Loubikerun Samba Member
Joined: October 21, 2009 Posts: 10 Location: altoona,PA
Posted: Sun Mar 15, 2015 5:50 am Post subject: Seat belts- anybody ever retrofit a self retracting set? |
As we all know the original seat belts that just hang there can be a pain to adjust, and look messy. I've been wondering if I could find something retractable in our local U-Pull-It junkyard that would give me retractable seat belts. Anybody every try this? I have looked at the aftermarket cheap ones on E-bay, but the usual safety concerns weigh on those belts. Something from the Junkyard might be a tougher more reliable belt. |
hopkin Samba Member
Joined: June 25, 2012 Posts: 2480 Location: Ottawa, Ontario
Posted: Sun Mar 15, 2015 6:05 am Post subject: |
The Mexican Beetle use retractable seatbelts that should bolt in:
1B0857705A (left), 1B0857706A (right). You may need the buckle as well:
BAA857755D. There may be different part numbers for the older (late 70s) beetles which I think used a similar set up.
Some people have retro-fitted GM seatbelts which are almost identical, there are some threads on it.
Here's an image on the seatbelt configuration on the Mexican Beetle:
_________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
1991 Honda Civic (Original Owner)
1996 'Open Air' Mexican Beetle (current)
2015 Golf (current)
2017 Dune Edition (daughter's car) |
relicstone Samba Member
Joined: May 06, 2006 Posts: 365 Location: Smyrna Delaware
Cusser Samba Member
Joined: October 02, 2006 Posts: 31362 Location: Hot Arizona
Andymon Samba Member
Joined: February 24, 2015 Posts: 313 Location: Medford, OR
dirtkeeper Samba Member
Joined: February 19, 2008 Posts: 3200 Location: Left of everywhere
Posted: Sun Mar 15, 2015 9:32 am Post subject: |
I installed bmw retractable belts along with my bmw seats. Also found some that fit the back seat too. A key o these is the way they are mounted. The mechanism that "locks" the belt on impact or under stress is a small ball bearing in a little plastic cup. In the wrong position it won't work right. |
gt1953 Samba Member
Posted: Sun Mar 15, 2015 10:51 am Post subject: |
Cusser advised me on the Hummer seat belts. Do not skimp on the safety item. They do work great and did have to get this bracket.
http://www2.cip1.com/ProductDetails.asp?ProductCode=C26%2D857%2D024 _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
sb001 Samba Member
Posted: Sun Mar 15, 2015 10:54 am Post subject: |
Do those cip brackets have the small mounting locator pins like the original repa ones did? _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
moparvwfreak Samba Member
Posted: Sun Mar 15, 2015 6:18 pm Post subject: |
Mom has Honda retractables in her 66. Looks a little wierd bu ft they work. _________________ 71 Bug 1600DP, 79 Rabbit L, 89 Jetta GL WE, 90 GLI, 90 Passat GL Wagon Calypso Green, 93 Passat GLX VR6. and that's just the dubs!
Dodges, Datsuns, and Dubs. i am a glutton for punishment. |
mike58 Samba Member
Posted: Sat Aug 27, 2016 7:19 am Post subject: Re: Seat belts- anybody ever retrofit a self retracting set? |
Hi
Does anyone know where i could get a new or used left side Mexican seat belt part no 1B0857706A
My inertia reel on mine has frozen and I need an identical replacement urgently.
When I google the part no. its almost zero hits which is unusual.
I'd be really grateful if anyone can help.
Mike |
sb001 Samba Member
Posted: Sat Aug 27, 2016 8:07 am Post subject: Re: Seat belts- anybody ever retrofit a self retracting set? |
mike58 wrote: |
Hi
Mike |
According to this page:
http://autopartmaster.com/en/?action=catalog_show&cat=vw&t_id=118954&id_pic=49688
the left side belt w/ inertia reel was part number 1B0857705A
Do a search for that you get several hits, of course most say out of stock or discontinued. Looks like Bus Depot might be able to get it, don't know:
http://www.busdepot.com/1b0857705a _________________ I'm the humblest guy on this board.
1600 SP engine
