soissisc Samba Member
Joined: April 04, 2007 Posts: 637 Location: Western Pennsylvania
Posted: Mon Mar 16, 2015 10:37 pm Post subject: 99 Passat No Crank, No Start, Automatic |
This is my son's car. I am experienced with water cooled VW's, just not this 1.8T... (more of an ABA, VR6 kind of guy...)
Issue is, out of the blue, turn the key and nothing happens. Lights on dash are on, radio plays, windows work, gas door opens, trunk opens, fuse 14 ok, etc, etc, just no crank of the starter, and no click of the starter solenoid. I pulled the ignition switch and checked the switch for continuity when the key is turned. It all appeared ok. BUT, when switch is plugged in and key is turned, I do not get 12 volts across to the red wire to the red / black stripe wire. I do get 12 volts across the other red wire to the yellow and black wire.
I tried bypassing the safety solenoid, no luck. Even tried a jumper on the ignition switch, no luck (red to red/black when key turned). I am led to believe that CCM is OK since all those features seem to work, although the carpet seems kind of damp (it has been a long winter). Brake switch turns on brake lights, so I assume it works to enable starting of the car?
Any ideas on systematically working from battery to starter? Should I not get 12V across the red wire to red/black wire when the key is turned? Could it be as simple as a suddenly bad ignition switch?
Any and all advice is appreciated.
Thanks _________________ Mark
68 Westy
92 Jetta (oh it is retired)
99 Eurovan
05 NBC
06 Audi A3
72 Westy (I am going to fix it up) |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Tue Mar 17, 2015 1:40 pm Post subject: |
Seems the electrical portion of the ign sw would be a cheap enough diagnostics tool. And the brake sw has nothing to do with starting. Does it crank if the battery is connected for a jump? How old is the battery? A Bently manual will show you what terminals on the switch to look at. |
Posted: Tue Mar 17, 2015 1:48 pm Post subject: |
It does not crank when hooked up for a jump. The battery was new last summer. I supposed "I" should bone up for a Bentley... being that it is not "my" car... OR it will never get fixed _________________ Mark
68 Westy
99 Eurovan
05 NBC
06 Audi A3
ps2375 Samba Member
Posted: Tue Mar 17, 2015 2:55 pm Post subject: |
Kids are great, aren't they?
Have you tried jumping the starter solenoid at the starter? That'll let you know if the starter is good or not. |
Posted: Tue Mar 17, 2015 3:41 pm Post subject: |
I have not. It sits so low to the ground that I need to get a jack under it to even understand how to access the starter. (Practical, I know.) _________________ Mark
68 Westy
99 Eurovan
05 NBC
06 Audi A3
ps2375 Samba Member
Posted: Tue Mar 17, 2015 4:31 pm Post subject: |
Yes, they are low. You might as well check all that you can before tossing money at it. |
