Fuel injected Thing project
Page: 1, 2, 3, 4  Next
Jzsquared
Jzsquared is offline
PostPosted: Wed Mar 11, 2015 6:31 am    Post subject: Fuel injected Thing project Reply with quote
I decided to switch gears on my 1835 build and fuel inject the car this year, instead of next winter. I have been collecting parts for a short time now so I figured what the hey lets get it done. I have been covering my powder coaters mortgage the past month or so and am very happy with the results.
I'm going to use MS2 to run the car since it's the most widely used system for FI conversions. There are a ton of forum information that is still way over my head right now but hopefully will become second nature with time.
These are not the actual manifolds for this build but I had them coated for a future build. I'm guessing that once I go FI I will never return to carbs but you never know.
CB injection manifolds ported a bit
Stock shroud cleaned up and coated, I realized after it was coated I had to drill a different hole for the throttle cable but I took my time and it turned out fine.
tins coated
plenum in place with coated tins
The distributor is only in place until I receive the mini cam sync from Mario at The Dub Shop.
and another
shroud on
needed to make my own adapters to connect manifolds & plenum. I used a steel tube off a aftermarket manifold under a piece of http://smile.amazon.com/gp/product/B00NJC314I/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1 Pegasus tubing to make it pretty
I'm paranoid about fuel leaks so I looked into all set ups and decided on AN6 and stainless steel new return and feed lines. I did my homework about all the additives in cars now and the use of ethanol (jackass's stop burning food for fuel when there are people starving !) all the line meets 30r9 spec so it should outlast me. The stainless made it easy to shove through the tunnel I ran one line on each side to make it neat as possible.
figuring out where to mount regulator and lines
AN6 fittings
a before shot of the plenum before Powder Coating Pros did there magic
I will be megasquirting the engine with the help of The Dub Shop. This is my first crack at FI so it will be a learning curve & something I have always wanted to do. I will post more as I move forward lots to do like connecting fuel pump & electronics.
mondshine
mondshine is offline
PostPosted: Wed Mar 11, 2015 7:38 am    Post subject: Reply with quote
Your setup looks good.
My Thing has had a similar setup since before the turn of the century, except I use CIS injection. Megsaquirt had not been invented back then.
I will be curious to know whether you find the rotary throttle return spring adequate. The stock FI Beetles used a second spring which was connected to a long bracket that was part of the EGR system.
I fabricated a similar bracket which is bolted to the bell crank assembly.
This old (and lousy) photo sort of shows what I did:
Keep posting as you make progress. At least 1 person is very interested in how this works out.
Good luck, Mondshine
Jzsquared
PostPosted: Wed Mar 11, 2015 7:48 am    Post subject: Reply with quote
Thanks for the heads up, hopefully it will the stock spring seams strong but you never know
citroen
citroen is offline
PostPosted: Wed Mar 11, 2015 5:42 pm    Post subject: Reply with quote
it all looks good keep it going
Jzsquared
PostPosted: Wed Mar 11, 2015 6:13 pm    Post subject: Reply with quote
I received the rest of my AN fitting in the mail from Redhorse today so I started to connect the fuel pump. I really wanted to use the Aeromotive stealth in the tank pump but after looking closely at the fuel tank the pump would not go all the way to the bottom. Being such a small tank as is I didn't want to loose 1 precious gallon. I hope this in line pump is not to loud. Next winters project will consist of a new tank that I will custom build a intank fuel pump.
10x1mm to AN 6 fittings on the fuel pump
I used 5/16 hardline to AN6 adapters on the new line I ran. I could have used the stock line as a return but the line came in a 25' role so what the hey.
underneath pic with the return line connected.
I'm still waiting for my Russell inline fuel filter to arrive so I can finish the supply side. Its hard to tell in the pics but I used a piece of fuel line as a grommet for the new lines so it wouldn't be rubbing on the tunnel.
NY thing
NY thing is offline
PostPosted: Thu Mar 12, 2015 6:05 pm    Post subject: Reply with quote
Where is that gen stand/plenum from?
It looks like a nice little project you got going.
Jzsquared
PostPosted: Thu Mar 12, 2015 6:09 pm    Post subject: Reply with quote
75-79 fuel injected beetle usually called the German plenum. They come up forsale once and while on this site but I found mine on eBay. After some time in the media blaster they can come out pretty nice.
Jzsquared
PostPosted: Sat Mar 14, 2015 4:49 am    Post subject: Reply with quote
I finished up most of my fuel lines yesterday with a few changes from the original design. I was going to use the CB fuel tee which most likely would have worked fine but I just didn't like the fuel not having time to cool a bit before recirculating. I decided to have a AN6 bung welded on the top of the tank for the return instead. Bung $5 , welding $10 since i don't a welder my happiness priceless Very Happy
Here is the tee that goes on the bottom of the tank, again probably fine I just like to be different
line entering trunk area
New fitting on bottom of tank that a 90 degree AN6 will connect to fuel filter on the way to the pump
connected and out of the way for the most part
I wanted to run SS lines through the front cover so I made little lines for this. because of the regulator design I had to run 5/16 line AN6 was to big so I figured I will run the soft line off the back on both sides. The front cover is hacked up since I could not seam to figure out where the throttle cable tube was going to end up. This is an on going project so I will at some point get a new one but for now it works and you don't see it anyways.
super special fuel regulator mount $1.50 Home Depot special rived on
Regulators Mount Up !! (come on what movie reference)
line to and fro regulator to rail
cheap rivet gun that broke with 1 rivet to go, always happens to me like that
pressure gauge mounted
I ran the line from the one side to the other on top of the shroud. thought it looked clean and return goes back out on passenger side
mcmscott
mcmscott is offline
PostPosted: Sat Mar 14, 2015 9:56 am    Post subject: Reply with quote
Good call on not using the "t" on the bottom of the tank, I have had multiple problems with cavitation with it.
