Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Tue Mar 17, 2015 8:41 am Post subject: |
The main fuel hose exiting the 1/2 injectors goes to your adjustable fuel pressure regulator in your return line. You have the extra outlet on both sides? _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
nogoodwithusernames Samba Member
Joined: November 10, 2014 Posts: 599 Location: CA, USA
Posted: Tue Mar 17, 2015 9:00 am Post subject: |
Mike, I think this is something else. Both sides have the 5 point connection (2 on the bottom for injectors, 2 sides for 1 outlet and 1 inlet, and the one on top.)
The 3/4 side has a screw in it like mentioned, the 1/2 side has a fuel line going up to something that is on the throttle/air distributor body (there is also a wire running to this same piece). Side 1/2 also has the return line going through what I believe is the pressure regulator connected to the front tin before going to the hardline back to the tank.
I didn't see this mystery piece when I was looking at the fuel system in the Bentley but I may have missed something. _________________ 71 Squareback, 1.7l T4 w/ crank trigger fuel and spark
(Conversion thread https://www.thesamba.com/vw/forum/viewtopic.php?t=732508&highlight= or https://shoptalkforums.com/viewtopic.php?f=1&t=151375&sid=f0542d44a322d290c29d6609fac7f215 )
74 914, 2.0L w/ D-Jet
-Derek |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34009 Location: Conejo Valley, CA
Posted: Tue Mar 17, 2015 10:29 am Post subject: |
nogoodwithusernames wrote: |
the 1/2 side has a fuel line going up to something that is on the throttle/air distributor body (there is also a wire running to this same piece). |
That is your cold start jet. |
Donnie strickland Samba Member
Joined: December 21, 2009 Posts: 2403 Location: Moody, AL
Posted: Tue Mar 17, 2015 10:52 am Post subject: |
KTPhil wrote: |
Correct. Maybe Mike's 69 doesn't have a cold start valve? _________________ 71 Elm Green FI A/T Squareback |
Posted: Wed Mar 18, 2015 5:22 pm Post subject: |
Alright everyone, good news! As you all guessed it was a vacuum leak and no fault of the old lines...
I had accidentally disconnected the line from the AAR into the throttle body when running new fuel line across there. I did replace all the old lines still and she's running good again! I haven't driven her yet but hopefully that part will be better too. 'edit' she drives great again too, no one from the Addams Family hitching a ride.
No luck with fuel pressure yet. My FLAPS didn't have the gauge in stock today.
And yes the cold start jet was 70+ so Mike doesn't have one. (As per the Bentley)
Thanks again everyone! _________________ 71 Squareback, 1.7l T4 w/ crank trigger fuel and spark
-Derek |
KTPhil Samba Member
Posted: Thu Mar 19, 2015 9:30 am Post subject: |
Check your filler neck sealing; typically old ones are cracked and let water and dirt into your tank.
When you remove and install the tank, be careful of the thin rubber sock used under the large thick filler tank pipe. It is easy to tear, but it must be perfect to seal while submerged, as it will be after a fillup. |
Posted: Sat Apr 04, 2015 4:33 pm Post subject: |
Been a while since an update. I've been going through stuff still. Got the the overflow hose replaced (the molded rubber elbow bit going under the fender to the filler neck) it was badly cracked and could be letting in dirt. Got the tank outlet and screen replaced, mine was bent and rusty and cruddy. I replaced the fuel filter a few times to make sure everything was out of the tank.
Today I...
-Rented a fuel pressure kit from a place down the street cause the auto parts store didn't have one the last few times I was there. It was a little high at first (35psi) set it to 30 so that should be good.
-Checked all spark plugs. They were all gapped a bit wide so I corrected them and cleaned them up.
-Put in new spark plug wires, the old ones were quite stiff.
-Finished replacing injector seals. My order came in this week so I was finally able to get that done.
It is still running poorly and I have determined it to be a vacuum leak. I took the elbow from the air cleaner to the throttle body off and blocked the inlet with my hand and the idle smoothed out. I think it is one of the hose connections between the manifold and throttle body but I couldn't hear any differences when doing the "carb cleaner test". Does anyone sell those and how hard are they to replace? _________________ 71 Squareback, 1.7l T4 w/ crank trigger fuel and spark
-Derek |
Posted: Wed Apr 08, 2015 8:37 pm Post subject: |
Well this afternoon I got some stuff done, but still no luck with running any better.
I was able to get the 1/2 side all re-sealed, there is a hose shop near me that had some silicone hose the same size as the stuff from the air box to intake manifold so I replaced two of those today, I got some paper gasket material and re-did the manifold to head seal (new paper on either side of the spacer. I stuck it to the spacer with some non hardening gasket sealer.) and re-seated the injectors to make sure there is a good seal.
