Ghia 1966 Samba Member
Posted: Tue Mar 24, 2015 2:23 pm Post subject: Should semaphores move up and down when turned on? |
just installed the 12 v semaphores in my split 1950 and when I turn them on they start flip flopping up and down! is that normal, or should it be erected and just the light blinking? if the latter is the case, how could I fix this problem?
thanks _________________ - Split De luxe 1950
- Oval Ragtop 1956
- Karmann Ghia 1966 Convertible
- Bug 1970 Convertible |
coolparts Samba Member
Posted: Tue Mar 24, 2015 2:52 pm Post subject: |
SWF DID OFFER ONES THAT FLOPP AS AN ACCESSORY. I have a set of them on a 50 split. I leave yours alone because there more safer and easier to spot. The last time I saw a nos set the dude was asking 1800. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Bruce Samba Member
Posted: Tue Mar 24, 2015 7:37 pm Post subject: |
I bet he's got semaphores wired up to a flasher relay. 12V semaphores are not stock. _________________
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
i had a set of those in my old 56 fire panel, annoying as hell, but also quite cool _________________ regards
Uli
Posted: Tue Mar 24, 2015 7:40 pm Post subject: |
Bruce wrote: |
I bet he's got semaphores wired up to a flasher relay. 12V semaphores are not stock. |
good point, of course, that is not how it should be wired _________________ regards
Uli
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Tue Mar 24, 2015 10:29 pm Post subject: |
They r not stock ones ! 12 v ones from cip1
I also believe that electrician r connecting them to a wrong relay or something of this sort
Any video showing how the should b wired?!! installed and connected, relays , mechanisms , etc ... In order to show it to my technician ?
Thanks _________________ - Split De luxe 1950
- Oval Ragtop 1956
Posted: Wed Mar 25, 2015 6:30 am Post subject: |
Wiring diagrams thru the "Technical" button at top right of this screen. _________________ In Stereo, Where Available! |
p horvath Samba Member
Joined: December 29, 2003 Posts: 1225 Location: south carolina
Posted: Wed Mar 25, 2015 8:34 pm Post subject: |
had them on my 50 dlx.
called them "clackers". |
Keith Samba Member
Joined: August 15, 2005 Posts: 3634 Location: Brodheadsville, PA
Posted: Mon Mar 30, 2015 8:12 pm Post subject: |
You guys are overlooking the fact that he doesn't have stock semaphores and he certainly doesn't have accessory clackers. He has 12v CIP1 reproduction semaphores and the installer wired them to an actual flasher relay and that's why he is having issues with them. _________________ Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind |
