doc73 Samba Member
Posted: Thu Mar 19, 2015 4:37 pm Post subject: Fell prey to the narrowed adjustable beam gods |
I did it. Here is my 66 with a adjustable narrowed beam from Oldspeed.
I was trying to add the before photo but had no luck. _________________ Speed Leaving Without Warning . . .
66 Bug
66 fastback (sunroof) |
vwsonmybrain Samba Member
Posted: Thu Mar 19, 2015 4:54 pm Post subject: |
Here you go:
Before:
MomoMoto Samba Member
Joined: March 02, 2015 Posts: 84 Location: Greenville, SC
Posted: Fri Mar 20, 2015 8:25 am Post subject: |
That really made a difference! Looks great! _________________ ------------------
'61 Beetle Ragtop
'15 Golf GTI |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Fri Mar 20, 2015 1:55 pm Post subject: |
Narrowed beam made the snow melt away, too.
Car looks good. I like the detailed BRM's. _________________ nothing |
54ovsemi Samba Member
Posted: Fri Mar 20, 2015 2:42 pm Post subject: |
looks real good! 2" or 4" narrow? tire size? _________________ 2013 Jetta
2009 Rabbit
2006 GLI
1955 Semaphore Oval |
doc73 Samba Member
Posted: Sun Mar 22, 2015 6:39 am Post subject: |
4" narrowed with 185/65 15 up front and 195/65 15 rear.
I have tire rub on the driver side headlight bucket when turning right and ever so slight amount on passenger side. I'm hoping my tire rub issue is due to the fact that the passenger side fender is curved different than the driver side. I've done different measurements from various points and it seems that the issue is with the fender. Looking into a fender swap. _________________ Speed Leaving Without Warning . . .
66 Bug
doc73 Samba Member
Posted: Sun Mar 22, 2015 6:42 am Post subject: |
The color is actually the diamond green. The pictures make it look so flat and dull. But that is the typical lighting on cloudy Ohio days! _________________ Speed Leaving Without Warning . . .
66 Bug
OTO X58 Samba Member
Joined: March 27, 2004 Posts: 3102 Location: Santa Cruz, CA
Posted: Wed Mar 25, 2015 1:05 pm Post subject: |
doc73 wrote: |
I have tire rub on the driver side headlight bucket when turning right and ever so slight amount on passenger side. I'm hoping my tire rub issue is due to the fact that the passenger side fender is curved different than the driver side. I've done different measurements from various points and it seems that the issue is with the fender. Looking into a fender swap. |
Do you have dropped spindles as well?
I'm asking because lowering that far with an adjustable beam might end up swinging the wheel forward, as the trailing arms move up. So the wheel will sit closer to the headlight buckets. You see it all the time in really low cars, but I can't quite tell from your picture. Since you have tall tires, it might be your issue, even though your car isn't ridiculous low.
Dropped spindles reduce that problem, because they move the wheel directly upwards (not forwards). And they allow you to leave the beam in a more raised setting, so that the trailing arms are more like stock. _________________ -Thomas
RIP HBB 10.10.84 - 12.25.09
1958 Ragtop Bug Build - Subaru Swap!
1957 Gazelle Beige Ghia FOR SALE
1957 Dove Blue Kombi field find |
doc73 Samba Member
Posted: Thu Mar 26, 2015 4:31 am Post subject: |
Yes I have dropped spindles. I might be a tad to low for the size tire up front. Also I believe the problem lies with the passenger front fender shape and the fact that the passenger rear spring plate was about 3 degrees off. _________________ Speed Leaving Without Warning . . .
66 Bug