I guess my vacuum leak is on 3/4 side so I will let you know when that is done. Maybe tomorrow night after work. I was hoping to be able to take her to work tomorrow but oh well huh? _________________ 71 Squareback, 1.7l T4 w/ crank trigger fuel and spark
-Derek |
Intrinsic Samba Member
Joined: November 16, 2011 Posts: 262 Location: Clearwater, FL
OGSquare Samba Member
Joined: March 18, 2008 Posts: 244 Location: N. Georgia
Posted: Sat Apr 11, 2015 10:46 am Post subject: |
Have you replaced the spark plug wires? They go bad and are frequently overlooked when diagnosing driveability problems. _________________ Early 71 Stock Squareback
Early 65 Stock Doublecab
63 Stock Beetle |
Posted: Mon Apr 13, 2015 11:44 am Post subject: |
Another idea. Remove the rockers and check the torque on the head studs. You can only check the bottom 4 studs but, they are the ones that usually come loose. Also, pull your plugs and see what their condition is. After you replace them, check the compression on all cylinders. Another thing to do is pull the throttle body off to see if it's crudded-up inside. When you do this, check the 4 external rubber seals that connect the throttle body to the fuel runners. These seals dry out and leak over time. All these things were problems on my '71. Even after I fixed all this, I still had problems. I ended up rebuilding the engine and found all my compression rings were totally worn out. _________________ Early 71 Stock Squareback
63 Stock Beetle |
Posted: Wed Apr 15, 2015 5:02 pm Post subject: |
Alright another update. Finished the 3/4 side intake seals and manifold hoses so those are all new. Took it down to the local VW mechanic on the way to pick up my stock wheels from the blaster, and he listened to it and made some adjustments. Those being adjusting the timing a little and moved the little black box on the side of the throttle a bit.
It helped smooth out the idle and it is running much better in general but still a but "surgy" during cruising.
Any ideas?
I am getting ≈13.5v and 25amps from the generator. _________________ 71 Squareback, 1.7l T4 w/ crank trigger fuel and spark
-Derek |
Posted: Wed Apr 15, 2015 5:57 pm Post subject: |
If it's surging, it could be one of more cylinders intermittently cutting out rather than all the cylinders surging at the same time. There is a connector on the front top of the engine with 4 wires connected to it. There are the grounds for the fuel injectors. Over time the slide-on spade lugs loosen up and the insulation cracks on the wiring. You can check to make sure they're all tight. I've also had the wires going to the fuel injectors fray and make intermittent connections. Mine is the same year as yours and I've already had to replace both wires going to 1-2 side. Also, the trigger points in the distributor could be worn. I've had to replace them on my car as well. _________________ Early 71 Stock Squareback
63 Stock Beetle |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Wed Apr 15, 2015 8:22 pm Post subject: |
I am getting ≈13.5v and 25amps from the generator. |
Isn't 13.5v a bit on the low side? I recall reading in other threads that the FI system likes to see over 14v or it can start acting wonky. |
Posted: Thu Apr 16, 2015 8:52 am Post subject: |
sjbartnik wrote: |
It would be pretty strange to design a PCB that required 14v in a 12v car, even for Germans. _________________ Early 71 Stock Squareback
63 Stock Beetle |
Posted: Thu Apr 16, 2015 8:37 pm Post subject: |
Well after I got home from work today I was playing around a little trying to see what what going on. I picked up a remanned beetle generator (bosch even!) and put it in. It ran well but the generator light was on. Turns out since it's a beetle gen that it was backwards so I flipped it around and it started running poorly again but the generator light was off.
Any ideas from this info?
I'm hoping and thinking it's not the injector wiring but that may just be me not wanting to check all the wiring... _________________ 71 Squareback, 1.7l T4 w/ crank trigger fuel and spark
-Derek |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22727 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Thu Apr 16, 2015 8:55 pm Post subject: |
OGSquare wrote: |
sjbartnik wrote: |
It would be pretty strange to design a PCB that required 14v in a 12v car, even for Germans. |
Yet, that's what they did. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Fri Apr 17, 2015 5:07 am Post subject: |
sjbartnik wrote: |
If you're worried about the voltage going to the ECU, you have to check the output coming from the voltage regulator, not the generator. The voltage regulator could be bad but I don't think that is your problem. I'm not even getting 13.5v out of my generator/regulator and, my car runs like a scalded dog. _________________ Early 71 Stock Squareback
63 Stock Beetle |
