Please help Carburetor driving me nuts
Lpec900
Lpec900 is offline
PostPosted: Wed Mar 18, 2015 10:18 pm    Post subject: Please help Carburetor driving me nuts Reply with quote
after a few minutes of driving and then shut off the bug. As its sitting for about 5-10 minutes it's starts to leak fuel out of the injection tube. Now here's the kicker it leaks with the top of the carburetor off. Carburetor is a Solex 30 pict 1. The carb has been rebuilt. Fuel pump is new And Running fuel pressure is 3.5lbs and after its shut off fuel pressure goes to 5lbs then starts to drop. But keep in mind it leaks with the top of the carb off. So I really don't think its fuel pump related.
Volks Wagen
Volks Wagen is offline
PostPosted: Thu Mar 19, 2015 2:47 am    Post subject: Reply with quote
Does it keep leaking or does it leak a bit and then stop? If the level in the float bowl is too high then a bit will leak out. This might mean a bad float or you need to adjust the float level.
The title of your post reminded me of this:
Guy walks into the doctor with a steering wheel down his trousers and says "I've got this problem and it's driving me nuts". Good innit?
1973 1303 with AB-motor - sporadic
reconstruction as time permits, 1986 ex-Bundeswehr Doka - on the road again.
I'm definitely, probably, the worlds greatest lover.
Aithníonn ciaróg ciaróg eile.
Lpec900
Lpec900 is offline
PostPosted: Thu Mar 19, 2015 8:20 am    Post subject: Reply with quote
Lol. Yes it leaks for a lil bit then stops. It has a new float in it.
Volks Wagen
PostPosted: Thu Mar 19, 2015 4:50 pm    Post subject: Reply with quote
The fuel needs to be about 12-14mm below the top of the bowl...although this is more of a 'it depends' scenario, but it's a start. To change the fuel level in the bowl, you need to add or remove washers under the needle valve in the top of the carb. Adding washers means the valve closes sooner as the float rises with the fuel level, thereby shutting off the fuel sooner, and reducing the fuel level in the float bowl. Try adding a washer or using a thicker washer and see if that cures it, then take it out for a hard run and see that it all works well.
ashman40
ashman40 is offline
PostPosted: Fri Mar 20, 2015 3:38 am    Post subject: Reply with quote
Not sure what you mean by "injection tube". This was the best pic I could find of a 30-series carb with the top removed. Where is the fuel flowing from?
If the fuel level in the bowl is too high it can flow from the discharge tube, especially when the car is nose up on a hill.
AshMan40
Lpec900
Lpec900 is offline
PostPosted: Fri Mar 20, 2015 6:18 am    Post subject: Reply with quote
It's coming from the accel dump tube. Float setting is good and it's still doing it. And replaced the needle valve twice.
Lpec900
Lpec900 is offline
PostPosted: Sat Mar 21, 2015 8:59 am    Post subject: Reply with quote
Update I put another fuel pump and Carburetor on yesterday and it did the same thing...
Volks Wagen
PostPosted: Sat Mar 21, 2015 1:25 pm    Post subject: Reply with quote
Just wondering is your accelerator cable moving the arm after it's shutting down somehow.. What carb did you put on another 30 PICT 1?
Lpec900
Lpec900 is offline
PostPosted: Sat Mar 21, 2015 3:05 pm    Post subject: Reply with quote
I put a Solex 30/31. Maybe I have the accelerator cable wrong. I have pulled enough to take the slack out of it. What should it be.
Volks Wagen
PostPosted: Sun Mar 22, 2015 10:34 am    Post subject: Reply with quote
Not sure. Can you post a few pics of your carb installed from a few angles? Then folks might spot something.
