bbbtate Samba Member
Joined: April 23, 2014 Posts: 16 Location: Iowa Park, TX
Posted: Thu Mar 05, 2015 3:17 pm Post subject: Brake Fluid Leak |
I'm having a pretty bad brake fluid leak in my '74 Super. It's had a small leak since I got it two years ago, but it's recently got very bad. I filled it up one night, next morning it was all puddled on the concrete. I don't know much about the brake system in general, but I've been told it might be leaking from the master cylinder. Could I get some advice on fixing this? Thanks |
volkswagen_bug Samba Member
Joined: November 04, 2008 Posts: 759 Location: Sumter, SC
Posted: Thu Mar 05, 2015 3:27 pm Post subject: |
Look for visible leaking around the reservoir and the lines leading to the master cylinder. _________________ 1968 Volkswagen Bug w/ 1600 Dual Port
"It’s better to give than to receive. Especially advice." -Mark Twain |
Ok, will do. |
Posted: Thu Mar 05, 2015 3:31 pm Post subject: |
Ok, so the master cylinder itself has brake fluid all over it. The lines leading from the reservoir all seem to be dry though. |
Posted: Thu Mar 05, 2015 3:37 pm Post subject: |
If the lines are dry and have no holes, check the seals on top of the master cylinder where the reservoir lines attach. _________________ 1968 Volkswagen Bug w/ 1600 Dual Port
Posted: Thu Mar 05, 2015 3:39 pm Post subject: |
Alright, I'm away from the car right now, but I'll check that later this evening. |
tcochr Samba Member
Joined: June 23, 2014 Posts: 62 Location: Augusta, GA
Posted: Thu Mar 05, 2015 4:06 pm Post subject: |
I had the same problem a few months ago. Fill up the reservoir and by morning it was all on the concrete. It was my master Cylinder leaking at the attachment point to the body (behind the accelerator pedal).
The problem is, it aint super-easy to replace due to the 2 spacers that must be threaded onto the bolts when you put on the new one. Theres a few good hints on how to do that here in other threads, Like using thin string/ wire to keep the spacers in place. The rest of the replacement is pretty straightforward:
1. Remove connections from Master Cyl.
2. Prime New Master with fluid (get all the bubbles out)
3. Bolt on New master Cyl ( dont forget those troublesome spacers)
4. Reconnect all the lines and the switch from step #1
5. Bleed the brakes.
6. Miller time.
My problem was further exacerbated by the path the fluid took to drain...right down the main center tunnel (the one with the Heater control cables, the shift rod etc) and leaked out a drain hole in the center.
The brake fluid should be cleaned up, but exactly how to do that is difficult to say due to so much mythology around hygroscopic brake fluid (the fluid is water absorbing). I did not want my car to rust from the tunnel out. In the end I opted to use some dawn dishwashing liquid and some warm water mix to clean it all out. I think it worked, because when I inspect the tunnel through the access port in the rear, and by the E-brake it looks much cleaner and very little residue (cant tell what is is in there). I did find some old army men and a @ .38 cents in change though). Only a few years will tell for sure if it worked. I just know that doing nothing will eat the tunnel away in very short time.
If you do lose a spacer...It is gone forever in the black hole of the bug firewall. I found some generic spacers at Ace and just had to shorten them to fit nicely. Yes, I lost one of my spacers in the black hole.
There is alot of mythology around cars in general, and bugs have no shortage.
Tim _________________ 1973 stock super. 2nd owner. Hawaii garage kept. NO RUST ANYWHERE. Now in Georgia. |
TheAmazingDave Samba Member
Joined: April 11, 2013 Posts: 788 Location: San Jose, CA
Posted: Thu Mar 05, 2015 4:20 pm Post subject: |
tcochr wrote: |
The problem is, it aint super-easy to replace due to the 2 spacers that must be threaded onto the bolts when you put on the new one. |
No joke. I dropped one in to the body the first time I changed my master. I cut a new one out of a small steel tube, and made it just a bit longer so it wedges in between the two body panels. It won't be falling out again...
My bottom spacer is original; I just leave the bolt in place through it after unthreading it from the master cylinder, and it holds the spacer in place. _________________ Just call me Big D. (formerly xBigDx408x)
TheAmazingDave.net
Deutschland Dubs 2015 at Presidio Trust |
tcochr Samba Member
Posted: Thu Mar 05, 2015 4:33 pm Post subject: |
The Army moves me so much I cant keep excess parts like tubing around.
I need to retire so I can have a proper shop with some real odds and ends around. _________________ 1973 stock super. 2nd owner. Hawaii garage kept. NO RUST ANYWHERE. Now in Georgia. |
Posted: Thu Mar 05, 2015 4:36 pm Post subject: |
tcochr wrote: |
I need to retire so I can have a proper shop with some real odds and ends around. |
That's the same issue I'm running into with the Air Force. With dep. weight allowance I still get close to my max. That's before I bought the bug and all of the tools. _________________ 1968 Volkswagen Bug w/ 1600 Dual Port
Joined: June 02, 2011 Posts: 1593 Location: Louisville, ky
Yikes, how is that car safe to drive. You probably only have half the brakes.
The spacer is easy to deal with, just don't take the bolts out. |
tcochr Samba Member
Posted: Thu Mar 05, 2015 4:40 pm Post subject: |
Yep. Dont remove the bolts FULLY from the hole...That way the spacers stay in and on the bolt.
Excellent advice for bbb...too late for me.
Posted: Sun Mar 08, 2015 9:36 pm Post subject: |
Alright, well the leak is on top of the master cylinder right around the seal with the white plastic tube coming out. I tried for about 15 minutes trying to get that out, nothing.. |
sb001 Samba Member
Posted: Sun Mar 08, 2015 10:17 pm Post subject: |
It should just pull out although it might be quite tight..
_________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Geirskogul Samba Member
Posted: Mon Mar 09, 2015 1:09 am Post subject: |
Semi-hijack, but I'm doing the master cylinder on my bug, but the new switches I bought to go along with it (the old ones don't activate unless I push down on the pedal hard) only thread in one or two turns before getting very tight in the master cylinder body. Is this normal? |
green1303 Samba Member
Joined: February 04, 2014 Posts: 748 Location: Alexandria, VA
Posted: Mon Mar 09, 2015 4:14 am Post subject: |
bbbtate wrote: |
I figured that would be the case. Those hoses can be a bear to get off. Mr. Duncan suggested using an OEM master cylinder due to the cheaper reproductions failing. That's if you go down the path of replacing it. _________________ 1968 Volkswagen Bug w/ 1600 Dual Port
Cusser Samba Member
Joined: October 02, 2006 Posts: 31362 Location: Hot Arizona
Posted: Mon Mar 09, 2015 6:18 am Post subject: |
Geirskogul wrote: |
Are those new switches the same thread, doesn't sound like it. Yes, they are pipe thread, but should thread in further than that. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Mon Mar 09, 2015 7:34 am Post subject: |
Ok, I'll keep trying. I'd like to avoid replacing it if possible. Hopefully the only problem is that seal. |
Posted: Mon Mar 09, 2015 7:36 am Post subject: |
But then again, it might be good to replace the whole cylinder. |
