VSarge Samba Member
Joined: March 31, 2008 Posts: 367 Location: St Louis, MO
Posted: Tue Mar 24, 2015 3:08 pm Post subject: |
Got a CNC single pedal with 5/8" master. Will pick up brake line, flex lines and residual valve when it comes in. LOL!! It'll be the prettiest part on the trike too.
Sarge _________________ _________________
VW trike -- FrankenMutt
1971 1600
Swing Arm frame
Stock 4 spd tranny - no reverse gate (crap!)
1966/67 rear brakes wheel cylinders from front of 1966 Bug
1934 Chevy headlight
Custom leading link front end
Ford Ranger rims
P225/60R15 rear tires
GoldWIng front tire
Body is fiberglass nose from semi
One ugly exhaust, heavily rusted, set up for heat??? On a trike?? |
Tyranicon Samba Member
Joined: September 02, 2008 Posts: 11 Location: Dewey OK
Posted: Fri Mar 27, 2015 10:16 pm Post subject: |
I thought all VW's master cylinders were below the wheel cylinders? _________________ 68 Karmmann Ghia Convertible
64 Beetle
VW Trike
"The advantage of a bad memory is that one enjoys several times the same good things for the first time." -Friedrich Nietzsche |
VSarge Samba Member
Posted: Sat Mar 28, 2015 6:00 am Post subject: |
If memory serves me correctly they also all ran remote reservoirs. _________________ _________________
1971 1600
Swing Arm frame
Ford Ranger rims
GoldWIng front tire
Posted: Sat Mar 28, 2015 6:29 am Post subject: |
Good point.
what residual valve are going to use, and where can I acquire one?
Thanks. _________________ 68 Karmmann Ghia Convertible
64 Beetle
VW Trike
VSarge Samba Member
Posted: Sat Mar 28, 2015 6:34 am Post subject: |
Since I am using drum brakes I'm using a 10psi one. I just went did a search and picked a lower priced one from a reputable company. I ended up with one from Wilwood I got thru Jegs. Free shipping that day for some reason.
1971 1600
Swing Arm frame
Ford Ranger rims
GoldWIng front tire
VSarge Samba Member
Posted: Thu Apr 16, 2015 9:43 am Post subject: |
She stops now!!!!!!!!!!
Ripped everything but the drum brakes out, installed my CNC 252C, new bubble flared lines (what the shop carried and cheaper), the valve and such. Went fast, even with a few bending screwups.
Took much less time to bleed and she stops now. A lot less time to bleed.
Fixed the clutch cable as well. Shifts like a dream even without a bowden tube. Gent at the shop swore it wouldn't without the tube.
Oh and for those who insist that if the brakes lock up, then why upgrade? Well in a test run against a stock 67 VW upgraded to T3 brakes, even tho he outweighs me and needed to adjust his brakes, he stopped sooner.
1971 1600
Swing Arm frame
Ford Ranger rims
GoldWIng front tire