There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250
GI Joe
GI Joe is offline
PostPosted: Sat Mar 14, 2015 1:49 pm    Post subject: Reply with quote
Jzsquared wrote:
I finished up most of my fuel lines yesterday with a few changes from the original design. ...
Looking Great!! I love the symmetry of it all..
'74 Thing, "Our Thing"....Blue 181
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...p;start=60
'71 Beetle RPU
http://www.thesamba.com/vw/forum/viewtopic.php?p=8080337#8080337
www.NLEOMF.com
Respect, Honor, Remember
clonebug
clonebug is offline
PostPosted: Sun Mar 15, 2015 7:48 am    Post subject: Reply with quote
Looking good!!!!
I ran a German Plenum for a year on my FI.
I also cleaned up the inside of my intakes to get rid of the step.
If you ever decide to upgrade to turbo you might want to find a better connector for the intake since those stock ones tear at about 13 lbs boost.
They were a PITA to change in my buggy since I have to pull the motor to lift the shroud to remove the intakes. Crying or Very sad Crying or Very sad Rolling Eyes
Are you local to the PNW???
If so you should go to the Burger Meet in Seattle in July so we can take a peak at your FI system.
I'll be there and Mario is most always there too.
vwracerdave wrote:
Take a good long look in the mirror and report back on what you see.
Paul.H wrote:
That one line on that chart is probably better info than you can get from this place in a month
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936
Jzsquared
PostPosted: Sun Mar 15, 2015 8:06 am    Post subject: Reply with quote
I'm just west of Chicago,IL but thanks for the invite. I'll keep that in mind about the boost pressure this one will never the turbocharged to much power for a Thing. Heck I don't even like driving it over 60mph just used for taking the back roads and camping trips.
phulc
phulc is offline
PostPosted: Tue Mar 17, 2015 11:51 am    Post subject: Reply with quote
Great project, nice work! Applause
Looking forward to doing the same, still collecting parts ...
If I can sent you anything you look for that can be bought in Germany more easily IŽd be glad to help ...
http://www.181-berlin.de
Join us on facebook
Jzsquared
PostPosted: Tue Mar 17, 2015 4:35 pm    Post subject: Reply with quote
Did a few things today my Russell fuel filter came in so I finished up the lines leaving room to easy lift out tank later if needed. I also hooked up the pump wiring
Jzsquared
PostPosted: Thu Mar 19, 2015 5:04 pm    Post subject: Reply with quote
I had a few things arrive in the mail today woohoo. I used double sided tape to mount the relay board to make sure I like it here. One thing I know for sure is I want all the electronics in the engine compartment since its a convertible. I don't want to worry if get caught in a heavy rain that I need to worry about a short somewhere. The airfilter mounts were a great spot to mount the coils. I'm running the LS2 coils instead of wasted spark look out corvette owners Very Happy
I had to mark the 2 yellow wires to make sure I routed the O2 and tach wires correctly I need to buy more colors.
clonebug
clonebug is offline
PostPosted: Thu Mar 19, 2015 5:33 pm    Post subject: Reply with quote
I used Mario's twisted pair wires for the TPS, IAT, CLT, trigger wheel and the four injectors. They come with the correct connectors on the ends and a nice covering that protects them.
You can't really beat the price and it is so much easier to hook up since all you have to do is follow his color coded wiring diagram.
It looks like this when you are done if you do a little house keeping to make it look nice..
Audi TT intercooler
EcuMaster PMU16
Jzsquared
PostPosted: Fri Mar 20, 2015 5:17 am    Post subject: Reply with quote
I did order the rest of the wiring from there as well so the other wires will look as tidy. Once you really get into this kind of project it's really not hard at all just a few more wires to run.
Bobalos
Bobalos is offline
PostPosted: Fri Mar 20, 2015 6:57 am    Post subject: Reply with quote
VERY cool project. Your doing very nice work.
Bob
Jzsquared
PostPosted: Sat Mar 21, 2015 6:17 am    Post subject: Reply with quote
Time to stop looking at the engine on the stand and put her back in the car.
The manifolds are a little wider than stock but not enough to cause issues installing.
I did have to remove the fuel regular since it kept getting caught on the engine seal
I bolted a piece of metal to my old HF motorcycle jack and slid
the engine from the lift table to the jack
After fighting with the engine for 20 minutes because it wouldn't go all the way
in my old age kicked in and said relax take it back out and figure it out.
Rookie mistake the Kennedy clutch has a center piece only used on the older transmissions.
So off it came and wow it fits
fuel line installed
Air temp sensor
Engine temp sensor
I think I picked a good spot for the relay board,
still need a little tiding up but it is tucked away but accessible
Been a long day time to sit back relax and have a cold one
PumaVW79
PumaVW79 is offline
PostPosted: Sat Mar 21, 2015 10:46 am    Post subject: Reply with quote
Nice project, great creativity. I'm sure it will be a joy to drive.
If it's for safety measures, call me paranoid too... Smile
Page 1 of 4
