought it had a 64-65 wheel due to the lack of ring. |
wayne1230cars wrote: |
panicman wrote: |
Best of luck with your car. |
Thanks |
Posted: Thu Mar 05, 2015 9:38 am Post subject: |
I guess the 60-61 sticky will be helpful here |
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Thu Mar 05, 2015 11:00 am Post subject: |
It's easier to see with the tank out, but you should be able to see if the choke cable tube is there by taking the front wheels off and having a look up in there.
The big issue without knowing if it has a serial number is really who legally owns the car and what is it?
The number should be stamped into the tunnel. Sometimes they did get filled with paint over the years but they HAD to be visible and readable when the car rolled off the line.
Post a couple picture if you can of the area where the number is supposed to be. That might help figure out what happened to the number. _________________ Mother Nature is a Mean Evil Bitch! |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13269 Location: Tejas!