Here's how to post photos:
http://www.thesamba.com/vw/forum/viewtopic.php?t=6
Lpec900
Lpec900 is offline
PostPosted: Sun Mar 22, 2015 7:10 pm    Post subject: Reply with quote
Ok. I will post some shortly. Thx
ashman40
ashman40 is offline
PostPosted: Tue Mar 24, 2015 4:10 pm    Post subject: Reply with quote
Normally, you should adjust the throttle cable so you can achieve full opening of the throttle (vertical throttle plate) when the pedal is fully depressed. I don't like the feel of this as the pedal rests very low to the floor. So I adjust it so it is fully open before the pedal reaches the floor. There are two problems with this method:
    1) You risk stressing the throttle arm as it is the only thing stopping your "lead foot"
    2) It may be possible to "over open" the throttle so it is beyond fully open and has started to close again. This means you don't get max acceleration when you "floor it ".
AshMan40
Lpec900
Lpec900 is offline
PostPosted: Fri Mar 27, 2015 8:21 pm    Post subject: Reply with quote
Ok update... I was just told its normal cause the fuel is oxygenated and it's just boiling over. 😕 .... what are you thoughts on that.
Lpec900
Lpec900 is offline
PostPosted: Mon Mar 30, 2015 4:51 pm    Post subject: Reply with quote
Ok I am having problem loading pics. But Here's an update. I put a electric fuel pump in. Electric fuel pump is in putting out 3psi and goes to zero after shut down. And it still leaks.
Lpec900
Lpec900 is offline
PostPosted: Mon Mar 30, 2015 9:41 pm    Post subject: Reply with quote
Another update put a 3rd carb on a 30 pict 2. And guess what it still leaks. 😡 I have video of it. But can't seem to load it.
Lpec900
Lpec900 is offline
PostPosted: Sun Apr 05, 2015 10:10 am    Post subject: Reply with quote
Update 4th Solex carb and installed Holley fuel pressure regulator. I Dialed the pressure down to 1.5psi and still leaks after shut down. Anyone got any ideas cause I am running out of them.
kreemoweet
kreemoweet is offline
PostPosted: Sun Apr 05, 2015 10:38 am    Post subject: Reply with quote
You should have listened to the person who told you it's normal, cuz it is. Gasoline, like every other fluid, expands
when heated. The gas in the carb will start absorbing heat from the engine after it's shut down. The gas above the check ball in the accel. circuit has nowhere to go except out the nozzle when it
expands. The amount of gas "leaking" that way is insignificant. If the gas contains very volatile additives, such as
alcohol, and the heat is enough, you can get vapor bubbles forming in the gas, which will force even more gas out
the nozzle.
'67 bug: seized by the authorities
Q-Dog
Q-Dog is offline
PostPosted: Sun Apr 05, 2015 2:21 pm    Post subject: Reply with quote
I don't quite understand. Is the car hard to start? Is it running poorly?
Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle
ashman40
ashman40 is offline
PostPosted: Sun Apr 05, 2015 3:03 pm    Post subject: Reply with quote
First off, stop messing with the fuel pump. It has no direct impact on the accelerator pump discharge. The fuel pump fills the fuel bowl until the float and inlet valve cut off the flow. If there is too much pressure you would see the fuel level being to high in the bowl, or fuel fleeing from the discharge nozzle. The fuel pump cannot force fuel to come out of the accelerator pump tube.
Since you have the same problem with different carbs it is likely not something specific to the carb. Look at how the accelerator cable is connected. Make sure there is nothing pulling on it as the engine sits.
The fuel expanding in the accelerator pump circuit is possible I suppose but the amount of fuel would be minimum. What problem is this leak causing?
Also, how hot is your engine? If it is heat related, you may be able to confirm this by opening the engine lid and get a fan to blow air into the engine area. This should minimize the heat transferred to the carb. Does this prevent the fuel discharge?
AshMan40
Harleyelf
Harleyelf is offline
PostPosted: Sun Apr 05, 2015 4:26 pm    Post subject: Reply with quote
Is your accelerator pump linkage correctly adjusted?
