unibagel Samba Member
Joined: December 02, 2004 Posts: 528 Location: Bflo, NY
Posted: Wed Mar 25, 2015 11:36 am Post subject: How to remove engine/wiring harness 2001 Subaru Outback? |
I’m getting my Subaru donor vehicle today, is there a detailed description of how to remove the engine and wiring harness? The donor car is a 2001 Subaru Legacy Outback. What other parts should I remove as well? |
Zeitgeist 13 Samba Member
Posted: Wed Mar 25, 2015 11:48 am Post subject: |
Seems like an excellent question to ask on a site devoted to that particular marque. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
kalispell365 Samba Member
Posted: Wed Mar 25, 2015 12:15 pm Post subject: |
Rocky Mountain Westy has a good step by step on their website. _________________ 1983 Diesel Vanagon Westfalia chassis with Subaru 2.2l |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32584 Location: Reading Pennsylvania
Forthwithtx Samba Member
Joined: July 14, 2014 Posts: 717 Location: Fort Worth
Posted: Wed Mar 25, 2015 12:40 pm Post subject: |
There is a good tutorial at www.boxerswaps.com and I think a video on his YouTube channel, "Busaru". |
VTSyncro Samba Member
Posted: Wed Mar 25, 2015 1:36 pm Post subject: |
Did this to a 2001 Forester last weekend. The Boxerswaps.com instructions were super helpful even though I think they use a Legacy, it was all pretty similar.
Unplug everything, pull the whole dash, drop the steering wheel, remove the support bar, remove the AC channels.
The most important tool is cold beer. Have fun! |
babysnakes Samba Member
Posted: Wed Mar 25, 2015 2:40 pm Post subject: |
Have you checked out Shoptalk Forums? |
Joined: January 01, 2007 Posts: 16863 Location: sticksville, ct.
Posted: Wed Mar 25, 2015 3:12 pm Post subject: |
short sequence
remove dash/hvac unit. you will need to (ahem) LEGALLY evacuate the a/c system
remove l/f fender
as stated, have beer on hand, and 1/4 metric swivel sockets. _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Wed Mar 25, 2015 4:46 pm Post subject: |
skills@eurocarsplus wrote: |
short sequence
remove l/f fender
as stated, have beer on hand, and 1/4 metric swivel sockets. |
You make it sound like a 20 min. job. |
Hammy1 Samba Member
Posted: Wed Mar 25, 2015 4:57 pm Post subject: |
It took me about 2 hours to pull the motor and 2.5 hours to pull the harness, what a PITA!
Jon H. |
Posted: Wed Mar 25, 2015 10:06 pm Post subject: |
Hammy1 wrote: |
Jon H. |
Took me a bit longer with marking all the connections with masking tape. Even the ones you don't want, you probably want to mark, so later you don't go, "What is this? Do I need it?"
Some wires and connectors came in handy later for use elsewhere, or lengthening sections with same color wires. Keep your pile until you don't need it anymore, and then a bit longer.
Lesson learned for me: If the donor has electric windows and you want to preserve the interior for parting out, make sure they are closed before you completely scotch the electrical system. |
Posted: Thu Mar 26, 2015 4:17 am Post subject: |
Excellent resources! You guys rock! Thank you!
I'm going to send the harness to RMW as I'm getting their fantastic kit anyway. |
Posted: Thu Mar 26, 2015 4:31 pm Post subject: |
babysnakes wrote: |
short sequence
remove l/f fender
well, I do this crap for a living....
while the a/c machine was sucking out the 134, I was in the car pulling the dash. it comes out as an assembly, in about 20 minutes I had the dash out, another 15-20 the hvac unit was loose.
by then the a/c machine sucked it down, so I split the box, cut the harness back to the door jamb and rolled it in a box to ship off.
left engine in the car till I got the harness back.
got harness back, hooked the 3 wires together jumped the starter and made sure everything worked.
unzip intake, (while the coolant was draining) did all my top side stuff first. coolant done, pull radiator/condenser
up in the air, drop exhaust, do all my bottom stuff
back down
pull engine
the biggest bitch was the bell housing welded itself to the block. I good sharp air chisel took care of that.
all told, it was out of the car in 1:15
multitask!
I watch guys that have let's say a brake job to do and a oil change, balance and rotate.
they will change the oil. then do the brakes. then b&r.
I blow it in the air, pull the drain plug, blow the wheels off, do brakes, b&r install drain plug etc etc....got to make every motion count in my line of work _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Thu Mar 26, 2015 5:15 pm Post subject: |
Awesome reply, thanks!
Got any hints as to where the fasteners are to remove the dash? Or are they obvious? |
