Jondoekauai Samba Member
Joined: November 23, 2014 Posts: 20 Location: Kauai Hawaii
Posted: Sat Mar 21, 2015 8:26 pm Post subject: Pan repair |
Got my pan quarter panels and cut out the rotted pieces. The battery section and most of the pan were good but the lowest part of the pan had rusted through because the rear window leaked and the sunroof did too. Cut up the new quarter to fit and it's pretty tight. Used weld through primer and I'm going to weld it in tomorrow. Should I take the paint off of the new panel and spray it with the weld through primer? What brand of seam sealer should I use? I've read about 3M heavy body seam sealer, what have you all used? Not going with any silicone house stuff ever but Sikaflex makes a pretty bullet proof sealer that may work good and it's paintable. We use it to seal the seams on water storage tanks. Thanks for your input.
Posted: Sun Mar 22, 2015 2:50 am Post subject: Pan repair |
Wow , nothing? So many helpful guys on this site I figured someone would step up to give me a hint or two. Hope tomorrow's better! Thanks in advance, Jon |
Derek Cobb Annoying
Posted: Sun Mar 22, 2015 4:03 am Post subject: |
3m has always done well for me, and I usually don't trust the "paint" that comes on replacement parts. |
panicman Samba Member
Joined: December 18, 2011 Posts: 2290 Location: Canby, OR
Posted: Sun Mar 22, 2015 10:27 am Post subject: |
Most of the experienced responders here recommend that you remove the finish that comes on new parts. They are probably just tired of answering the same question!
I think I used 3M seam sealer and I was happy with it. _________________ Plate of shrimp |
Posted: Sun Mar 22, 2015 12:19 pm Post subject: Pan repair |
Thanks guys I tried searching for an answer but after two hours of reading posts I was getting bleary eyed. |
beetlenut Samba Member
Posted: Sun Mar 22, 2015 12:23 pm Post subject: |
Generally you can't go wrong removing the E-coating that comes on the replacement pans, and using a good etching, epoxy, or comparable metal primer and top coat. Usually the primer that comes on the repair panels, especially the black stuff, is to keep them from rusting from the time they're stamped, to the time that they actually get installed. A good aircraft paint stripper usually does the trick. I wouldn't spray the whole panel with the weld-thru primer, but a good epoxy or Master Series Silver primer instead. Then a good top coat. I used SEM seam sealer and was happy with it. Any good quality auto seam sealer that doesn't harden will be good to go with. _________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
Posted: Sun Mar 22, 2015 1:26 pm Post subject: Pan repair |
Thanks, yeah I wasn't going to use the weldable primer except where I was welding. The E-coating is really whimpy and comes off very easily. I didn't think to pick up an epoxy primer so I guess I'll have to wait until later in the week to weld the patch in. I've been testing my settings on my welder with pieces from both new and old scraps and doing strength tests by bending the two pieces. I'm getting good penetration as evidenced by seeing the weld from the backside but no burn throughs and the metal tears before the weld. I'm going to spot it in place then stitch the rest a little at a time. What brand aircraft paint remover do you use? Thanks again, Jon |
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Sun Mar 22, 2015 2:29 pm Post subject: |
I have read pros AND cons re. weld-through primer . . . I decided to forgo using it when replacing my pans. Instead, I cleaned both surfaces before welding, then I used a hypo-applicator (one of these . . . http://www.amazon.com/Gaunt-Industries-HYPO-25-Applicator-Weld/dp/B00EZRQOAY) to flow thinned paint into the joint. You, of course, want to get the patch to fit tightly together when welding, then capillary action will draw the paint into the joint . . . you will actually be able to see the paint seep to the opposite side of the joint, so you know that the joint is filled with paint. After giving the paint time to cure, seam sealer on both sides will do the job.
_________________ Jesucristo es mi Seņor y Salvador! |
Posted: Fri Mar 27, 2015 2:24 am Post subject: |
Got the aircraft paint stripper, phosphoric acid etch, por15, and seam sealer. Going to weld in my pan patch panel after stripping and etching, should I prime before por15ing or after, then top coat after seam sealing? Everyone has their way of doing it and I'm so confused by a million different posts. Does it sound like it will work the way I described? No rattle can epoxy primer to be had here in the islands right now. Thanks. |
Posted: Fri Mar 27, 2015 8:44 am Post subject: |
You want to make sure the POR15 is compatible with whatever primer you use. I thought POR15 was put on over bare (after metal etch) metal? The welding process will burn off some of whatever you put on there, so I would leave the outer 2 inches of the metal where you're going to weld bare. Then prime after it's welded in. I would also at least prime before seam sealer to get some protection into the cracks. With Master Series Silver primer, I primed before seam sealing, then again after seam sealing over the seam sealer, then top coated. Don't think you can do that with POR15 though as its a one coat system. _________________ scrapyards are for quitters
Wetstuff wrote: |
Posted: Fri Mar 27, 2015 10:14 am Post subject: |
I painted . . . then I sealed the seams. _________________ Jesucristo es mi Seņor y Salvador! |
